[Geoserver-devel] Build failed in Jenkins: geoserver-2.5.x #96
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/96/changes&gt;
Changes:
[andrea.aime] [GEOS-6604] WMS GetFeatureInfo using 'vendorParams: propertyName' does not working after upgrade to 2.5.x
[...truncated 8862 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Web Map Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Running org.geoserver.community.css.web.CssDemoTest
Downloading: http://repo.opengeo.org/org/geotools/gt-svg/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-svg/11-SNAPSHOT/maven-metadata.xml
308/308 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-svg/11-SNAPSHOT/maven-metadata.xml (308 B at 4.6 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-process/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process/11-SNAPSHOT/maven-metadata.xml
312/312 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-process/11-SNAPSHOT/maven-metadata.xml (312 B at 14.5 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-process-raster/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-raster/11-SNAPSHOT/maven-metadata.xml
319/319 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-process-raster/11-SNAPSHOT/maven-metadata.xml (319 B at 6.9 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-process-feature/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-feature/11-SNAPSHOT/maven-metadata.xml
320/320 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-process-feature/11-SNAPSHOT/maven-metadata.xml (320 B at 9.8 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-grid/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-grid/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-grid/11-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-grid/11-SNAPSHOT/maven-metadata.xml
309/309 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-grid/11-SNAPSHOT/maven-metadata.xml (309 B at 5.2 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wms ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-wms ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wms ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6604] WMS GetFeatureInfo using 'vendorParams: propertyName' does not working after upgrade to 2.5.x
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 11.08.2014 @ 10:10:02 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-Aug-2014 10:59
[INFO] [GitCommitIdMojo] build.build.time = 11.08.2014 @ 11:09:34 UTC
[INFO] [GitCommitIdMojo] build.branch = c2d0e8b51c2cd00ebfd57de004902a829a53b238
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c2d0e8b
[INFO] [GitCommitIdMojo] build.commit.id = c2d0e8b51c2cd00ebfd57de004902a829a53b238
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6604] WMS GetFeatureInfo using 'vendorParams: propertyName' does not working after upgrade to 2.5.x
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wms ---
[INFO] Copying 1 resource
[INFO] Copying 64 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wms ---
[INFO] Compiling 167 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wms/src/main/java/org/geoserver/wms/featureinfo/VectorRenderingLayerIdentifier.java&gt;:\[651,58\] illegal start of type
[INFO] 1 error
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping Sample DataAccess Integration Test
[INFO]
[INFO] Skipping ogr2ogr Output Format
[INFO]
[INFO] Skipping Excel Output Format
[INFO]
[INFO] Skipping GeoServer Layer Querying filter functions
[INFO]
[INFO] Skipping DXF output format
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.951s]
[INFO] Core Platform Module .............................. SUCCESS [5.105s]
[INFO] Open Web Service Module ........................... SUCCESS [12.826s]
[INFO] Main Module ....................................... SUCCESS [2:41.446s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.334s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.015s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.426s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.930s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.005s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:10.424s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [3:44.756s]
[INFO] Web Map Service Module ............................ FAILURE [2.946s]
[INFO] REST Support Module ............................... SUCCESS [37.331s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.618s]
[INFO] Core UI Module .................................... SUCCESS [2:04.804s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.442s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.270s]
[INFO] Printing Module ................................... SUCCESS [20.886s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.588s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.233s]
[INFO] Application Schema Support ........................ SUCCESS [0.347s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [24.158s]
[INFO] H2 DataStore Extension ............................ SUCCESS [20.741s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.532s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.815s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.647s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.554s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.406s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.906s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [3.241s]
[INFO] Chart external graphics support ................... SUCCESS [1.584s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.998s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.984s]
[INFO] OWS request flow controller ....................... SUCCESS [22.270s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.258s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.684s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.820s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [17.791s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.288s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.465s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 9:52.525s (Wall Clock)
[INFO] Finished at: Mon Aug 11 11:09:40 UTC 2014
[INFO] Final Memory: 50M/294M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wms: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/97/changes&gt;
Changes:
[andrea.aime] Fixing the build
[...truncated 3416 lines...]
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.253 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.297 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.976 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.087 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.049 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.223 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.733 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.339 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.172 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.642 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.security.validation.PasswordValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.037 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.487 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.189 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.243 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.311 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.336 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.984 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.276 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.45 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.498 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.817 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.598 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.919 sec <<< FAILURE!
testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest) Time elapsed: 1627 sec <<< FAILURE!
java.lang.AssertionError: expected:<2> but was:<4>
  at org.junit.Assert.fail(Assert.java:88)
  at org.junit.Assert.failNotEquals(Assert.java:743)
  at org.junit.Assert.assertEquals(Assert.java:118)
  at org.junit.Assert.assertEquals(Assert.java:555)
  at org.junit.Assert.assertEquals(Assert.java:542)
  at org.vfny.geoserver.crs.OvverideTransformationsTest.testFallbackOnEPSGDatabaseStd(OvverideTransformationsTest.java:96)
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.459 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.076 sec
Results :
Failed tests: testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest): expected:<2> but was:<4>
Tests run: 570, Failures: 1, Errors: 0, Skipped: 1
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.983s]
[INFO] Core Platform Module .............................. SUCCESS [4.107s]
[INFO] Open Web Service Module ........................... SUCCESS [12.763s]
[INFO] Main Module ....................................... FAILURE [2:40.688s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.509s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.281s]
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.505s]
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.178s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.834s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.579s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.593s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.284s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.611s]
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.076s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.819s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.266s]
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.308s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.531s]
[INFO] Total time: 3:07.775s (Wall Clock)
[INFO] Finished at: Mon Aug 11 14:15:56 UTC 2014
[INFO] Final Memory: 37M/376M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/98/changes&gt;
Changes:
[jdeolive] Updated repository settings for new boundless maven repo.
[...truncated 7687 lines...]
[INFO]
[INFO] Skipping GeoServer CSS Styling
[INFO]
[INFO] Skipping Catalog Services for the Web interfaces
[INFO]
[INFO] Skipping Web Map Service Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.453 sec
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@1af4e9d
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.505 sec
Results :
Tests run: 85, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wcs1_1 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/gs-wcs1_1-2.5-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs1_1 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/gs-wcs1_1-2.5-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs1_1 >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wcs1_1 ---
[INFO] [GitCommitIdMojo] build.commit.message.short = Updated repository settings for new boundless maven repo.
[INFO] [GitCommitIdMojo] build.commit.time = 13.08.2014 @ 17:10:31 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Aug-2014 18:05
[INFO] [GitCommitIdMojo] build.build.time = 13.08.2014 @ 18:13:47 UTC
[INFO] [GitCommitIdMojo] build.branch = d50a763c17cb2742cccc3ff87388dc7a59dd88fd
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d50a763
[INFO] [GitCommitIdMojo] build.commit.id = d50a763c17cb2742cccc3ff87388dc7a59dd88fd
[INFO] [GitCommitIdMojo] build.commit.message.full = Updated repository settings for new boundless maven repo.
[INFO]
[INFO] --- javacc-maven-plugin:2.3:jjtree (jjtree) @ gs-wcs1_1 ---
[INFO] Nothing to process - all grammars in <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset&gt; are up to date.
[INFO]
[INFO] --- javacc-maven-plugin:2.3:javacc (javacc) @ gs-wcs1_1 ---
[INFO] Nothing to process - all grammars in <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/generated-sources/jjtree&gt; are up to date.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs1_1 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs1_1 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/gs-wcs1_1-2.5-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs1_1 >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 13.08.2014 @ 18:13:48 UTC
[INFO]
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs1_1 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs1_1 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/gs-wcs1_1-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wcs1_1 ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/gs-wcs1_1-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs1_1/2.5-SNAPSHOT/gs-wcs1_1-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs1_1/2.5-SNAPSHOT/gs-wcs1_1-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/gs-wcs1_1-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs1_1/2.5-SNAPSHOT/gs-wcs1_1-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/gs-wcs1_1-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs1_1/2.5-SNAPSHOT/gs-wcs1_1-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/wcs1_1/target/gs-wcs1_1-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs1_1/2.5-SNAPSHOT/gs-wcs1_1-2.5-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.704s]
[INFO] Core Platform Module .............................. SUCCESS [4.495s]
[INFO] Open Web Service Module ........................... SUCCESS [13.322s]
[INFO] Main Module ....................................... SUCCESS [2:44.438s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.109s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.718s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [44.919s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.823s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:09.410s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:08.242s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:41.544s]
[INFO] REST Support Module ............................... SUCCESS [36.968s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.373s]
[INFO] Core UI Module .................................... SUCCESS [2:04.948s]
[INFO] Security UI Modules ............................... SUCCESS [0.464s]
[INFO] Printing Module ................................... FAILURE [1.343s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.218s]
[INFO] Application Schema Support ........................ SUCCESS [0.248s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.595s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.689s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.496s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.998s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.500s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.584s]
[INFO] Validation Module ................................. SUCCESS [3.216s]
[INFO] Chart external graphics support ................... SUCCESS [2.331s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.301s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.439s]
[INFO] OWS request flow controller ....................... SUCCESS [22.644s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.275s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.248s]
[INFO] DXF output format ................................. SUCCESS [0.445s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.246s]
[INFO] Total time: 8:46.886s (Wall Clock)
[INFO] Finished at: Wed Aug 13 18:13:48 UTC 2014
[INFO] Final Memory: 44M/190M
[ERROR] Failed to execute goal on project gs-printing: Could not resolve dependencies for project org.geoserver.community:gs-printing:jar:2.5-SNAPSHOT: Could not find artifact org.mapfish.print:print-lib:jar:1.2-20101018133712 in boundless (http://repo.boundlessgeo.com/main) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-printing
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/99/&gt;
[...truncated 7573 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/web/security/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-sec/2.5-SNAPSHOT/gs-web-sec-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/ws/src/web/security/target/gs-web-sec-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-sec/2.5-SNAPSHOT/gs-web-sec-2.5-SNAPSHOT-tests.jar
SchemaLocation: schemaLocation value = 'http://localhost:8080/geoserver/schemas/wcs/1.1.1/wcsCoverages.xsd’ must have even number of URI's.
[INFO]
[INFO] Building Printing Module 2.5-SNAPSHOT
[WARNING] The following plugins are not marked @threadSafe in Printing Module:
Downloading: http://repo.boundlessgeo.com/main/org/mapfish/print/print-lib/1.2-20101018133712/print-lib-1.2-20101018133712.pom
Downloaded: http://repo.boundlessgeo.com/main/org/mapfish/print/print-lib/1.2-20101018133712/print-lib-1.2-20101018133712.pom (0 B at 0.0 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.pom
Downloading: http://download.osgeo.org/webdav/geotools/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.pom
Downloading: http://maven.restlet.org/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.pom
Downloading: http://repo.maven.apache.org/maven2/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.pom
[WARNING] The POM for ch.thus:pvalsecc:jar:0.9.2 is missing, no dependency information available
Downloading: http://repo.boundlessgeo.com/main/org/mapfish/geo/mapfish-geo-lib/1.2-20090817094015/mapfish-geo-lib-1.2-20090817094015.pom
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.371 sec
Running org.geoserver.wcs.GetCoverageTest
Downloading: http://download.osgeo.org/webdav/geotools/org/mapfish/geo/mapfish-geo-lib/1.2-20090817094015/mapfish-geo-lib-1.2-20090817094015.pom
Downloading: http://maven.restlet.org/org/mapfish/geo/mapfish-geo-lib/1.2-20090817094015/mapfish-geo-lib-1.2-20090817094015.pom
Downloading: http://repo.maven.apache.org/maven2/org/mapfish/geo/mapfish-geo-lib/1.2-20090817094015/mapfish-geo-lib-1.2-20090817094015.pom
[WARNING] The POM for org.mapfish.geo:mapfish-geo-lib:jar:1.2-20090817094015 is missing, no dependency information available
Downloading: http://repo.boundlessgeo.com/main/org/mapfish/print/print-lib/1.2-20101018133712/print-lib-1.2-20101018133712.jar
Downloading: http://repo.boundlessgeo.com/main/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.jar
Downloading: http://repo.boundlessgeo.com/main/org/mapfish/geo/mapfish-geo-lib/1.2-20090817094015/mapfish-geo-lib-1.2-20090817094015.jar
Downloaded: http://repo.boundlessgeo.com/main/org/mapfish/print/print-lib/1.2-20101018133712/print-lib-1.2-20101018133712.jar (0 B at 0.0 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/mapfish/geo/mapfish-geo-lib/1.2-20090817094015/mapfish-geo-lib-1.2-20090817094015.jar
Downloading: http://maven.restlet.org/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.jar
Downloading: http://maven.restlet.org/org/mapfish/geo/mapfish-geo-lib/1.2-20090817094015/mapfish-geo-lib-1.2-20090817094015.jar
Downloading: http://repo.maven.apache.org/maven2/ch/thus/pvalsecc/0.9.2/pvalsecc-0.9.2.jar
Downloading: http://repo.maven.apache.org/maven2/org/mapfish/geo/mapfish-geo-lib/1.2-20090817094015/mapfish-geo-lib-1.2-20090817094015.jar
[INFO]
[INFO] Skipping HTTP Proxy Extension
[INFO]
[INFO] Skipping ArcSDE DataStore Extension
[INFO]
[INFO] Skipping H2 DataStore Extension
[INFO]
[INFO] Skipping Teradata DataStore Extension
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.017 sec
Running org.geoserver.wcs.ResourceAccessManagerWCSTest
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.557s]
[INFO] Core Platform Module .............................. SUCCESS [4.503s]
[INFO] Open Web Service Module ........................... SUCCESS [12.815s]
[INFO] Main Module ....................................... SUCCESS [2:37.959s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.953s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:08.802s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [41.875s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.416s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:02.827s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:46.801s]
[INFO] REST Support Module ............................... SUCCESS [37.728s]
[INFO] Core UI Module .................................... SUCCESS [2:00.773s]
[INFO] Security UI Modules ............................... SUCCESS [0.494s]
[INFO] Community Space ................................... SUCCESS [0.291s]
[INFO] Printing Module ................................... FAILURE [2.472s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.255s]
[INFO] Application Schema Support ........................ SUCCESS [0.542s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.179s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.790s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.589s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.456s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.227s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.631s]
[INFO] Validation Module ................................. SUCCESS [3.253s]
[INFO] Chart external graphics support ................... SUCCESS [1.915s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.042s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.508s]
[INFO] OWS request flow controller ....................... SUCCESS [20.421s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.270s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.447s]
[INFO] DXF output format ................................. SUCCESS [0.475s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.262s]
[INFO] Total time: 8:30.773s (Wall Clock)
[INFO] Finished at: Wed Aug 13 19:21:25 UTC 2014
[INFO] Final Memory: 45M/195M
[ERROR] Failed to execute goal on project gs-printing: Could not resolve dependencies for project org.geoserver.community:gs-printing:jar:2.5-SNAPSHOT: The following artifacts could not be resolved: ch.thus:pvalsecc:jar:0.9.2, org.mapfish.geo:mapfish-geo-lib:jar:1.2-20090817094015: Could not find artifact ch.thus:pvalsecc:jar:0.9.2 in boundless (http://repo.boundlessgeo.com/main) -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x/100/&gt;
