[Geoserver-devel] Build failed in Jenkins: geoserver-2.5.x-nightly #29
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/29/&gt;
[...truncated 3661 lines...]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/dependency/gwc-core-1.5-SNAPSHOT.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/feature-aggregate/target/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-feature-aggregate/2.5-SNAPSHOT/gs-feature-aggregate-2.5-SNAPSHOT-sources.jar
[INFO] Building WMS-EO
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fix-GEOS-6114 (tests and minor fixes by Andrea Aime)
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.03.2014 @ 13:58:17 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 23-Mar-2014 15:29
[INFO] [GitCommitIdMojo] build.build.time = 23.03.2014 @ 15:34:51 UTC
[INFO] [GitCommitIdMojo] build.branch = 12e0d706ff121999ee95b53ddc8972758af0ee42
[INFO] [GitCommitIdMojo] build.commit.user.email = srivani.vuppala@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = svuppala
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 12e0d70
[INFO] [GitCommitIdMojo] build.commit.id = 12e0d706ff121999ee95b53ddc8972758af0ee42
[INFO] [GitCommitIdMojo] build.commit.message.full = Fix-GEOS-6114 (tests and minor fixes by Andrea Aime)
[INFO] Copying 12 resources
[INFO] Copying 18 resources
[INFO] Compiling 26 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/dependency/gwc-core-1.5-SNAPSHOT.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/wms-eo/target/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-wms-eo/2.5-SNAPSHOT/gs-wms-eo-2.5-SNAPSHOT-test-sources.jar
[INFO] Building ColorMap
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 23.03.2014 @ 15:34:58 UTC
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/src/main/resources&gt;
[INFO] Compiling 6 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/classes&gt;
[INFO] Copying 4 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/src/test/resources&gt;
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/test-classes&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/dependency/gwc-core-1.5-SNAPSHOT.jar&gt;
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.5-SNAPSHOT/gs-colormap-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.5-SNAPSHOT/gs-colormap-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.5-SNAPSHOT/gs-colormap-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/colormap/target/gs-colormap-2.5-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-colormap/2.5-SNAPSHOT/gs-colormap-2.5-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer mbtiles Extension
[INFO] Deleting directory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/mbtiles/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 23.03.2014 @ 15:35:04 UTC
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/community/mbtiles/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-mbtiles:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-mbtiles:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-mbtiles/11-SNAPSHOT/gt-mbtiles-11-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-mbtiles:pom:11-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-mbtiles/11-SNAPSHOT/gt-mbtiles-11-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geotools:gt-mbtiles:pom:11-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geotools/gt-mbtiles/11-SNAPSHOT/gt-mbtiles-11-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-mbtiles:jar:11-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/gt-mbtiles/11-SNAPSHOT/gt-mbtiles-11-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geotools:gt-mbtiles:jar:11-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools:gt-mbtiles:jar:11-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geotools -DartifactId=gt-mbtiles -Dversion=11-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geotools -DartifactId=gt-mbtiles -Dversion=11-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:gs-mbtiles:jar:2.5-SNAPSHOT
    2) org.geotools:gt-mbtiles:jar:11-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 6 minutes 1 second
[INFO] Finished at: Sun Mar 23 15:35:04 UTC 2014
[INFO] Final Memory: 130M/323M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-23-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
Build step 'Execute shell' marked build as failure
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/30/changes&gt;
Changes:
[andrea.aime] [GEOS-6413] The new KML encoder can leak unclosed feature iterators
[...truncated 3648 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6413] The new KML encoder can leak unclosed feature iterators
[INFO] [GitCommitIdMojo] build.commit.time = 24.03.2014 @ 14:13:03 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Mar-2014 15:55
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 16:00:52 UTC
[INFO] [GitCommitIdMojo] build.branch = fa5a98fa2f4f76aa41c45f325f1e62a351097300
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = fa5a98f
[INFO] [GitCommitIdMojo] build.commit.id = fa5a98fa2f4f76aa41c45f325f1e62a351097300
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6413] The new KML encoder can leak unclosed feature iterators
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 16:00:59 UTC
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 16:01:05 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Finished at: Mon Mar 24 16:01:05 UTC 2014
[INFO] Final Memory: 128M/416M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-24-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/31/&gt;
[...truncated 3580 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 25-Mar-2014 15:28
[INFO] [GitCommitIdMojo] build.build.time = 25.03.2014 @ 15:34:07 UTC
[INFO] [GitCommitIdMojo] build.build.time = 25.03.2014 @ 15:34:14 UTC
[INFO] [GitCommitIdMojo] build.build.time = 25.03.2014 @ 15:34:20 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 5 minutes 39 seconds
[INFO] Finished at: Tue Mar 25 15:34:21 UTC 2014
[INFO] Final Memory: 122M/445M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-25-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/32/&gt;
[INFO] [GitCommitIdMojo] build.timestamp = 26-Mar-2014 15:29
[INFO] [GitCommitIdMojo] build.build.time = 26.03.2014 @ 15:37:08 UTC
[INFO] [GitCommitIdMojo] build.build.time = 26.03.2014 @ 15:37:15 UTC
[INFO] [GitCommitIdMojo] build.build.time = 26.03.2014 @ 15:37:21 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 7 minutes 51 seconds
[INFO] Finished at: Wed Mar 26 15:37:21 UTC 2014
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-26-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/33/&gt;
[...truncated 3709 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 27-Mar-2014 15:29
[INFO] [GitCommitIdMojo] build.build.time = 27.03.2014 @ 15:37:38 UTC
[INFO] [GitCommitIdMojo] build.build.time = 27.03.2014 @ 15:37:44 UTC
[INFO] [GitCommitIdMojo] build.build.time = 27.03.2014 @ 15:37:50 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 7 minutes 57 seconds
[INFO] Finished at: Thu Mar 27 15:37:51 UTC 2014
[INFO] Final Memory: 122M/466M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-27-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/34/changes&gt;
Changes:
[andrea.aime] [GEOS-5532] Renaming workspaces doesn't translate over to Tile Caches
[...truncated 3700 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5532] Renaming workspaces doesn't translate over to Tile Caches
[INFO] [GitCommitIdMojo] build.commit.time = 27.03.2014 @ 17:45:01 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 28-Mar-2014 15:29
[INFO] [GitCommitIdMojo] build.build.time = 28.03.2014 @ 15:35:06 UTC
[INFO] [GitCommitIdMojo] build.branch = 91c5d971cedb2beeaebf1b0f27b15a8cca9ec356
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 91c5d97
[INFO] [GitCommitIdMojo] build.commit.id = 91c5d971cedb2beeaebf1b0f27b15a8cca9ec356
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5532] Renaming workspaces doesn't translate over to Tile Caches
[INFO] [GitCommitIdMojo] build.build.time = 28.03.2014 @ 15:35:12 UTC
[INFO] [GitCommitIdMojo] build.build.time = 28.03.2014 @ 15:35:18 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 6 minutes 13 seconds
[INFO] Finished at: Fri Mar 28 15:35:19 UTC 2014
[INFO] Final Memory: 122M/454M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-28-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/35/changes&gt;
Changes:
[andrea.aime] [GEOS-3662] Documentation for jp2kak extension
[...truncated 3532 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-3662] Documentation for jp2kak extension
[INFO] [GitCommitIdMojo] build.commit.time = 29.03.2014 @ 14:46:45 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 29-Mar-2014 17:01
[INFO] [GitCommitIdMojo] build.build.time = 29.03.2014 @ 17:07:28 UTC
[INFO] [GitCommitIdMojo] build.branch = fff667d6465851bb361218811ef9a44a86ecbc09
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = fff667d
[INFO] [GitCommitIdMojo] build.commit.id = fff667d6465851bb361218811ef9a44a86ecbc09
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-3662] Documentation for jp2kak extension
[INFO] [GitCommitIdMojo] build.build.time = 29.03.2014 @ 17:07:35 UTC
[INFO] [GitCommitIdMojo] build.build.time = 29.03.2014 @ 17:07:41 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 6 minutes 23 seconds
[INFO] Finished at: Sat Mar 29 17:07:42 UTC 2014
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-29-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/36/changes&gt;
Changes:
[andrea.aime] [GEOS-6422] Several exceptions logged after import due to non serializable classes referenced by Import pages
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6422] Several exceptions logged after import due to non serializable classes referenced by Import pages
[INFO] [GitCommitIdMojo] build.commit.time = 30.03.2014 @ 14:47:40 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 30-Mar-2014 18:17
[INFO] [GitCommitIdMojo] build.build.time = 30.03.2014 @ 18:23:17 UTC
[INFO] [GitCommitIdMojo] build.branch = b130b7d44e25c53b22bbdf19b095812d45a2cacb
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b130b7d
[INFO] [GitCommitIdMojo] build.commit.id = b130b7d44e25c53b22bbdf19b095812d45a2cacb
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6422] Several exceptions logged after import due to non serializable classes referenced by Import pages
[INFO] [GitCommitIdMojo] build.build.time = 30.03.2014 @ 18:23:24 UTC
[INFO] [GitCommitIdMojo] build.build.time = 30.03.2014 @ 18:23:30 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 5 minutes 53 seconds
[INFO] Finished at: Sun Mar 30 18:23:31 UTC 2014
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-30-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/37/&gt;
[...truncated 3697 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 31-Mar-2014 15:29
[INFO] [GitCommitIdMojo] build.build.time = 31.03.2014 @ 15:35:35 UTC
[INFO] [GitCommitIdMojo] build.build.time = 31.03.2014 @ 15:35:41 UTC
[INFO] [GitCommitIdMojo] build.build.time = 31.03.2014 @ 15:35:47 UTC
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 6 minutes 17 seconds
[INFO] Finished at: Mon Mar 31 15:35:48 UTC 2014
[INFO] Final Memory: 128M/410M
+ cp target/release/geoserver*-bin.zip /var/www/geoserver/2.5.x/geoserver-2.5.x-2014-03-31-bin.zip
See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/38/changes&gt;
