[Geoserver-devel] Build failed in Jenkins: geoserver-2.4.x #17
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/17/changes&gt;
Changes:
[andrea.aime] [GEOS-5858] Inconsistent representation of workspace specific styles in rest
[andrea.aime] Make sure the test works even with odd chars in the build path (a @ in this case)
[andrea.aime] [GEOS-6074] Build failure in wms GetMapKvpRequestReaderTest in path with spaces
[...truncated 61706 lines...]
13 Oct 03:21:22 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:2:role org.geoserver.web.wicket.SimpleAjaxLink [ROLE_WMS]
13 Oct 03:21:22 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:2:role:link org.apache.wicket.ajax.markup.html.AjaxLink [ROLE_WMS]
13 Oct 03:21:22 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:2:role:link:label org.apache.wicket.markup.html.basic.Label [ROLE_WMS]
13 Oct 03:21:22 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.impl.GeoServerUser expression: save]
13 Oct 03:21:22 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.markup.html.link.Link [No get method defined for class: class org.geoserver.security.impl.GeoServerUser expression: cancel]
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.833 sec
Running org.geoserver.security.web.jdbc.user.JDBCNewUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.287 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ web-csw ---
13 Oct 03:21:42 ERROR [geoserver.web] - Error occurred while saving user
java.io.IOException: Details are in the nested excetpion
  at org.geoserver.security.validation.UserGroupServiceValidationWrapper.createSecurityException(UserGroupServiceValidationWrapper.java:283)
  at org.geoserver.security.validation.UserGroupServiceValidationWrapper.checkNotExistingUserName(UserGroupServiceValidationWrapper.java:90)
  at org.geoserver.security.validation.UserGroupStoreValidationWrapper.addUser(UserGroupStoreValidationWrapper.java:68)
  at org.geoserver.security.web.user.NewUserPage.onFormSubmit(NewUserPage.java:36)
  at org.geoserver.security.web.user.AbstractUserPage$6.onSubmit(AbstractUserPage.java:194)
  at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1561)
  at org.apache.wicket.markup.html.form.Form.process(Form.java:958)
  at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:920)
  at sun.reflect.GeneratedMethodAccessor226.invoke(Unknown Source)
  at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
  at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:527)
  at org.apache.wicket.util.tester.FormTester.submit(FormTester.java:695)
  at org.apache.wicket.util.tester.FormTester.submit(FormTester.java:742)
  at org.geoserver.security.web.user.NewUserPageTest.testUserNameConflict(NewUserPageTest.java:218)
Caused by: org.geoserver.security.validation.UserGroupServiceException: User user1 already exists
  at org.geoserver.security.validation.UserGroupServiceValidationWrapper.createSecurityException(UserGroupServiceValidationWrapper.java:282)
  ... 55 more
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/target/web-csw-2.4-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/target/web-csw-2.4-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web-csw >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web-csw ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6074] Build failure in wms GetMapKvpRequestReaderTest in path with spaces
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.10.2013 @ 17:52:57 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Oct-2013 02:56
[INFO] [GitCommitIdMojo] build.build.time = 13.10.2013 @ 03:21:43 UTC
[INFO] [GitCommitIdMojo] build.branch = 0d156ccc9a6a0d54226651351c6255f60ef1cd00
[INFO] [GitCommitIdMojo] build.commit.user.email = Ben.Caradoc-Davies@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0d156cc
[INFO] [GitCommitIdMojo] build.commit.id = 0d156ccc9a6a0d54226651351c6255f60ef1cd00
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6074] Build failure in wms GetMapKvpRequestReaderTest in path with spaces
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/target/web-csw-2.4-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-csw >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-csw <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-csw ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/target/web-csw-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web-csw ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/target/web-csw-2.4-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/web-csw/2.4-SNAPSHOT/web-csw-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/web-csw/2.4-SNAPSHOT/web-csw-2.4-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/target/web-csw-2.4-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/web-csw/2.4-SNAPSHOT/web-csw-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/target/web-csw-2.4-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/web-csw/2.4-SNAPSHOT/web-csw-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/csw/web-csw/target/web-csw-2.4-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/web-csw/2.4-SNAPSHOT/web-csw-2.4-SNAPSHOT-test-sources.jar
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.842 sec
Running org.geoserver.security.web.jdbc.user.JDBCUserListPageTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.322 sec
Results :
Failed tests: testRemove(org.geoserver.security.jdbc.H2JNDIRoleServiceTest): org.h2.jdbc.JdbcSQLException: Error opening database: Concurrent update [8000-119]
Tests run: 186, Failures: 1, Errors: 0, Skipped: 80
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [29.734s]
[INFO] Core Platform Module .............................. SUCCESS [4.461s]
[INFO] Open Web Service Module ........................... SUCCESS [22.063s]
[INFO] Main Module ....................................... SUCCESS [2:06.071s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:21.408s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.218s]
[INFO] Web Map Service Module ............................ SUCCESS [3:34.792s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.519s]
[INFO] Core UI Module .................................... SUCCESS [1:33.725s]
[INFO] Security UI Module ................................ SUCCESS [3:10.228s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.253s]
[INFO] GeoServer JDBC Security Module .................... FAILURE [2:57.699s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [52.048s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [51.426s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [59.259s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:02.899s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:29.510s]
[INFO] REST Support Module ............................... SUCCESS [29.355s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:28.346s]
[INFO] WMS UI Module ..................................... SUCCESS [50.581s]
[INFO] GWC UI Module ..................................... SUCCESS [1:01.700s]
[INFO] WFS UI Module ..................................... SUCCESS [32.954s]
[INFO] Demoes Module ..................................... SUCCESS [48.697s]
[INFO] WCS UI Module ..................................... SUCCESS [41.260s]
[INFO] Community Space ................................... SUCCESS [0.343s]
[INFO] Printing Module ................................... SUCCESS [19.262s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.686s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.209s]
[INFO] Application Schema Support ........................ SUCCESS [0.169s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:58.692s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.474s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [25.703s]
[INFO] GeoSearch Index Module ............................ SUCCESS [40.873s]
[INFO] H2 DataStore Extension ............................ SUCCESS [18.011s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.343s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.700s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.571s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.457s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.322s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [9.666s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.451s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [29.227s]
[INFO] Excel Output Format ............................... SUCCESS [32.494s]
[INFO] Validation Module ................................. SUCCESS [2.571s]
[INFO] Chart external graphics support ................... SUCCESS [1.156s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.839s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.731s]
[INFO] OWS request flow controller ....................... SUCCESS [19.753s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.180s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:09.348s]
[INFO] Web Processing Service GUI ........................ SUCCESS [40.386s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [39.022s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.455s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.678s]
[INFO] Core Monitor Extension ............................ SUCCESS [25.777s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [9.484s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [7.868s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.371s]
[INFO] XLST based WFS output format ...................... SUCCESS [44.144s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [42.625s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [24.131s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.239s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [28.373s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [22.071s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:27.589s]
[INFO] CSW UI Module ..................................... SUCCESS [25.174s]
[INFO] BUILD FAILURE
[INFO] Total time: 25:37.066s (Wall Clock)
[INFO] Finished at: Sun Oct 13 03:21:53 UTC 2013
[INFO] Final Memory: 59M/192M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project sec-jdbc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/security/jdbc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :sec-jdbc
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/18/changes&gt;
Changes:
[andrea.aime] [GEOS-5983] Add a way for styling to know what kind of KML output mode we are using
[niels] GEOS-6011: CSW: publish records for layer groups too
[niels] Support CSW requests with different types in query and in outputschema.
[niels] GEOS-6012: Automatically link CSW (ISO) records to the respective WMS/WFS/WCS sources
[niels] CSW: add test for unsupported outputschema
[niels] CSW: wms link in DC out of box mapping
[niels] CSW: Fix syntax error in mapping file.
[...truncated 26674 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.email = niels@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Niels Charlier
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8e0c056
[INFO] [GitCommitIdMojo] build.commit.id = 8e0c0567b89ef1e720094964e8d27f59da7623fc
[INFO] [GitCommitIdMojo] build.commit.message.full = CSW: Fix syntax error in mapping file.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-security ---
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.14 sec
Running org.geoserver.kml.icons.IconPropertiesTest
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/web/security/target/web-security-2.4-SNAPSHOT-test-sources.jar&gt;
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.231 sec
Running org.geoserver.kml.icons.IconPropertyInjectorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.02 sec
Running org.geoserver.kml.icons.IconRendererTest
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web-security ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/web/security/target/web-security-2.4-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/web/security/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/web/security/target/web-security-2.4-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/web/security/target/web-security-2.4-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/web/security/target/web-security-2.4-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoWebCache (GWC) Module 2.4-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoWebCache (GWC) Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
14 Oct 02:56:06 ERROR [image.test] - perceptualdiff is not available, can't compare target/expected.png with image2
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gwc ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/gwc/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gwc ---
[INFO] [GitCommitIdMojo] build.commit.message.short = CSW: Fix syntax error in mapping file.
[INFO] [GitCommitIdMojo] build.commit.time = 13.10.2013 @ 16:59:03 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 14-Oct-2013 02:41
[INFO] [GitCommitIdMojo] build.build.time = 14.10.2013 @ 02:56:06 UTC
[INFO] [GitCommitIdMojo] build.branch = 8e0c0567b89ef1e720094964e8d27f59da7623fc
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gwc ---
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gwc ---
[INFO] Compiling 39 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/gwc/target/classes&gt;
14 Oct 02:56:07 ERROR [image.test] - perceptualdiff is not available, can't compare target/expected.png with image2
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.538 sec
Running org.geoserver.kml.icons.IconServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.274 sec
Results :
Failed tests: testOutputModeVector(org.geoserver.kml.KMLTest): expected:<[1]> but was:<[0]>
Tests in error:
  testReprojectedVector(org.geoserver.kml.KMLTest): Could not load outputMode.sld from scope class org.geoserver.kml.KMLTest.
  testEncodeTime(org.geoserver.kml.KMLTest)
Tests run: 105, Failures: 1, Errors: 2, Skipped: 3
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoServer Security Modules
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gwc ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/gwc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gwc ---
[INFO] Compiling 19 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/gwc/target/test-classes&gt;
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.618s]
[INFO] Core Platform Module .............................. SUCCESS [5.095s]
[INFO] Open Web Service Module ........................... SUCCESS [11.681s]
[INFO] Main Module ....................................... SUCCESS [2:07.602s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:04.546s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.850s]
[INFO] Web Map Service Module ............................ SUCCESS [3:32.030s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.486s]
[INFO] Core UI Module .................................... SUCCESS [1:34.103s]
[INFO] Security UI Module ................................ SUCCESS [3:10.420s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [50.405s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:00.723s]
[INFO] KML support for GeoServer ......................... FAILURE [1:03.657s]
[INFO] REST Support Module ............................... SUCCESS [29.884s]
[INFO] WFS UI Module ..................................... SUCCESS [32.476s]
[INFO] Community Space ................................... SUCCESS [0.238s]
[INFO] Printing Module ................................... SUCCESS [23.315s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.571s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.179s]
[INFO] Application Schema Support ........................ SUCCESS [0.180s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.393s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [23.730s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.080s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.212s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.653s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.525s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.455s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.291s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.489s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [26.909s]
[INFO] Excel Output Format ............................... SUCCESS [32.564s]
[INFO] Validation Module ................................. SUCCESS [3.781s]
[INFO] Chart external graphics support ................... SUCCESS [1.197s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.590s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.668s]
[INFO] OWS request flow controller ....................... SUCCESS [19.452s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.175s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:14.074s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [38.689s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.133s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.209s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [28.900s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.268s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [18.510s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [19.270s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] Total time: 14:25.282s (Wall Clock)
[INFO] Finished at: Mon Oct 14 02:56:13 UTC 2013
[INFO] Final Memory: 52M/200M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project kml: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/kml/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :kml
Destroying 1 processes
Destroying process..
Destroyed 1 processes
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/19/&gt;
[...truncated 26548 lines...]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:remove org.apache.wicket.ajax.markup.html.AjaxLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm org.apache.wicket.markup.html.form.Form
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLUserGroupServiceConfig@anonymised.com]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[passwordEncoderName], BeanProperty[passwordPolicyName]]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML user/group service]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordEncoderName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:2:component org.apache.wicket.markup.html.basic.Label [Digest]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:3 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordPolicyName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:3:component org.apache.wicket.markup.html.basic.Label [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLUserGroupServiceConfig@anonymised.com]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[passwordEncoderName], BeanProperty[passwordPolicyName]]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML user/group service]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordEncoderName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:2:component org.apache.wicket.markup.html.basic.Label [Digest]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:3 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordPolicyName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:3:component org.apache.wicket.markup.html.basic.Label [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLUserGroupServiceConfig@anonymised.com]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[passwordEncoderName], BeanProperty[passwordPolicyName]]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [test]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [test]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [test]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML user/group service]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordEncoderName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:2:component org.apache.wicket.markup.html.basic.Label [Digest]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:3 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordPolicyName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:3:component org.apache.wicket.markup.html.basic.Label [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[passwordEncoderName], BeanProperty[passwordPolicyName]]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordEncoderName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:2:header org.apache.wicket.markup.html.panel.Fragment
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:2:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[passwordEncoderName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:2:header:link:label org.apache.wicket.markup.html.basic.Label [Password Encryption]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:3 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordPolicyName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:3:header org.apache.wicket.markup.html.panel.Fragment
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:3:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[passwordPolicyName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:3:header:link:label org.apache.wicket.markup.html.basic.Label [Password Policy]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:feedback org.apache.wicket.markup.html.panel.FeedbackPanel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:dialog org.geoserver.web.wicket.GeoServerDialog
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServicesHelp org.geoserver.web.wicket.HelpLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices org.geoserver.security.web.role.RoleServicesPanel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:add org.apache.wicket.ajax.markup.html.AjaxLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:remove org.apache.wicket.ajax.markup.html.AjaxLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm org.apache.wicket.markup.html.form.Form
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLRoleServiceConfig@anonymised.com]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[adminRoleName]]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML role service]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[adminRoleName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:2:component org.apache.wicket.markup.html.basic.Label [ADMIN]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLRoleServiceConfig@anonymised.com]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[adminRoleName]]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [test]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [test]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [test]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML role service]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[adminRoleName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:2:component org.apache.wicket.markup.html.basic.Label
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[adminRoleName]]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[adminRoleName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:2:header org.apache.wicket.markup.html.panel.Fragment
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:2:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[adminRoleName]]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:2:header:link:label org.apache.wicket.markup.html.basic.Label [Administrator Role]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:feedback org.apache.wicket.markup.html.panel.FeedbackPanel
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:dialog org.geoserver.web.wicket.GeoServerDialog
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
14 Oct 14:32:01 INFO [tester.BaseWicketTester] - path panel:panel:roleServicesHelp org.geoserver.web.wicket.HelpLink
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.512s]
[INFO] Core Platform Module .............................. SUCCESS [4.210s]
[INFO] Open Web Service Module ........................... SUCCESS [12.592s]
[INFO] Main Module ....................................... SUCCESS [2:10.264s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:09.171s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.391s]
[INFO] Web Map Service Module ............................ SUCCESS [3:31.921s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.475s]
[INFO] Core UI Module .................................... SUCCESS [1:35.815s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [50.176s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:00.690s]
[INFO] KML support for GeoServer ......................... FAILURE [1:00.193s]
[INFO] REST Support Module ............................... SUCCESS [29.377s]
[INFO] WFS UI Module ..................................... SUCCESS [32.332s]
[INFO] Community Space ................................... SUCCESS [0.219s]
[INFO] Printing Module ................................... SUCCESS [24.208s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.517s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.180s]
[INFO] Application Schema Support ........................ SUCCESS [0.151s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.755s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [25.708s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.292s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.080s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.900s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.593s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.603s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.188s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.697s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [28.868s]
[INFO] Excel Output Format ............................... SUCCESS [30.614s]
[INFO] Validation Module ................................. SUCCESS [3.194s]
[INFO] Chart external graphics support ................... SUCCESS [1.481s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.798s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.093s]
[INFO] OWS request flow controller ....................... SUCCESS [17.305s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.279s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:04.338s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [40.183s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.174s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.455s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [27.174s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.263s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [19.916s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [21.027s]
[INFO] Total time: 14:21.959s (Wall Clock)
[INFO] Finished at: Mon Oct 14 14:32:01 UTC 2013
[INFO] Final Memory: 52M/198M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/20/changes&gt;
Changes:
[planablediglet] GEOS-6086 remove WfsDispatcher from describelayer
[jdeolive] Factored out web secrity modules, GEOS-5972. Backport of #357.
[jdeolive] GEOS-6077 Create an endpoint for webapps to authenticate against
[jdeolive] fixing version numbers for backported security web module changes
[...truncated 20247 lines...]
testOutputModeVector(org.geoserver.kml.KMLTest) Time elapsed: 35 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[1]> but was:<[0]>
  at junit.framework.Assert.assertEquals(Assert.java:100)
  at junit.framework.Assert.assertEquals(Assert.java:107)
  at org.custommonkey.xmlunit.XMLAssert.assertXpathEvaluatesTo(XMLAssert.java:858)
  at org.geoserver.kml.KMLTest.testOutputModeVector(KMLTest.java:428)
Running org.geoserver.kml.KMLWFSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.316 sec
Running org.geoserver.wps.gs.CountProcessTest
14 Oct 17:32:13 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.146 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.515 sec
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.242 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.018 sec
14 Oct 17:32:16 ERROR [image.test] - perceptualdiff is not available, can't compare target/expected.png with image2
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.593 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.207 sec
Results :
Tests in error:
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping GeoServer CAS Security Module
Point2D.Double[0.0, 250.0]
Point2D.Double[10.0, 265.0]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.605 sec
Running org.geoserver.wps.gs.CropCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.815 sec
Running org.geoserver.wps.gs.GeorectifyCoverageTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.070s]
[INFO] Core Platform Module .............................. SUCCESS [4.141s]
[INFO] Open Web Service Module ........................... SUCCESS [13.118s]
[INFO] Main Module ....................................... SUCCESS [2:14.983s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:13.734s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.276s]
[INFO] Web Map Service Module ............................ SUCCESS [3:40.374s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.470s]
[INFO] Core UI Module .................................... SUCCESS [1:38.982s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.216s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [52.813s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:02.472s]
[INFO] KML support for GeoServer ......................... FAILURE [1:07.513s]
[INFO] REST Support Module ............................... SUCCESS [29.093s]
[INFO] WFS UI Module ..................................... SUCCESS [32.007s]
[INFO] Security UI Modules ............................... SUCCESS [0.443s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.252s]
[INFO] Printing Module ................................... SUCCESS [24.015s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.095s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.143s]
[INFO] Application Schema Support ........................ SUCCESS [0.138s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.453s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [25.732s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.278s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.829s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.883s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.499s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.167s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.225s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.586s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [29.498s]
[INFO] Excel Output Format ............................... SUCCESS [32.986s]
[INFO] Validation Module ................................. SUCCESS [2.519s]
[INFO] Chart external graphics support ................... SUCCESS [1.344s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.463s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.953s]
[INFO] OWS request flow controller ....................... SUCCESS [17.864s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.150s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [39.262s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.433s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.642s]
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [25.950s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.246s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [18.440s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [19.821s]
[INFO] Total time: 12:43.646s (Wall Clock)
[INFO] Finished at: Mon Oct 14 17:32:21 UTC 2013
[INFO] Final Memory: 53M/204M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/21/changes&gt;
