See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/104/changes>
Changes:
[andrea.aime] [GEOS-6890] An import generating a layer whose name already exists in a different workspace fails
[...truncated 24754 lines...]
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 23.02.2015 @ 10:06:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 23-Feb-2015 11:50
[INFO] [GitCommitIdMojo] build.build.time = 23.02.2015 @ 12:25:22 UTC
[INFO] [GitCommitIdMojo] build.branch = de99b1a2f4be771180958a0d524851a6274e99b7
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = de99b1a
[INFO] [GitCommitIdMojo] build.commit.id = de99b1a2f4be771180958a0d524851a6274e99b7
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6890] An import generating a layer whose name already exists in a different workspace fails
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-xslt <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-xslt ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/xslt/target/gs-xslt-2.6-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-xslt ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/xslt/target/gs-xslt-2.6-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.6-SNAPSHOT/gs-xslt-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/xslt/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.6-SNAPSHOT/gs-xslt-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/xslt/target/gs-xslt-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.6-SNAPSHOT/gs-xslt-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/xslt/target/gs-xslt-2.6-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.6-SNAPSHOT/gs-xslt-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/xslt/target/gs-xslt-2.6-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-xslt/2.6-SNAPSHOT/gs-xslt-2.6-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Importer Core Module 2.6-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Importer Core Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-kml/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-kml/12-SNAPSHOT/maven-metadata.xml
971/971 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-kml/12-SNAPSHOT/maven-metadata.xml (971 B at 9.5 KB/sec)
Downloading: http://download.java.net/maven/2/org/geotools/gt-arcsde-common/12-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-arcsde-common/12-SNAPSHOT/maven-metadata.xml
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-importer-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/importer/core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-importer-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-importer-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6890] An import generating a layer whose name already exists in a different workspace fails
[INFO] [GitCommitIdMojo] build.build.time = 23.02.2015 @ 12:25:23 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-importer-core ---
[INFO] Copying 0 resource
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-importer-core ---
[INFO] Compiling 79 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/importer/core/target/classes>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.557 sec
Running org.geoserver.test.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.549 sec
Running org.geoserver.test.DefaultIdTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-importer-core ---
[INFO] Copying 20 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-importer-core ---
[INFO] Compiling 26 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/importer/core/target/test-classes>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.219 sec
Running org.geoserver.test.DuplicatePropertiesWfsTest
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/importer/core/src/test/java/org/geoserver/importer/ImporterTestSupport.java>:\[34,28\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping CSW UI Module
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.299 sec
Running org.geoserver.test.DuplicateTypeTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.015s]
[INFO] Core Platform Module .............................. SUCCESS [14.786s]
[INFO] Open Web Service Module ........................... SUCCESS [16.665s]
[INFO] Main Module ....................................... SUCCESS [3:21.105s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.603s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:17.837s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [50.838s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.104s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:12.480s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.945s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.717s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:34.468s]
[INFO] Web Map Service Module ............................ SUCCESS [7:05.496s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:36.282s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:30.973s]
[INFO] REST Support Module ............................... SUCCESS [45.297s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:26.692s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.401s]
[INFO] Core UI Module .................................... SUCCESS [2:35.029s]
[INFO] WMS UI Module ..................................... SUCCESS [1:14.077s]
[INFO] GWC UI Module ..................................... SUCCESS [1:30.538s]
[INFO] WFS UI Module ..................................... SUCCESS [45.303s]
[INFO] Demoes Module ..................................... SUCCESS [1:01.217s]
[INFO] WCS UI Module ..................................... SUCCESS [59.096s]
[INFO] Security UI Modules ............................... SUCCESS [0.212s]
[INFO] Security UI Core Module ........................... SUCCESS [3:47.546s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [47.443s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.210s]
[INFO] Printing Module ................................... SUCCESS [38.010s]
[INFO] Community Space ................................... SUCCESS [0.336s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.687s]
[INFO] Application Schema Support ........................ SUCCESS [0.337s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.846s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.313s]
[INFO] GeoSearch Index Module ............................ SUCCESS [49.790s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.645s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.226s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.582s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.380s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.470s]
[INFO] ImageMap Output Format ............................ SUCCESS [16.568s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.884s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.500s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [34.773s]
[INFO] Excel Output Format ............................... SUCCESS [1:12.203s]
[INFO] Chart external graphics support ................... SUCCESS [1.807s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.913s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.089s]
[INFO] OWS request flow controller ....................... SUCCESS [27.823s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.326s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:45.485s]
[INFO] Web Processing Service GUI ........................ SUCCESS [1:05.759s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.694s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.724s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.169s]
[INFO] Core Monitor Extension ............................ SUCCESS [29.706s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [57.878s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [54.616s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.944s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.226s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.674s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [26.824s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [2:01.988s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.354s]
[INFO] DXF WFS output format ............................. SUCCESS [39.010s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [40.095s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [1.007s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [52.487s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [38.166s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.388s]
[INFO] Importer Core Module .............................. FAILURE [15.997s]
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 35:31.230s (Wall Clock)
[INFO] Finished at: Mon Feb 23 12:25:43 UTC 2015
[INFO] Final Memory: 73M/242M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-importer-core: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-core
