See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/141/changes>
Changes:
[andrea.aime] [GEOS-6395] WMS Animator parameter is misspelled
[...truncated 9000 lines...]
[INFO] Skipping ogr2ogr Output Format
[INFO]
[INFO] Skipping Excel Output Format
[INFO]
[INFO] Skipping GeoServer Layer Querying filter functions
[INFO]
[INFO] Skipping DXF output format
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.409 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-css ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/target/gs-css-2.5-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-css ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/target/gs-css-2.5-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-css >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-css ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6395] WMS Animator parameter is misspelled
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.12.2014 @ 15:20:24 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Dec-2014 16:16
[INFO] [GitCommitIdMojo] build.build.time = 24.12.2014 @ 16:26:44 UTC
[INFO] [GitCommitIdMojo] build.branch = d282cc944c012c127129cbfa12331bb7a3552049
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d282cc9
[INFO] [GitCommitIdMojo] build.commit.id = d282cc944c012c127129cbfa12331bb7a3552049
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6395] WMS Animator parameter is misspelled
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-css <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-css ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/target/gs-css-2.5-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-css >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-css <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-css ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/target/gs-css-2.5-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-css ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/target/gs-css-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-css/2.5-SNAPSHOT/gs-css-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-css/2.5-SNAPSHOT/gs-css-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/target/gs-css-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-css/2.5-SNAPSHOT/gs-css-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/target/gs-css-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-css/2.5-SNAPSHOT/gs-css-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/css/target/gs-css-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-css/2.5-SNAPSHOT/gs-css-2.5-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.200s]
[INFO] Core Platform Module .............................. SUCCESS [4.910s]
[INFO] Open Web Service Module ........................... SUCCESS [15.520s]
[INFO] Main Module ....................................... SUCCESS [2:47.788s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.271s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.496s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [45.870s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.464s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.537s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.450s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [3:41.251s]
[INFO] Web Map Service Module ............................ FAILURE [13.024s]
[INFO] REST Support Module ............................... SUCCESS [37.010s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.559s]
[INFO] Core UI Module .................................... SUCCESS [2:06.533s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.445s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.545s]
[INFO] Printing Module ................................... SUCCESS [18.615s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.833s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.316s]
[INFO] Application Schema Support ........................ SUCCESS [0.322s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [25.221s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.099s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.442s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.952s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.831s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.046s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [6.834s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.630s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [2.546s]
[INFO] Chart external graphics support ................... SUCCESS [1.359s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.561s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.088s]
[INFO] OWS request flow controller ....................... SUCCESS [20.935s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.417s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.426s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [37.270s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.544s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [18.832s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.495s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.515s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:07.287s (Wall Clock)
[INFO] Finished at: Wed Dec 24 16:26:45 UTC 2014
[INFO] Final Memory: 50M/204M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wms: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[143,11\] '{' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[143,29\] ')' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[143,93\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[143,8\] 'try' without 'catch' or 'finally'
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,4\] illegal start of expression
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,12\] illegal start of expression
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,22\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,53\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,54\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,58\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,11\] illegal start of type
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,15\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,35\] illegal start of expression
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,34\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,36\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,44\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,53\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,11\] illegal start of type
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,15\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,40\] illegal start of expression
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,39\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,41\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,49\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,58\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[287,1\] reached end of file while parsing
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
