See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/1/>
[...truncated 11156 lines...]
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0ca267f
[INFO] [GitCommitIdMojo] build.commit.id = 0ca267f4f03c5e09a95bf302df7086e4f03c4f4f
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #626 from smithkm/geojson-crs
Correct CRS encoding for WFS GeoJSON, Fixes GEOS-5996
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-core <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-dxf-core ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.6-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-core >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-dxf-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #626 from smithkm/geojson-crs
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.08.2014 @ 15:20:55 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Aug-2014 15:36
[INFO] [GitCommitIdMojo] build.build.time = 20.08.2014 @ 15:56:54 UTC
[INFO] [GitCommitIdMojo] build.branch = 0ca267f4f03c5e09a95bf302df7086e4f03c4f4f
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-core <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-dxf-core ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.6-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-dxf-core ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.6-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.6-SNAPSHOT/gs-dxf-core-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/dxf/core/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.6-SNAPSHOT/gs-dxf-core-2.6-SNAPSHOT.pom
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.173 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.6-SNAPSHOT/gs-dxf-core-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.6-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.6-SNAPSHOT/gs-dxf-core-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/dxf/core/target/gs-dxf-core-2.6-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-core/2.6-SNAPSHOT/gs-dxf-core-2.6-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Coverage Service 2.0 Module 2.6-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Web Coverage Service 2.0 Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wcs2_0 ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wcs2_0 ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wcs2_0 ---
[INFO] [GitCommitIdMojo] build.build.time = 20.08.2014 @ 15:56:56 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wcs2_0 ---
[INFO] Copying 2 resources
[INFO] Copying 110 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wcs2_0 ---
[INFO] Compiling 52 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wcs2_0/target/classes>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.604 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.743 sec
Results :
Failed tests: testPropertySelection(org.geoserver.wms.featureinfo.GetFeatureInfoJSONTest): expected:<application/[json]> but was:<application/[vnd.ogc.se_xml]>
Tests run: 639, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wcs2_0 ---
[INFO] Copying 53 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wcs2_0 ---
[INFO] Compiling 26 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wcs2_0/target/test-classes>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.997s]
[INFO] Core Platform Module .............................. SUCCESS [15.831s]
[INFO] Open Web Service Module ........................... SUCCESS [16.354s]
[INFO] Main Module ....................................... SUCCESS [3:19.792s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.771s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [3:32.836s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [3:49.178s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.265s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [57.573s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:26.642s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [5:10.498s]
[INFO] Web Map Service Module ............................ FAILURE [5:03.926s]
[INFO] REST Support Module ............................... SUCCESS [44.760s]
[INFO] GeoServer Web Modules ............................. SUCCESS [2.817s]
[INFO] Core UI Module .................................... SUCCESS [2:52.663s]
[INFO] WFS UI Module ..................................... SUCCESS [41.564s]
[INFO] Security UI Modules ............................... SUCCESS [0.228s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.134s]
[INFO] Printing Module ................................... SUCCESS [48.697s]
[INFO] Community Space ................................... SUCCESS [0.176s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [14.176s]
[INFO] Application Schema Support ........................ SUCCESS [0.103s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.853s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.348s]
[INFO] H2 DataStore Extension ............................ SUCCESS [22.429s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.376s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.620s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.107s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.418s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.842s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.253s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.074s]
[INFO] Excel Output Format ............................... SUCCESS [40.606s]
[INFO] Chart external graphics support ................... SUCCESS [2.000s]
[INFO] Feature Generalization Extension .................. SUCCESS [8.331s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.801s]
[INFO] OWS request flow controller ....................... SUCCESS [33.396s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.104s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.955s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [11.081s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [1:18.577s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [1.601s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.684s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.094s]
[INFO] DXF WFS output format ............................. SUCCESS [43.294s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.137s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 20:29.506s (Wall Clock)
[INFO] Finished at: Wed Aug 20 15:57:04 UTC 2014
[INFO] Final Memory: 222M/373M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Destroying 1 processes
Destroying process..
Destroyed 1 processes
