See <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/314/changes>
Changes:
[andrea.aime] [GEOS-6395] WMS Animator parameter is misspelled
[...truncated 1662 lines...]
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wfs/target/gs-wfs-2.5-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-wfs ---
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wfs/target/dependency/gt-api-11-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wfs/target/dependency/gwc-core-1.5-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wfs ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wfs/target/gs-wfs-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.5-SNAPSHOT/gs-wfs-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wfs/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.5-SNAPSHOT/gs-wfs-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wfs/target/gs-wfs-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.5-SNAPSHOT/gs-wfs-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wfs/target/gs-wfs-2.5-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.5-SNAPSHOT/gs-wfs-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wfs/target/gs-wfs-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wfs/2.5-SNAPSHOT/gs-wfs-2.5-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Map Service Module 2.5-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wms ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-wms ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wms ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6395] WMS Animator parameter is misspelled
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.12.2014 @ 15:20:24 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Dec-2014 17:14
[INFO] [GitCommitIdMojo] build.build.time = 24.12.2014 @ 17:15:23 UTC
[INFO] [GitCommitIdMojo] build.branch = d282cc944c012c127129cbfa12331bb7a3552049
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d282cc9
[INFO] [GitCommitIdMojo] build.commit.id = d282cc944c012c127129cbfa12331bb7a3552049
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6395] WMS Animator parameter is misspelled
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wms ---
[INFO] Copying 1 resource
[INFO] Copying 64 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wms ---
[INFO] Compiling 167 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wms ---
[INFO] Copying 95 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wms ---
[INFO] Compiling 93 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[143,11\] '{' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[143,29\] ')' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[143,93\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[143,8\] 'try' without 'catch' or 'finally'
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,4\] illegal start of expression
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,12\] illegal start of expression
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,22\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,53\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,54\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[184,58\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,11\] illegal start of type
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,15\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,35\] illegal start of expression
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,34\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,36\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,44\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[202,53\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,11\] illegal start of type
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,15\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,40\] illegal start of expression
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,39\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,41\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,49\] not a statement
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[224,58\] ';' expected
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.5.x-nightly/ws/src/wms/src/test/java/org/geoserver/wms/animate/AnimatorTest.java>:\[287,1\] reached end of file while parsing
[INFO] 25 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.355s]
[INFO] Core Platform Module .............................. SUCCESS [3.611s]
[INFO] Open Web Service Module ........................... SUCCESS [4.785s]
[INFO] Main Module ....................................... SUCCESS [17.157s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.337s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [4.403s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [4.242s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.634s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [6.257s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [6.213s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [7.722s]
[INFO] Web Feature Service Module ........................ SUCCESS [9.200s]
[INFO] Web Map Service Module ............................ FAILURE [6.872s]
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:22.710s
[INFO] Finished at: Wed Dec 24 17:15:29 UTC 2014
[INFO] Final Memory: 45M/223M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wms: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
