See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/274/changes>
Changes:
[jdeolive] Fixing links to old website
Started by an SCM change
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/>
Checkout:geoserver-2.4.x / <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/> - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision eefe3039263e7f5ebdd749606e2ff5e058b1596d (origin/2.4.x)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
Commencing build of Revision ed7f913855a8491794ec7d3ed581c4648910fc04 (origin/2.4.x)
Checking out Revision ed7f913855a8491794ec7d3ed581c4648910fc04 (origin/2.4.x)
[geoserver-2.4.x] $ /opt/apache-maven-3.0.4/bin/mvn -f src/pom.xml -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,proxy,printing,secJdbcJndiTest clean install -DconfigDirectory=../../../data -T2
[INFO] Scanning for projects...
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:wps-core:jar:2.4-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:wps-core:${gs.version}, <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/wps/wps-core/pom.xml,> line 21, column 14
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:web-wps:jar:2.4-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:web-wps:${gs.version}, <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/extension/wps/web-wps/pom.xml,> line 21, column 14
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Modules
[INFO] Security UI Core Module
[INFO] Security UI JDBC Module
[INFO] Security UI LDAP Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF parent module
[INFO] DXF output format
[INFO] DXF WPS PPIO
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] Building with 2 threads
[INFO]
[INFO] Building GeoServer 2.4-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.pom
[WARNING] The POM for org.geotools:gt-api:jar:10-SNAPSHOT is missing, no dependency information available
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.pom
[WARNING] The POM for org.geotools:gt-main:jar:10-SNAPSHOT is missing, no dependency information available
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.jar
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [1.333s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF parent module ................................. SKIPPED
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8.539s (Wall Clock)
[INFO] Finished at: Sat Aug 16 15:18:03 UTC 2014
[INFO] Final Memory: 23M/184M
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.4-SNAPSHOT: The following artifacts could not be resolved: org.geotools:gt-api:jar:10-SNAPSHOT, org.geotools:gt-main:jar:10-SNAPSHOT: Could not find artifact org.geotools:gt-api:jar:10-SNAPSHOT in boundless (http://repo.boundlessgeo.com/main) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
