See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/27/changes>
Changes:
[niels] GeoPackage & MbTiles: Plugin Configurations
[niels] GeoPackage & MBTiles: documentation
[...truncated 3698 lines...]
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/dependency/gwc-core-1.5-SNAPSHOT.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar
[INFO] Building WMS-EO
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target>
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = GeoPackage & MBTiles: documentation
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 21.03.2014 @ 12:14:43 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 21-Mar-2014 16:41
[INFO] [GitCommitIdMojo] build.build.time = 21.03.2014 @ 16:48:09 UTC
[INFO] [GitCommitIdMojo] build.branch = 3958d7cdcbfbdc745ab3fd4aac7efc6af70724d9
[INFO] [GitCommitIdMojo] build.commit.user.email = niels@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Niels Charlier
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3958d7c
[INFO] [GitCommitIdMojo] build.commit.id = 3958d7cdcbfbdc745ab3fd4aac7efc6af70724d9
[INFO] [GitCommitIdMojo] build.commit.message.full = GeoPackage & MBTiles: documentation
[INFO] Copying 12 resources
[INFO] Copying 18 resources
[INFO] Compiling 26 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/classes>
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/test-classes>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/dependency/gwc-core-1.5-SNAPSHOT.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar
[INFO] Building ColorMap
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target>
[INFO] [GitCommitIdMojo] build.build.time = 21.03.2014 @ 16:48:16 UTC
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/src/main/resources>
[INFO] Compiling 6 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/classes>
[INFO] Copying 4 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/src/test/resources>
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/test-classes>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/dependency/gwc-core-1.5-SNAPSHOT.jar>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.5-SNAPSHOT/gs-colormap-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.5-SNAPSHOT/gs-colormap-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.5-SNAPSHOT/gs-colormap-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.5-SNAPSHOT/gs-colormap-2.5-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer mbtiles Extension
[INFO] [GitCommitIdMojo] build.build.time = 21.03.2014 @ 16:48:21 UTC
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/mbtiles/src/main/resources>
[INFO] snapshot org.geotools:gt-mbtiles:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-mbtiles:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-mbtiles/11-SNAPSHOT/gt-mbtiles-11-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-mbtiles:pom:11-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-mbtiles/11-SNAPSHOT/gt-mbtiles-11-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-mbtiles:pom:11-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geotools/gt-mbtiles/11-SNAPSHOT/gt-mbtiles-11-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-mbtiles:jar:11-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-mbtiles/11-SNAPSHOT/gt-mbtiles-11-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-mbtiles:jar:11-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools:gt-mbtiles:jar:11-SNAPSHOT
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geotools -DartifactId=gt-mbtiles -Dversion=11-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.geotools -DartifactId=gt-mbtiles -Dversion=11-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver.community:gs-mbtiles:jar:2.5-SNAPSHOT
2) org.geotools:gt-mbtiles:jar:11-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
maven-restlet (http://maven.restlet.org),
[INFO] Total time: 6 minutes 24 seconds
[INFO] Finished at: Fri Mar 21 16:48:22 UTC 2014
[INFO] Final Memory: 121M/348M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-21-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
