[Geoserver-devel] Build failed in Jenkins: geoserver-2.5.x-nightly #181
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/181/changes&gt;
Changes:
[andrea.aime] [GEOS-6619] Rendering based feature info will return just one geometry of the group that falls into the same pixel
[jdeolive] Fixing links to old website
Started by timer
Building in workspace <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/&gt;
Checkout:geoserver-2.4.x / <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision f7b29a16d0571d8f23535ea9c0aed6501bb99cf7 (origin/2.5.x)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
Commencing build of Revision 31a9cc81e9abf744dc7d88ea0c0ac3b60e235cbb (origin/2.5.x)
Checking out Revision 31a9cc81e9abf744dc7d88ea0c0ac3b60e235cbb (origin/2.5.x)
[geoserver-2.4.x] $ /bin/sh -xe /tmp/hudson5945184702023462638.sh
+ ver=2.5.x
+ dist=/var/www/geoserver/2.5.x
+ date +%Y-%m-%d
+ datestamp=2014-08-16
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=181 -P release,communityRelease clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Coverage Service 2.0 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Modules
[INFO] Security UI Core Module
[INFO] Security UI JDBC Module
[INFO] Security UI LDAP Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] Authentication by unique url key
[INFO] WorldWind Format Module
[INFO] Printing Module
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Extensions
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] GeoServer Scripting Extensions
[INFO] Core Scripting Extension
[INFO] H2 DataStore Extension
[INFO] Python Scripting Extension
[INFO] JavaScript Scripting Extension
[INFO] Groovy Scripting Extension
[INFO] GeoServer JDBC KV Catalog
[INFO] Simple Feature Service
[INFO] Aggregating Data Store
[INFO] WMS-EO
[INFO] ColorMap
[INFO] GeoServer mbtiles Extension
[INFO] GeoServer GeoPackage Extension
[INFO] GRIB Coverage Format
[INFO] GeoServer Community Release Module
[INFO] SpatiaLite Extension
[INFO] BeanShell Scripting Extension
[INFO] Ruby Scripting Extension
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF output format
[INFO] DXF WPS PPIO
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GeoServer Release Module
[INFO] Building GeoServer
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing links to old website
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.08.2014 @ 13:55:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 16-Aug-2014 15:25
[INFO] [GitCommitIdMojo] build.build.time = 16.08.2014 @ 15:26:01 UTC
[INFO] [GitCommitIdMojo] build.branch = 31a9cc81e9abf744dc7d88ea0c0ac3b60e235cbb
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 31a9cc8
[INFO] [GitCommitIdMojo] build.commit.id = 31a9cc81e9abf744dc7d88ea0c0ac3b60e235cbb
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing links to old website
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:gt-api:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:library:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:modules:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:geotools:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:gt-referencing:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-referencing:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-metadata:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:gt-metadata:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-metadata:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-metadata:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-opengis:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:gt-opengis:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-opengis:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-opengis:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-main:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:gt-main:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:gwc-core:1.5-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geowebcache:gwc-core:1.5-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-core/1.5-SNAPSHOT/gwc-core-1.5-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geowebcache:gwc-core:pom:1.5-SNAPSHOT' in repository boundless (http://repo.boundlessgeo.com/main)
Downloading: http://download.osgeo.org/webdav/geotools//org/geowebcache/gwc-core/1.5-SNAPSHOT/gwc-core-1.5-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geowebcache:gwc-core:pom:1.5-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-core/1.5-SNAPSHOT/gwc-core-1.5-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geowebcache:gwc-core:jar:1.5-SNAPSHOT' in repository boundless (http://repo.boundlessgeo.com/main)
Downloading: http://download.osgeo.org/webdav/geotools//org/geowebcache/gwc-core/1.5-SNAPSHOT/gwc-core-1.5-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geowebcache:gwc-core:jar:1.5-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geowebcache:gwc-core:jar:1.5-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geowebcache -DartifactId=gwc-core -Dversion=1.5-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geowebcache -DartifactId=gwc-core -Dversion=1.5-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver:geoserver:pom:2.5-SNAPSHOT
    2) org.geowebcache:gwc-core:jar:1.5-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  boundless (http://repo.boundlessgeo.com/main),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org)
[INFO] Total time: 17 seconds
[INFO] Finished at: Sat Aug 16 15:26:05 UTC 2014
[INFO] Final Memory: 55M/227M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-08-16-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/182/&gt;
[...truncated 174 lines...]
[INFO] snapshot org.geowebcache:geowebcache:1.5-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geowebcache:geowebcache:1.5-SNAPSHOT: checking for updates from osgeo
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/target/geoserver-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] build.timestamp = 17-Aug-2014 15:30
[INFO] [GitCommitIdMojo] build.build.time = 17.08.2014 @ 15:31:03 UTC
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/target/dependency/gwc-core-1.5-SNAPSHOT.jar&gt;
[WARNING] DEPRECATED [tasks]: Use target instead
[INFO] [antrun:run {execution: read-manifest}]
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [copy] Copying 1 file to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/target&gt;
[INFO] Executed tasks
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.5-SNAPSHOT/geoserver-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/target/geoserver-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.5-SNAPSHOT/geoserver-2.5-SNAPSHOT-tests.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 17.08.2014 @ 15:31:07 UTC
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/src/main/resources&gt;
[INFO] Compiling 23 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/classes&gt;
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/src/test/resources&gt;
[INFO] Compiling 6 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/gs-platform-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/gs-platform-2.5-SNAPSHOT-tests.jar&gt;
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/gs-platform-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/gs-platform-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/dependency/gwc-core-1.5-SNAPSHOT.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/gs-platform-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.5-SNAPSHOT/gs-platform-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/gs-platform-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.5-SNAPSHOT/gs-platform-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/gs-platform-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.5-SNAPSHOT/gs-platform-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/platform/target/gs-platform-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.5-SNAPSHOT/gs-platform-2.5-SNAPSHOT-test-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/ows/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 17.08.2014 @ 15:31:12 UTC
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/ows/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.ows:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools.ogc:net.opengis.ows:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:ogc:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:ogc:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools.ogc:org.w3.xlink:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:org.w3.xlink:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-ows/11-SNAPSHOT/gt-xsd-ows-11-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools.xsd:gt-xsd-ows:pom:11-SNAPSHOT' in repository boundless (http://repo.boundlessgeo.com/main)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/xsd/gt-xsd-ows/11-SNAPSHOT/gt-xsd-ows-11-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools.xsd:gt-xsd-ows:pom:11-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[INFO] snapshot org.geotools.xsd:gt-xsd-core:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools.xsd:gt-xsd-core:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:xsd:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools.xsd:xsd:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:extension:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:extension:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-graph:11-SNAPSHOT: checking for updates from boundless
[INFO] snapshot org.geotools:gt-graph:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-graph:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-graph:11-SNAPSHOT: checking for updates from geosolutions
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-ows/11-SNAPSHOT/gt-xsd-ows-11-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools.xsd:gt-xsd-ows:jar:11-SNAPSHOT' in repository boundless (http://repo.boundlessgeo.com/main)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/xsd/gt-xsd-ows/11-SNAPSHOT/gt-xsd-ows-11-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools.xsd:gt-xsd-ows:jar:11-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
Missing:
1) org.geotools.xsd:gt-xsd-ows:jar:11-SNAPSHOT
      mvn install:install-file -DgroupId=org.geotools.xsd -DartifactId=gt-xsd-ows -Dversion=11-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
      mvn deploy:deploy-file -DgroupId=org.geotools.xsd -DartifactId=gt-xsd-ows -Dversion=11-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver:gs-ows:jar:2.5-SNAPSHOT
    2) org.geotools.xsd:gt-xsd-ows:jar:11-SNAPSHOT
for artifact:
[INFO] Total time: 33 seconds
[INFO] Finished at: Sun Aug 17 15:31:16 UTC 2014
[INFO] Final Memory: 79M/261M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-08-17-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/183/changes&gt;
