See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/30/changes>
Changes:
[smithkm] Backport JDBCConfig fixes and improvements: #308, #329, #335, #350, #369
[...truncated 19042 lines...]
26 Oct 03:07:55 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer lakes_and_places
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1252)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:218)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:80)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:934)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:917)
at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:902)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1228)
at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1163)
at org.geoserver.wms.wms_1_3.GetMapIntegrationTest.testLayerGroupContainer(GetMapIntegrationTest.java:315)
org.geoserver.platform.ServiceException: Found multiple, inconsistent values for parameter FORMAT: [image/png, image/jpeg]
at org.geoserver.ows.KvpRequestReader.read(KvpRequestReader.java:183)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:172)
at org.geoserver.wms.wms_1_3.GetMapIntegrationTest.testRepeatedValues(GetMapIntegrationTest.java:185)
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.939 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.069 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.954 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.96 sec
Results :
Failed tests: testGroupWorkspaceQualified(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest): expected:<[image/png]> but was:<[text/xml]>
Tests in error:
testBlueLake(org.geoserver.wms.map.GIFMapResponseTest): Rendering process failed
testBlueLake(org.geoserver.wms.map.RenderedImageMapOutputFormatTest): Rendering process failed
Tests run: 539, Failures: 1, Errors: 2, Skipped: 0
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.233s]
[INFO] Core Platform Module .............................. SUCCESS [5.074s]
[INFO] Open Web Service Module ........................... SUCCESS [14.442s]
[INFO] Main Module ....................................... SUCCESS [2:09.200s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:04.490s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.583s]
[INFO] Web Map Service Module ............................ FAILURE [3:28.452s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.654s]
[INFO] Core UI Module .................................... SUCCESS [1:36.662s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:01.693s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:02.356s]
[INFO] REST Support Module ............................... SUCCESS [31.603s]
[INFO] WFS UI Module ..................................... SUCCESS [32.310s]
[INFO] Security UI Modules ............................... SUCCESS [0.551s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.616s]
[INFO] Printing Module ................................... SUCCESS [23.750s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [5.933s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.241s]
[INFO] Application Schema Support ........................ SUCCESS [0.286s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.448s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [24.050s]
[INFO] H2 DataStore Extension ............................ SUCCESS [20.488s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.096s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.362s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.615s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.529s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.281s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.895s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [29.979s]
[INFO] Excel Output Format ............................... SUCCESS [32.881s]
[INFO] Validation Module ................................. SUCCESS [3.219s]
[INFO] Chart external graphics support ................... SUCCESS [3.217s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.484s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.844s]
[INFO] OWS request flow controller ....................... SUCCESS [17.786s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.248s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [41.233s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.259s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [30.694s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.583s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [19.038s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:05.940s (Wall Clock)
[INFO] Finished at: Sat Oct 26 03:08:06 UTC 2013
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 27.353 sec
Running org.geoserver.wps.ExecuteTest
[INFO] Final Memory: 47M/179M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :wms
