See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/197/changes>
Changes:
[andrea.aime] Fix-GEOS-6114 (tests and minor fixes by Andrea Aime)
[andrea.aime] [GEOS-6413] The new KML encoder can leak unclosed feature iterators
[...truncated 5271 lines...]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path devButtons:clearCache org.apache.wicket.extensions.ajax.markup.html.IndicatingAjaxLink
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path devButtons:reload org.apache.wicket.extensions.ajax.markup.html.IndicatingAjaxLink
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path devButtons:wicketPaths org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [false]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path devButtons:xhtml org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [null]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path devButtons:wicketIds org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [true]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path devButtons:ajaxDebug org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [false]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path category org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.Category@anonymised.com]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path category:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path category:0:category.header org.apache.wicket.markup.html.basic.Label [About & Status]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path category:0:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path category:0:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [About GeoServer]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path standalone org.apache.wicket.markup.html.list.ListView []
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path feedback org.apache.wicket.markup.html.panel.FeedbackPanel
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView [[[FeedbackMessage message = "Field 'Workspace' is required.", reporter = paramValue, level = ERROR], [FeedbackMessage message = "Field 'Data Source Name' is required.", reporter = paramValue, level = ERROR]]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:0 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = "Field 'Workspace' is required.", reporter = paramValue, level = ERROR]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:0:message org.apache.wicket.markup.html.basic.Label [Field 'Workspace' is required.]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:1 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = "Field 'Data Source Name' is required.", reporter = paramValue, level = ERROR]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages:1:message org.apache.wicket.markup.html.basic.Label [Field 'Data Source Name' is required.]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path ajaxFeedbackImage org.apache.wicket.markup.html.image.Image
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path headerPanel org.apache.wicket.markup.html.WebMarkupContainer
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path gbpTitle org.apache.wicket.markup.html.basic.Label [Edit Vector Data Source]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path gbpDescription org.apache.wicket.markup.html.basic.Label [Edit an existing vector data source]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dialog org.geoserver.web.wicket.GeoServerDialog
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm org.apache.wicket.markup.html.form.Form [DataStoreInfoImpl[cite]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:storeType org.apache.wicket.markup.html.basic.Label [Properties]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:storeTypeDescription org.apache.wicket.markup.html.basic.Label [Allows access to Java Property files containing Feature information]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel org.geoserver.web.data.store.panel.WorkspacePanel [WorkspaceInfoImpl[cite]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:paramName org.apache.wicket.markup.html.basic.Label [Workspace *]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:border org.apache.wicket.markup.html.form.validation.FormComponentFeedbackBorder [No get method defined for class: class $Proxy19 expression: border]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:border:_body org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: _body]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:border:errorIndicator org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: errorIndicator]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:workspacePanel:border:paramValue org.apache.wicket.markup.html.form.DropDownChoice [WorkspaceInfoImpl[cite]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel org.geoserver.web.data.store.panel.TextParamPanel [cite]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:paramName org.apache.wicket.markup.html.basic.Label [Data Source Name *]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:border org.apache.wicket.markup.html.form.validation.FormComponentFeedbackBorder [No get method defined for class: class $Proxy19 expression: border]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:border:_body org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: _body]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:border:errorIndicator org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: errorIndicator]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreNamePanel:border:paramValue org.apache.wicket.markup.html.form.TextField [cite]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel org.geoserver.web.data.store.panel.TextParamPanel
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:paramName org.apache.wicket.markup.html.basic.Label [Description]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:border org.apache.wicket.markup.html.form.validation.FormComponentFeedbackBorder [No get method defined for class: class $Proxy19 expression: border]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:border:_body org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: _body]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:border:errorIndicator org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: errorIndicator]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreDescriptionPanel:border:paramValue org.apache.wicket.markup.html.form.TextField
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreEnabledPanel org.geoserver.web.data.store.panel.CheckBoxParamPanel [true]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreEnabledPanel:paramName org.apache.wicket.markup.html.basic.Label [Enabled]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:dataStoreEnabledPanel:paramValue org.apache.wicket.markup.html.form.CheckBox [true]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel org.geoserver.web.data.store.DefaultDataStoreEditPanel [No get method defined for class: class $Proxy19 expression: parametersPanel]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters org.apache.wicket.markup.html.list.ListView [[directory, namespace]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0 org.apache.wicket.markup.html.list.ListItem [directory]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel org.geoserver.web.data.store.panel.TextParamPanel [./target/default3905459752937293997data/cite]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:paramName org.apache.wicket.markup.html.basic.Label [directory *]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:border org.apache.wicket.markup.html.form.validation.FormComponentFeedbackBorder [No get method defined for class: class $Proxy19 expression: border]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:border:_body org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: _body]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:border:errorIndicator org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: errorIndicator]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:0:parameterPanel:border:paramValue org.apache.wicket.markup.html.form.TextField [./target/default3905459752937293997data/cite]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:1 org.apache.wicket.markup.html.list.ListItem [namespace]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:1:parameterPanel org.geoserver.web.data.store.panel.NamespacePanel [NamespaceInfoImpl[cite:http://www.opengis.net/cite\]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:1:parameterPanel:paramName org.apache.wicket.markup.html.basic.Label [Namespace *]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:parametersPanel:parameters:1:parameterPanel:paramValue org.apache.wicket.markup.html.basic.Label [http://www.opengis.net/cite\]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback org.apache.wicket.markup.html.panel.FeedbackPanel [No get method defined for class: class $Proxy19 expression: feedback]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class $Proxy19 expression: feedbackul]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView [[[FeedbackMessage message = "Field 'Workspace' is required.", reporter = paramValue, level = ERROR], [FeedbackMessage message = "Field 'Data Source Name' is required.", reporter = paramValue, level = ERROR]]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages:0 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = "Field 'Workspace' is required.", reporter = paramValue, level = ERROR]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages:0:message org.apache.wicket.markup.html.basic.Label [Field 'Workspace' is required.]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages:1 org.apache.wicket.markup.html.list.ListItem [[FeedbackMessage message = "Field 'Data Source Name' is required.", reporter = paramValue, level = ERROR]]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:feedback:feedbackul:messages:1:message org.apache.wicket.markup.html.basic.Label [Field 'Data Source Name' is required.]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:cancel org.apache.wicket.markup.html.link.BookmarkablePageLink [No get method defined for class: class $Proxy19 expression: cancel]
24 Mar 14:23:03 INFO [tester.BaseWicketTester] - path dataStoreForm:save org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink [No get method defined for class: class $Proxy19 expression: save]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.493 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
24 Mar 14:23:04 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not locate {http://www.opengis.net/cite/data\}Locks in catalog.
at org.geoserver.wfs.GetFeature.featureTypeInfo(GetFeature.java:1073)
at org.geoserver.wfs.GetFeature.run(GetFeature.java:331)
at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:121)
at org.geoserver.wfs.DefaultWebFeatureService.getFeatureWithLock(DefaultWebFeatureService.java:135)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy24.getFeatureWithLock(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1367)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1131)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1066)
at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1046)
at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1316)
at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1299)
at org.geoserver.wfs.GetFeatureWithLockTest.testLayerQualified(GetFeatureWithLockTest.java:329)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.266 sec
Running org.geoserver.web.data.store.NewDataPageTest
24 Mar 14:23:06 ERROR [geoserver.wfs] - Transaction failed
org.geoserver.wfs.WFSTransactionException: Update error: Transaction does not have authorization for Locks:Locks.0
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:253)
at org.geoserver.wfs.Transaction.execute(Transaction.java:321)
at org.geoserver.wfs.Transaction.transaction(Transaction.java:105)
at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:170)
at $Proxy24.transaction(Unknown Source)
at org.geoserver.wfs.GetFeatureWithLockTest.testUpdateLockedFeatureWithoutLockId(GetFeatureWithLockTest.java:139)
Caused by: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
at org.geotools.data.InProcessLockingManager.assertAccess(InProcessLockingManager.java:287)
at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:334)
at org.geotools.data.FilteringFeatureWriter.write(FilteringFeatureWriter.java:108)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:204)
at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:130)
at org.vfny.geoserver.global.GeoServerFeatureStore.modifyFeatures(GeoServerFeatureStore.java:182)
at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:247)
... 74 more
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.53 sec
Running org.geoserver.web.data.store.ShapefileDirectoryStorePageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.04 sec
Running org.geoserver.wfs.LockFeatureTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.312 sec
Running org.geoserver.web.data.store.StoreModelTest
