See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/143/>
[...truncated 19200 lines...]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:934)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:917)
at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:902)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1228)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1163)
at org.geoserver.wms.wms_1_3.GetMapIntegrationTest.testRepeatedValues(GetMapIntegrationTest.java:185)
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.867 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-validation/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-data/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-jdbc/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-metadata/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-opengis/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-property/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-epsg-hsql/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-wms/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-imagemosaic/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-transform/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml
Downloading: http://oss.sonatype.org/content/repositories/snapshots/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.616 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/wps/wps-core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #475 from mbarto/24x_geos_6052
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 06.02.2014 @ 13:54:42 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 07-Feb-2014 09:03
[INFO] [GitCommitIdMojo] build.build.time = 07.02.2014 @ 09:14:08 UTC
[INFO] [GitCommitIdMojo] build.branch = 13dd73e9d251870f15bc5a6ec284fa024b398f11
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 13dd73e
[INFO] [GitCommitIdMojo] build.commit.id = 13dd73e9d251870f15bc5a6ec284fa024b398f11
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #475 from mbarto/24x_geos_6052
GEOS-6052: fixed VirtualTable deserializing when some elements are missi...
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ wps-core ---
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ wps-core ---
[INFO] Compiling 120 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/wps/wps-core/target/classes>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.784 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.334 sec
Results :
Failed tests: testTimeIntervalResolution(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest): expected:<TimeElevation.2> but was:<null>
testTimeListExtra(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest): expected:<TimeElevation.3> but was:<null>
testTimeListMulti(org.geoserver.wms.wms_1_1_1.DimensionsVectorGetFeatureInfoTest): expected:<TimeElevation.3> but was:<null>
Tests run: 543, Failures: 3, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ wps-core ---
[INFO] Copying 13 resources
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ wps-core ---
[INFO] Compiling 45 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/wps/wps-core/target/test-classes>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.234s]
[INFO] Core Platform Module .............................. SUCCESS [4.580s]
[INFO] Open Web Service Module ........................... SUCCESS [12.668s]
[INFO] Main Module ....................................... SUCCESS [2:08.882s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:09.968s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.320s]
[INFO] Web Map Service Module ............................ FAILURE [3:28.810s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.584s]
[INFO] Core UI Module .................................... SUCCESS [1:36.848s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [55.117s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:01.011s]
[INFO] REST Support Module ............................... SUCCESS [32.488s]
[INFO] WFS UI Module ..................................... SUCCESS [30.350s]
[INFO] Security UI Modules ............................... SUCCESS [0.565s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.649s]
[INFO] Printing Module ................................... SUCCESS [21.472s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.586s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.263s]
[INFO] Application Schema Support ........................ SUCCESS [0.300s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.403s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.150s]
[INFO] H2 DataStore Extension ............................ SUCCESS [13.733s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.302s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.814s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.956s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.707s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.266s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.667s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [28.764s]
[INFO] Excel Output Format ............................... SUCCESS [33.285s]
[INFO] Validation Module ................................. SUCCESS [3.401s]
[INFO] Chart external graphics support ................... SUCCESS [2.452s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.040s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.290s]
[INFO] OWS request flow controller ....................... SUCCESS [17.142s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.348s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [39.478s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.813s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [30.092s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.447s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [20.463s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF parent module ................................. SUCCESS [0.362s]
[INFO] DXF output format ................................. SUCCESS [29.962s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:02.285s (Wall Clock)
[INFO] Finished at: Fri Feb 07 09:14:16 UTC 2014
[INFO] Final Memory: 50M/173M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :wms
Destroying 1 processes
Destroying process..
Destroyed 1 processes
