[Geoserver-devel] Build failed in Jenkins: geoserver-2.5.x #16
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/16/changes&gt;
Changes:
[andrea.aime] Addig a profile to include colormap extension in the build
[...truncated 9827 lines...]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 25.283 sec
Results :
Tests run: 17, Failures: 0, Errors: 0, Skipped: 17
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-ogr ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/target/gs-ogr-2.5-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-ogr ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/target/gs-ogr-2.5-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-ogr >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-ogr ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Addig a profile to include colormap extension in the build
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 11.03.2014 @ 15:58:28 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-Mar-2014 16:19
[INFO] [GitCommitIdMojo] build.build.time = 11.03.2014 @ 16:31:19 UTC
[INFO] [GitCommitIdMojo] build.branch = 749e144e0cd76457210086eb7064bba937ffcb74
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 749e144
[INFO] [GitCommitIdMojo] build.commit.id = 749e144e0cd76457210086eb7064bba937ffcb74
[INFO] [GitCommitIdMojo] build.commit.message.full = Addig a profile to include colormap extension in the build
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-ogr <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-ogr ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/target/gs-ogr-2.5-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ogr >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ogr <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-ogr ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/target/gs-ogr-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-ogr ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/target/gs-ogr-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr/2.5-SNAPSHOT/gs-ogr-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr/2.5-SNAPSHOT/gs-ogr-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/target/gs-ogr-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr/2.5-SNAPSHOT/gs-ogr-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/target/gs-ogr-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr/2.5-SNAPSHOT/gs-ogr-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/ogr/target/gs-ogr-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-ogr/2.5-SNAPSHOT/gs-ogr-2.5-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Excel Output Format 2.5-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Excel Output Format:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://snapshots.repository.codehaus.org/org/geotools/ogc/net.opengis.wfs/11-SNAPSHOT/maven-metadata.xml
Tests run: 32, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.459 sec
Running org.geoserver.wms.featureinfo.HTMLFeatureInfoOutputFormatTest
Downloading: http://snapshots.repository.codehaus.org/org/geotools/ogc/org.w3.xlink/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/ogc/net.opengis.fes/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/xsd/gt-xsd-wfs/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/xsd/gt-xsd-fes/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/xsd/gt-xsd-ows/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/xsd/gt-xsd-filter/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/xsd/gt-xsd-core/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/xsd/gt-xsd-gml2/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/xsd/gt-xsd-gml3/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-shapefile/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/ogc/net.opengis.ows/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-validation/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-graph/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-data/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-jdbc/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-property/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-epsg-hsql/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-wms/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-xml/11-SNAPSHOT/maven-metadata.xml
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.119 sec
Running org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest
Downloading: http://snapshots.repository.codehaus.org/org/geotools/xsd/gt-xsd-sld/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-imagemosaic/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-geotiff/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-transform/11-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/geotools/gt-image/11-SNAPSHOT/maven-metadata.xml
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-excel ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/excel/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-excel ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-excel ---
[INFO] [GitCommitIdMojo] build.build.time = 11.03.2014 @ 16:31:22 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-excel ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-excel ---
[INFO] Compiling 4 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/excel/target/classes&gt;
Query:
   feature type: Bridges
   filter: [ the_geom intersects POLYGON ((0.00019952 0.0006988, 0.00020032 0.0006988, 0.00020032 0.0006996, 0.00019952 0.0006996, 0.00019952 0.0006988)) ]
   [properties: ALL ]
Query:
   filter: [ the_geom intersects POLYGON ((0.0001968 0.0006942, 0.0002032 0.0006942, 0.0002032 0.0007006, 0.0001968 0.0007006, 0.0001968 0.0006942)) ]
   [properties: ALL ]
Query:
   filter: [ the_geom intersects POLYGON ((0.00019872 0.0006976, 0.00020112 0.0006976, 0.00020112 0.0007, 0.00019872 0.0007, 0.00019872 0.0006976)) ]
   [properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.803 sec
Running org.geoserver.wms.georss.AtomGeoRSSTransformerTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-excel ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/excel/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-excel ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/excel/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-excel ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/excel/target/surefire-reports&gt;
T E S T S
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.316 sec
Running org.geoserver.wms.georss.RSSGeoRSSTransformerTest
Running org.geoserver.wfs.response.ExcelOutputFormatTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.603 sec
Running org.geoserver.wms.legendgraphic.AbstractLegendGraphicOutputFormatTest
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.182 sec
Running org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReaderTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.685 sec
Running org.geoserver.wms.map.GIFMapResponseTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.744 sec
Running org.geoserver.wms.map.GetMapIntegrationTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.962 sec
Running org.geoserver.wms.map.GetMapKvpRequestReaderTest
Tests run: 22, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.718 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.131 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.678 sec
Running org.geoserver.wms.map.RawMapTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.395 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.965 sec
Running org.geoserver.wms.map.png.BufferedImageChildTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.wms.map.png.BufferedImageTypesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.136 sec
Running org.geoserver.wms.map.png.CustomByteIndexImageTypesTest
Tests run: 520, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.349 sec
Running org.geoserver.wms.map.png.CustomUShortImageTypesTest
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/17/changes&gt;
