See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/244/>
[...truncated 74721 lines...]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.4-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.4-SNAPSHOT/imagemosaic-jdbc-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.4-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.4-SNAPSHOT/imagemosaic-jdbc-2.4-SNAPSHOT-tests.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/extension/imagemosaic-jdbc/2.4-SNAPSHOT/imagemosaic-jdbc-2.4-SNAPSHOT.jar
2018/?
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:imagemosaic-jdbc'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:imagemosaic-jdbc:2.4-SNAPSHOT'
[INFO] Uploading project information for imagemosaic-jdbc 2.4-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/imagemosaic-jdbc/2.4-SNAPSHOT/imagemosaic-jdbc-2.4-SNAPSHOT-tests.jar
2018/?
[INFO] Building OWS request flow controller
[INFO] task-segment: [deploy]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5545] Two different SLD's that seem to be connected
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.06.2014 @ 09:23:43 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-Jun-2014 23:28
[INFO] [GitCommitIdMojo] build.build.time = 12.06.2014 @ 23:33:37 UTC
[INFO] [GitCommitIdMojo] build.branch = ff271d60bfc4fa9357e076b9b9bee7e4ae4b2212
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = ff271d6
[INFO] [GitCommitIdMojo] build.commit.id = ff271d60bfc4fa9357e076b9b9bee7e4ae4b2212
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5545] Two different SLD's that seem to be connected
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/control-flow/src/main/resources>
Downloading: http://repo.opengeo.org//org/geotools/gt-render/10-SNAPSHOT/gt-render-10-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-imagemosaic/10-SNAPSHOT/gt-imagemosaic-10-SNAPSHOT.jar
[INFO] Nothing to compile - all classes are up to date
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/control-flow/src/test/resources>
[INFO] Tests are skipped.
[INFO] Preparing source:jar
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-test-sources.jar
Uploading: http://repo.opengeo.org/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24566/?
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:control-flow'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:control-flow:2.4-SNAPSHOT'
[INFO] Uploading project information for control-flow 2.4-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-tests.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
24876/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-sources.jar
4096/?
8192/?
12288/?
16384/?
17448/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-test-sources.jar
4096/?
8192/?
12288/?
12974/?
[INFO] Building Web Processing Service parent
[INFO] [GitCommitIdMojo] build.build.time = 12.06.2014 @ 23:33:40 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/wps/2.4-SNAPSHOT/wps-2.4-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/wps/target/wps-2.4-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/wps/2.4-SNAPSHOT/wps-2.4-SNAPSHOT-tests.jar
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps/2.4-SNAPSHOT/wps-2.4-SNAPSHOT.pom
889/?
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:wps:2.4-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:wps'
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps/2.4-SNAPSHOT/wps-2.4-SNAPSHOT-tests.jar
1921/?
[INFO] Building Web Processing Service Module
[INFO] [GitCommitIdMojo] build.build.time = 12.06.2014 @ 23:33:42 UTC
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from jaitools-snapshots
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '780ba3cf6b6eb0f7c9f6d41d8d25a86a2f46b0c4'; remote = '<html>
<head><title>301' - RETRYING
<head><title>301' - IGNORING
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from osgeo
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools.ogc:net.opengis.wps
Reason: Error getting POM for 'org.geotools.ogc:net.opengis.wps' from the repository: Unable to read local copy of metadata: Cannot read metadata from '/var/lib/jenkins/.m2/repository/org/geotools/ogc/net.opengis.wps/10-SNAPSHOT/maven-metadata-jaitools-snapshots.xml': end tag name </body> must match start tag name <hr> from line 5 (position: TEXT seen ...</center>\r\n</body>... @6:8)
org.geotools.ogc:net.opengis.wps:pom:10-SNAPSHOT
for project org.geotools.ogc:net.opengis.wps
[INFO] Total time: 4 minutes 55 seconds
[INFO] Finished at: Thu Jun 12 23:33:42 UTC 2014
[INFO] Final Memory: 98M/426M
