See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/10/changes>
Changes:
[maurobartolomeoli] GEOS-6362: avoid side effects in SecuredGetMapRequest getFinalURL when called multiple times (for example for fine logging)
[...truncated 77152 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8c10934
[INFO] [GitCommitIdMojo] build.commit.id = 8c10934c8da1361ed7853534f5707e3281f4b389
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #523 from mbarto/25x_6362
[INFO] Copying 0 resource
[INFO] Copying 4 resources
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml3/11-SNAPSHOT/gt-xsd-gml3-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-graph/11-SNAPSHOT/gt-graph-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-wfs/11-SNAPSHOT/gt-xsd-wfs-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-cql/11-SNAPSHOT/gt-cql-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-data/11-SNAPSHOT/gt-data-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc/11-SNAPSHOT/gt-jdbc-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-fes/11-SNAPSHOT/gt-xsd-fes-11-SNAPSHOT.jar
[INFO] Nothing to compile - all classes are up to date
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/core/src/test/resources>
[INFO] Tests are skipped.
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.5-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.5-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.5-SNAPSHOT/gs-dxf-core-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.5-SNAPSHOT/gs-dxf-core-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.5-SNAPSHOT/gs-dxf-core-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.5-SNAPSHOT/gs-dxf-core-2.5-SNAPSHOT-test-sources.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-dxf-core/2.5-SNAPSHOT/gs-dxf-core-2.5-SNAPSHOT.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32601/?
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:gs-dxf-core:2.5-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:gs-dxf-core'
[INFO] Uploading project information for gs-dxf-core 2.5-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-dxf-core/2.5-SNAPSHOT/gs-dxf-core-2.5-SNAPSHOT-tests.jar
4096/?
6310/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-dxf-core/2.5-SNAPSHOT/gs-dxf-core-2.5-SNAPSHOT-sources.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
24793/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-dxf-core/2.5-SNAPSHOT/gs-dxf-core-2.5-SNAPSHOT-test-sources.jar
3619/?
[INFO] Building DXF WPS PPIO
[INFO] task-segment: [deploy]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #523 from mbarto/25x_6362
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 05.03.2014 @ 07:48:58 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 05-Mar-2014 09:52
[INFO] [GitCommitIdMojo] build.build.time = 05.03.2014 @ 10:18:14 UTC
[INFO] [GitCommitIdMojo] build.branch = 8c10934c8da1361ed7853534f5707e3281f4b389
[INFO] Copying 1 resource
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wcs/11-SNAPSHOT/net.opengis.wcs-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wps/11-SNAPSHOT/net.opengis.wps-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/11-SNAPSHOT/gt-arcgrid-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-process/11-SNAPSHOT/gt-process-11-SNAPSHOT.jar
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/wps/src/test/resources>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.5-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.5-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.5-SNAPSHOT/gs-dxf-wps-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.5-SNAPSHOT/gs-dxf-wps-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.5-SNAPSHOT/gs-dxf-wps-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.5-SNAPSHOT/gs-dxf-wps-2.5-SNAPSHOT-test-sources.jar
Uploading: http://repo.opengeo.org/org/geoserver/extension/gs-dxf-wps/2.5-SNAPSHOT/gs-dxf-wps-2.5-SNAPSHOT.jar
4096/?
4436/?
[ERROR] BUILD ERROR
[INFO] Error deploying artifact: Failed to transfer file: http://repo.opengeo.org/org/geoserver/extension/gs-dxf-wps/2.5-SNAPSHOT/gs-dxf-wps-2.5-SNAPSHOT.jar. Return code is: 500 Internal Server Error
[INFO] Total time: 26 minutes 12 seconds
[INFO] Finished at: Wed Mar 05 10:18:44 UTC 2014
[INFO] Final Memory: 108M/313M
