[Geoserver-devel] Build failed in Jenkins: geoserver-2.5.x #26
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/26/changes&gt;
Changes:
[andrea.aime] Fix-GEOS-6114 (tests and minor fixes by Andrea Aime)
[...truncated 3506 lines...]
Running org.geoserver.security.KeyStoreProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.256 sec
Running org.geoserver.security.MigrateFrom_2_2_Test
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.038 sec
Running org.geoserver.security.auth.AuthenticationCacheFilterTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.636 sec
Running org.geoserver.security.auth.AuthenticationFilterTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.549 sec
Running org.geoserver.security.auth.GeoServerRootAuthenticationProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.168 sec
Running org.geoserver.security.auth.LRUAuthenticationCacheTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.525 sec
Running org.geoserver.security.decorators.DecoratingWMSLayerInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.decorators.ReadSecuredCatalogDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.geoserver.security.decorators.SecuredFeatureCollectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.security.decorators.SecuredFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.decorators.SecuredGetMapRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.file.FileTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.106 sec
Running org.geoserver.security.filter.GeoServerBasicAuthenticationFilterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.geoserver.security.impl.AdvertisedCatalogTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.security.impl.DataAccessRuleDAOTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.security.impl.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.1 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.025 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.356 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.776 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.048 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.958 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.722 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.687 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.958 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.468 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.security.validation.PasswordValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.035 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.171 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.361 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.412 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.808 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.298 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.175 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.206 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.037 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.828 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.83 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.097 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.079 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.064 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.883 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.063 sec
Results :
Tests in error:
  testRemoveUserInGroup(org.geoserver.security.GroupAdminServiceTest)
Tests run: 561, Failures: 0, Errors: 1, Skipped: 1
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.253s]
[INFO] Core Platform Module .............................. SUCCESS [4.136s]
[INFO] Open Web Service Module ........................... SUCCESS [12.789s]
[INFO] Main Module ....................................... FAILURE [2:24.959s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.517s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.266s]
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.226s]
[INFO] Application Schema Support ........................ SUCCESS [0.257s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.357s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.690s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.585s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.435s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.219s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.574s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.903s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.932s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.354s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.215s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.275s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 2:51.183s (Wall Clock)
[INFO] Finished at: Sat Mar 22 15:12:46 UTC 2014
[INFO] Final Memory: 37M/196M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/27/&gt;
[...truncated 4123 lines...]
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 12e0d70
[INFO] [GitCommitIdMojo] build.commit.id = 12e0d706ff121999ee95b53ddc8972758af0ee42
[INFO] [GitCommitIdMojo] build.commit.message.full = Fix-GEOS-6114 (tests and minor fixes by Andrea Aime)
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/rest/target/gs-rest-2.5-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-rest ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fix-GEOS-6114 (tests and minor fixes by Andrea Aime)
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.03.2014 @ 13:58:17 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Mar-2014 09:30
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 09:34:33 UTC
[INFO] [GitCommitIdMojo] build.branch = 12e0d706ff121999ee95b53ddc8972758af0ee42
[INFO] [GitCommitIdMojo] build.commit.user.email = srivani.vuppala@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = svuppala
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/rest/target/gs-rest-2.5-SNAPSHOT-test-sources.jar&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 28.657 sec
Running org.geoserver.wfs.DescribeFeatureTest
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/rest/target/gs-rest-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.5-SNAPSHOT/gs-rest-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.5-SNAPSHOT/gs-rest-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/rest/target/gs-rest-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.5-SNAPSHOT/gs-rest-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/rest/target/gs-rest-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.5-SNAPSHOT/gs-rest-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/rest/target/gs-rest-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.5-SNAPSHOT/gs-rest-2.5-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Core UI Module 2.5-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Core UI Module:
[WARNING] org.apache.maven.plugins:maven-antrun-plugin:1.3
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/web/core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-web-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-core ---
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 09:34:34 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-core ---
[INFO] Copying 12 resources
[INFO] Copying 372 resources
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (process-resources) @ gs-web-core ---
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-core ---
[INFO] Compiling 227 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/web/core/target/classes&gt;
sf
cdf
cgf
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.368 sec
Running org.geoserver.wfs.ExternalEntitiesTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-core ---
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/web/core/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-core ---
[INFO] Compiling 56 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/web/core/target/test-classes&gt;
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="2.0.0" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd&quot;&gt;
  <ows:Exception exceptionCode="OperationParsingFailed">
    <ows:ExceptionText>Request parsing failed
null</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.242 sec
Running org.geoserver.wfs.GeometrylessTest
<wfs:GetFeature service="WFS" xmlns:wfs="http://www.opengis.net/wfs&quot; version="1.0.0" outputFormat="GML2" xmlns:topp="http://www.openplans.org/topp&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd&quot;&gt;&lt;wfs:Query typeName="cite:Geometryless" srsName="EPSG:900913"/></wfs:GetFeature>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.9 sec
Running org.geoserver.wfs.GeometrylessWriteTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/web/core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.CapabilitiesHomePagePanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.729 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.62 sec
Running org.geoserver.wfs.GetFeatureBboxTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.61 sec
Running org.geoserver.wfs.GetFeatureHitsIgnoreMaxFeaturesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.362 sec
Running org.geoserver.wfs.GetFeatureMissingTypesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.698 sec
Running org.geoserver.wfs.GetFeaturePagingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.505 sec
Running org.geoserver.web.ConverterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.779 sec
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.607 sec
Running org.geoserver.web.GeoServerConsoleFlagTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.324 sec
Running org.geoserver.wfs.GetFeatureTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.064 sec
Running org.geoserver.wfs.GetFeatureWithLockTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.514 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.571 sec
Running org.geoserver.wfs.LockFeatureTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.768 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.792 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.798 sec
Running org.geoserver.web.admin.AdminPrivilegeTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.667 sec
Running org.geoserver.wfs.NumDecimalsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.996 sec
Running org.geoserver.wfs.ReprojectionTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.999 sec
Running org.geoserver.web.admin.ContactPageTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.195 sec
Running org.geoserver.wfs.ReprojectionWriteTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.917 sec
Running org.geoserver.web.admin.CoverageAccessPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.964 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.285 sec
Running org.geoserver.wfs.ResourceAccessManagerWFSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.617 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.491 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.878 sec
Running org.geoserver.web.data.ConfirmRemovalPanelTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.42 sec
Running org.geoserver.wfs.RetypingTransactionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.617 sec
Running org.geoserver.web.data.layer.LayerPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.699 sec
Running org.geoserver.wfs.SQLViewTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.914 sec
Running org.geoserver.web.data.layer.NewLayerPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.433 sec
Running org.geoserver.wfs.SecuredGetFeatureTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.417 sec
Running org.geoserver.web.data.layergroup.LayerGroupEditPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.767 sec
Running org.geoserver.wfs.SrsNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.522 sec
Running org.geoserver.web.data.layergroup.LayerGroupNewPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.369 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.635 sec
Running org.geoserver.web.data.layergroup.LayerGroupPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.574 sec
Running org.geoserver.wfs.TransactionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.204 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.494 sec
Running org.geoserver.web.data.resource.ResourceNameValidatorTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.web.data.store.CoverageStoreEditPageTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.148 sec
Running org.geoserver.wfs.WFSDisabledTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.507 sec
Running org.geoserver.wfs.WFSServiceExceptionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.225 sec
Running org.geoserver.wfs.WFSXStreamLoaderTest
Running org.geoserver.wfs.json.GeoJSONBuilderTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.wfs.json.GeoJSONTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.444 sec
Running org.geoserver.web.data.store.CoverageStoreNewPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.937 sec
Running org.geoserver.web.data.store.DataAccessEditPageTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.29 sec
Running org.geoserver.wfs.json.GeoJsonDescribeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.391 sec
Running org.geoserver.wfs.json.JSONTypeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.wfs.kvp.Filter_1_0_0_KvpParserTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.wfs.kvp.Filter_1_1_0_KvpParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.26 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Feature type cite:InvalidTypeName unknown
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.578 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/28/changes&gt;
Changes:
[andrea.aime] [GEOS-6413] The new KML encoder can leak unclosed feature iterators
[...truncated 1145 lines...]
Downloading: http://repo.opengeo.org/org/geotools/plugin/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/plugin/11-SNAPSHOT/maven-metadata.xml
308/308 B
Downloaded: http://repo.opengeo.org/org/geotools/plugin/11-SNAPSHOT/maven-metadata.xml (308 B at 27.3 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-core/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-core/11-SNAPSHOT/maven-metadata.xml
317/317 B
Downloaded: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-core/11-SNAPSHOT/maven-metadata.xml (317 B at 38.7 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-core/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-jdbc/11-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-core/11-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-jdbc/11-SNAPSHOT/maven-metadata.xml
309/309 B
Downloading: http://download.java.net/maven/2/org/geotools/gt-jdbc/11-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-jdbc/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-jdbc/11-SNAPSHOT/maven-metadata.xml (309 B at 23.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-graph/11-SNAPSHOT/maven-metadata.xml
310/310 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-graph/11-SNAPSHOT/maven-metadata.xml (310 B at 10.8 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-graph/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-graph/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-graph/11-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-data/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-data/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-data/11-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-data/11-SNAPSHOT/maven-metadata.xml
309/309 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-data/11-SNAPSHOT/maven-metadata.xml (309 B at 43.1 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-sqlserver ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-sqlserver ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-sqlserver ---
Downloading: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-gml2/11-SNAPSHOT/maven-metadata.xml
317/317 B
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-gml2/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml2/11-SNAPSHOT/maven-metadata.xml
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6413] The new KML encoder can leak unclosed feature iterators
[INFO] [GitCommitIdMojo] build.commit.time = 24.03.2014 @ 14:13:03 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Mar-2014 14:17
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 14:18:21 UTC
[INFO] [GitCommitIdMojo] build.branch = fa5a98fa2f4f76aa41c45f325f1e62a351097300
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = fa5a98f
[INFO] [GitCommitIdMojo] build.commit.id = fa5a98fa2f4f76aa41c45f325f1e62a351097300
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6413] The new KML encoder can leak unclosed feature iterators
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sqlserver ---
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-gml2/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-gml2/11-SNAPSHOT/maven-metadata.xml (317 B at 7.4 KB/sec)
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-sqlserver ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sqlserver ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sqlserver ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sqlserver ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sqlserver ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/target/gs-sqlserver-2.5-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sqlserver ---
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml3/11-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-gml3/11-SNAPSHOT/maven-metadata.xml
317/317 B
Downloaded: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-gml3/11-SNAPSHOT/maven-metadata.xml (317 B at 38.7 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-gml3/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-gml3/11-SNAPSHOT/maven-metadata.xml
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/target/gs-sqlserver-2.5-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sqlserver >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 14:18:22 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sqlserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sqlserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sqlserver >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sqlserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sqlserver ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-sqlserver ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/target/gs-sqlserver-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sqlserver/2.5-SNAPSHOT/gs-sqlserver-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sqlserver/2.5-SNAPSHOT/gs-sqlserver-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/extension/sqlserver/target/gs-sqlserver-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sqlserver/2.5-SNAPSHOT/gs-sqlserver-2.5-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Oracle DataStore Extension 2.5-SNAPSHOT
[WARNING] The following plugins are not marked @threadSafe in Oracle DataStore Extension:
Downloading: http://repo.opengeo.org/org/geotools/jdbc/gt-jdbc-oracle/11-SNAPSHOT/maven-metadata.xml
321/321 B
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc-oracle/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/jdbc/gt-jdbc-oracle/11-SNAPSHOT/maven-metadata.xml (321 B at 10.4 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-ows ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/ows/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-ows ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-ows ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ows ---
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/ows/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-ows ---
[INFO] Compiling 90 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/ows/target/classes&gt;
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/29/changes&gt;
