[Geoserver-devel] Build failed in Jenkins: geoserver-2.4.x-nightly #335
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/335/&gt;
[...truncated 2818 lines...]
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Updated repository settings for new boundless maven repo.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 13.08.2014 @ 17:10:47 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Aug-2014 03:42
[INFO] [GitCommitIdMojo] build.build.time = 16.08.2014 @ 03:47:17 UTC
[INFO] [GitCommitIdMojo] build.branch = eefe3039263e7f5ebdd749606e2ff5e058b1596d
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = eefe303
[INFO] [GitCommitIdMojo] build.commit.id = eefe3039263e7f5ebdd749606e2ff5e058b1596d
[INFO] [GitCommitIdMojo] build.commit.message.full = Updated repository settings for new boundless maven repo.
[INFO] Copying 1 resource
[INFO] Copying 2 resources
[INFO] Compiling 26 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/classes&gt;
[INFO] Copying 4 resources
[INFO] Compiling 11 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/script-core-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/script-core-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/script-core-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/script-core-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/dependency/gwc-core-1.5.3.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/script-core-2.4-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/script-core/2.4-SNAPSHOT/script-core-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/script-core-2.4-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/script-core/2.4-SNAPSHOT/script-core-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/script-core-2.4-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/script-core/2.4-SNAPSHOT/script-core-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/core/target/script-core-2.4-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/script/script-core/2.4-SNAPSHOT/script-core-2.4-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Extensions
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 16.08.2014 @ 03:47:23 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/target/extension-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/target/dependency/gwc-core-1.5.3.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/2.4-SNAPSHOT/extension-2.4-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/target/extension-2.4-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/2.4-SNAPSHOT/extension-2.4-SNAPSHOT-tests.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 16.08.2014 @ 03:47:24 UTC
[INFO] Copying 10 resources
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/classes&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/src/test/resources&gt;
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/test-classes&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/h2-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/h2-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/h2-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/h2-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.3.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/dependency/gwc-core-1.5.3.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/h2-2.4-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/h2/2.4-SNAPSHOT/h2-2.4-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/h2-2.4-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/h2/2.4-SNAPSHOT/h2-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/h2-2.4-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/h2/2.4-SNAPSHOT/h2-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/extension/h2/target/h2-2.4-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/h2/2.4-SNAPSHOT/h2-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Python Scripting Extension
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/py/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 16.08.2014 @ 03:47:29 UTC
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/src/community/script/py/src/main/resources&gt;
[INFO] Copying 12 resources
[INFO] snapshot org.geotools.xsd:gt-xsd-kml:10-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools.xsd:gt-xsd-kml:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoscript:geoscript-py:1.4-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geoscript:geoscript-py:1.4-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-mysql:10-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools.jdbc:gt-jdbc-mysql:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-teradata:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.boundlessgeo.com/main/org/geotools/geotools/11-SNAPSHOT/geotools-11-20140816.015223-4.pom
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools:modules:pom:null
Reason: Cannot find parent: org.geotools:geotools for project: org.geotools:modules:pom:null for project org.geotools:modules:pom:null
[INFO] Total time: 5 minutes 29 seconds
[INFO] Finished at: Sat Aug 16 03:47:30 UTC 2014
[INFO] Final Memory: 109M/324M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-08-16-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/336/changes&gt;
Changes:
[jdeolive] Fixing links to old website
Started by timer
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/&gt;
Checkout:geoserver-2.4.x / <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision eefe3039263e7f5ebdd749606e2ff5e058b1596d (origin/2.4.x)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
Commencing build of Revision ed7f913855a8491794ec7d3ed581c4648910fc04 (origin/2.4.x)
Checking out Revision ed7f913855a8491794ec7d3ed581c4648910fc04 (origin/2.4.x)
[geoserver-2.4.x] $ /bin/sh -xe /tmp/hudson1509656337951562884.sh
+ ver=2.4.x
+ dist=/var/www/geoserver/2.4.x
+ date +%Y-%m-%d
+ datestamp=2014-08-17
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=336 -P release,communityRelease clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Modules
[INFO] Security UI Core Module
[INFO] Security UI JDBC Module
[INFO] Security UI LDAP Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] Authentication by unique url key
[INFO] WorldWind Format Module
[INFO] Printing Module
[INFO] NetCDF Coverage format
[INFO] Web Coverage Service 2.0 Module
[INFO] WCS NetCDF output Module
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Scripting Extensions
[INFO] Core Scripting Extension
[INFO] GeoServer Extensions
[INFO] H2 DataStore Extension
[INFO] Python Scripting Extension
[INFO] JavaScript Scripting Extension
[INFO] Groovy Scripting Extension
[INFO] GeoServer JDBC KV Catalog
[INFO] Simple Feature Service
[INFO] Aggregating Data Store
[INFO] WMS-EO
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] Fast pure java PNG output format
[INFO] ColorMap
[INFO] GeoServer Community Release Module
[INFO] SpatiaLite Extension
[INFO] BeanShell Scripting Extension
[INFO] Ruby Scripting Extension
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF parent module
[INFO] DXF output format
[INFO] DXF WPS PPIO
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GeoServer Release Module
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-compiler:2.9.0-01-SNAPSHOT: checking for updates from nexus
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-compiler:2.9.0-01-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-compiler:2.9.0-01-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-compiler:2.9.0-01-SNAPSHOT: checking for updates from osgeo
[INFO] artifact org.codehaus.groovy:groovy-eclipse-batch: checking for updates from nexus
[INFO] artifact org.codehaus.groovy:groovy-eclipse-batch: checking for updates from codehaus.org
[INFO] artifact org.codehaus.groovy:groovy-eclipse-batch: checking for updates from central
[INFO] artifact org.codehaus.groovy:groovy-eclipse-batch: checking for updates from boundless
[INFO] artifact org.codehaus.groovy:groovy-eclipse-batch: checking for updates from osgeo
[INFO] artifact org.codehaus.groovy:groovy-eclipse-batch: checking for updates from maven-restlet
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-batch:2.3.4-01-SNAPSHOT: checking for updates from nexus
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-batch:2.3.4-01-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-batch:2.3.4-01-SNAPSHOT: checking for updates from codehaus.org
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-batch:2.3.4-01-SNAPSHOT: checking for updates from codehaus-snapshots
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-batch:2.3.4-01-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.codehaus.groovy:groovy-eclipse-batch:2.3.4-01-SNAPSHOT: checking for updates from osgeo
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing links to old website
[INFO] [GitCommitIdMojo] build.commit.time = 16.08.2014 @ 13:55:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Aug-2014 03:27
[INFO] [GitCommitIdMojo] build.build.time = 17.08.2014 @ 03:28:09 UTC
[INFO] [GitCommitIdMojo] build.branch = ed7f913855a8491794ec7d3ed581c4648910fc04
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = ed7f913
[INFO] [GitCommitIdMojo] build.commit.id = ed7f913855a8491794ec7d3ed581c4648910fc04
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing links to old website
[INFO] snapshot org.geotools:gt-api:10-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:gt-api:10-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-api:pom:10-SNAPSHOT' in repository boundless (http://repo.boundlessgeo.com/main)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-api:pom:10-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[INFO] snapshot org.geotools:gt-main:10-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:gt-main:10-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-main:pom:10-SNAPSHOT' in repository boundless (http://repo.boundlessgeo.com/main)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-main:pom:10-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-api:jar:10-SNAPSHOT' in repository boundless (http://repo.boundlessgeo.com/main)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-api/10-SNAPSHOT/gt-api-10-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-api:jar:10-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-main:jar:10-SNAPSHOT' in repository boundless (http://repo.boundlessgeo.com/main)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-main/10-SNAPSHOT/gt-main-10-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-main:jar:10-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools:gt-api:jar:10-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geotools -DartifactId=gt-api -Dversion=10-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geotools -DartifactId=gt-api -Dversion=10-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver:geoserver:pom:2.4-SNAPSHOT
    2) org.geotools:gt-api:jar:10-SNAPSHOT
2) org.geotools:gt-main:jar:10-SNAPSHOT
      mvn install:install-file -DgroupId=org.geotools -DartifactId=gt-main -Dversion=10-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
      mvn deploy:deploy-file -DgroupId=org.geotools -DartifactId=gt-main -Dversion=10-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
2 required artifacts are missing.
for artifact:
from the specified remote repositories:
  boundless (http://repo.boundlessgeo.com/main),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org)
[INFO] Total time: 23 seconds
[INFO] Finished at: Sun Aug 17 03:28:11 UTC 2014
[INFO] Final Memory: 53M/226M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.4.x/geoserver-2.4.x-2014-08-17-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.4.x-nightly/337/&gt;
