See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/199/>
[...truncated 5753 lines...]
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/target>
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6422] Several exceptions logged after import due to non serializable classes referenced by Import pages
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 30.03.2014 @ 14:47:57 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 02-Apr-2014 03:25
[INFO] [GitCommitIdMojo] build.build.time = 02.04.2014 @ 03:32:45 UTC
[INFO] [GitCommitIdMojo] build.branch = 81b08ff114cce27061b17d495abd6d2529827a60
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 81b08ff
[INFO] [GitCommitIdMojo] build.commit.id = 81b08ff114cce27061b17d495abd6d2529827a60
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6422] Several exceptions logged after import due to non serializable classes referenced by Import pages
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/src/main/resources>
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:10-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/src/test/resources>
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.4-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.4-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/target/dependency/gwc-core-1.5.0.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.4-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.4-SNAPSHOT/imagemosaic-jdbc-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.4-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.4-SNAPSHOT/imagemosaic-jdbc-2.4-SNAPSHOT-tests.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target>
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/src/main/resources>
[INFO] Compiling 14 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/src/test/resources>
[INFO] Compiling 11 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/test-classes>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/dependency/gwc-core-1.5.0.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/control-flow/target/control-flow-2.4-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/control-flow/2.4-SNAPSHOT/control-flow-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/wps/target>
[INFO] [GitCommitIdMojo] build.build.time = 02.04.2014 @ 03:32:49 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/wps/target/wps-2.4-SNAPSHOT-tests.jar>
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/wps/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5.0.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/wps/target/dependency/gwc-core-1.5.0.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/wps/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/wps/2.4-SNAPSHOT/wps-2.4-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/wps/target/wps-2.4-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/wps/2.4-SNAPSHOT/wps-2.4-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/wps/wps-core/target>
[INFO] [GitCommitIdMojo] build.build.time = 02.04.2014 @ 03:32:50 UTC
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from jaitools-snapshots
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'ef3dc2ec718a24931364e81249c0933d3d0cc682'; remote = '<html>
<head><title>301' - RETRYING
<head><title>301' - IGNORING
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:10-SNAPSHOT: checking for updates from osgeo
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools.ogc:net.opengis.wps
Reason: Error getting POM for 'org.geotools.ogc:net.opengis.wps' from the repository: Unable to read local copy of metadata: Cannot read metadata from '/var/lib/jenkins/.m2/repository/org/geotools/ogc/net.opengis.wps/10-SNAPSHOT/maven-metadata-jaitools-snapshots.xml': end tag name </body> must match start tag name <hr> from line 5 (position: TEXT seen ...</center>\r\n</body>... @6:8)
org.geotools.ogc:net.opengis.wps:pom:10-SNAPSHOT
for project org.geotools.ogc:net.opengis.wps
[INFO] Total time: 7 minutes 22 seconds
[INFO] Finished at: Wed Apr 02 03:32:51 UTC 2014
[INFO] Final Memory: 136M/493M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-04-02-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
