See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/112/changes>
Changes:
[smithkm] [GEOS-6811] Relaxing Naming Restrictions with STRICT_PATH=false flag
[...truncated 393 lines...]
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #979 from smithkm/relax-26
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.03.2015 @ 00:04:49 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Mar-2015 00:05
[INFO] [GitCommitIdMojo] build.build.time = 19.03.2015 @ 00:05:35 UTC
[INFO] [GitCommitIdMojo] build.branch = 41ac1d5ea0adbc99e8ea8ae402a69b6bc6ded959
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 41ac1d5
[INFO] [GitCommitIdMojo] build.commit.id = 41ac1d5ea0adbc99e8ea8ae402a69b6bc6ded959
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #979 from smithkm/relax-26
[GEOS-6811] Relaxing Naming Restrictions with STRICT_PATH=false flag, Backport to 2.6
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/web/target/web-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT-tests.jar
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/platform/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-platform ---
[INFO] Compiling 39 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/platform/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-platform ---
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/platform/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-platform ---
[INFO] Compiling 15 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/platform/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-platform ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/platform/target/surefire-reports>
T E S T S
Running org.geoserver.platform.AdvancedDispatchFilterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.117 sec
Running org.geoserver.platform.GeoServerExtensionsTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.136 sec
Running org.geoserver.platform.exception.ExceptionLocalizeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.platform.exception.GeoServerExceptionsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.platform.resource.FileSystemResourceTheoryTest
Tests run: 34, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 6.535 sec <<< FAILURE!
invalid(org.geoserver.platform.resource.FileSystemResourceTheoryTest) Time elapsed: 22 sec <<< FAILURE!
java.lang.AssertionError: | invalid
at org.junit.Assert.fail(Assert.java:88)
at org.geoserver.platform.resource.FileSystemResourceTheoryTest.invalid(FileSystemResourceTheoryTest.java:57)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.junit.experimental.theories.Theories$TheoryAnchor$2.evaluate(Theories.java:175)
at org.junit.rules.ExternalResource$1.evaluate(ExternalResource.java:48)
at org.junit.rules.ExpectedException$ExpectedExceptionStatement.evaluate(ExpectedException.java:168)
at org.junit.experimental.theories.Theories$TheoryAnchor$1$1.evaluate(Theories.java:141)
at org.junit.experimental.theories.Theories$TheoryAnchor.runWithCompleteAssignment(Theories.java:127)
at org.junit.experimental.theories.Theories$TheoryAnchor.runWithAssignment(Theories.java:111)
at org.junit.experimental.theories.Theories$TheoryAnchor.evaluate(Theories.java:96)
Running org.geoserver.platform.resource.FileWrapperResourceTheoryTest
Tests run: 30, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.596 sec
Running org.geoserver.platform.resource.PathsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Results :
Failed tests: invalid(org.geoserver.platform.resource.FileSystemResourceTheoryTest): | invalid
Tests run: 92, Failures: 1, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.321s]
[INFO] Core Platform Module .............................. FAILURE [13.459s]
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.538s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 28.035s (Wall Clock)
[INFO] Finished at: Thu Mar 19 00:05:48 UTC 2015
[INFO] Final Memory: 33M/221M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-platform: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/platform/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
