See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/124/changes>
Changes:
[andrea.aime] [GEOS-7007] CQL_FILTER is ignored against a mosaic if the ResourceAccessManager also adds its own filter
[...truncated 19783 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 71ec7fb
[INFO] [GitCommitIdMojo] build.commit.id = 71ec7fbaa53ef9c87553ff3530584abcb4c92e8c
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7007] CQL_FILTER is ignored against a mosaic if the ResourceAccessManager also adds its own filter
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wcs2_0/target/gs-wcs2_0-2.6-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wcs2_0 ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wcs2_0/target/gs-wcs2_0-2.6-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.6-SNAPSHOT/gs-wcs2_0-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wcs2_0/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.6-SNAPSHOT/gs-wcs2_0-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wcs2_0/target/gs-wcs2_0-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.6-SNAPSHOT/gs-wcs2_0-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wcs2_0/target/gs-wcs2_0-2.6-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.6-SNAPSHOT/gs-wcs2_0-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wcs2_0/target/gs-wcs2_0-2.6-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.6-SNAPSHOT/gs-wcs2_0-2.6-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Processing Service Module 2.6-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Web Processing Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml (976 B at 34.0 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml
913/971 B
971/971 B
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml (971 B at 52.7 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml
913/976 B
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml (976 B at 50.2 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml
913/967 B
967/967 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml (967 B at 42.9 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7007] CQL_FILTER is ignored against a mosaic if the ResourceAccessManager also adds its own filter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 05.05.2015 @ 12:19:55 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 05-May-2015 13:22
[INFO] [GitCommitIdMojo] build.build.time = 05.05.2015 @ 13:43:41 UTC
[INFO] [GitCommitIdMojo] build.branch = 71ec7fbaa53ef9c87553ff3530584abcb4c92e8c
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 130 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target/classes>
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.953 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.714 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.198 sec
Results :
Failed tests: testRasterCrop(org.geoserver.wms.ResourceAccessManagerWMSTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
testRasterFilterGreen(org.geoserver.wms.ResourceAccessManagerWMSTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
testDoubleMosaic(org.geoserver.wms.ResourceAccessManagerWMSTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
Tests run: 651, Failures: 3, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 13 resources
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 50 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target/test-classes>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.573s]
[INFO] Core Platform Module .............................. SUCCESS [18.040s]
[INFO] Open Web Service Module ........................... SUCCESS [21.402s]
[INFO] Main Module ....................................... SUCCESS [3:46.235s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.701s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:59.905s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [3:52.893s]
[INFO] Web Coverage Service Module ....................... SUCCESS [8.075s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [59.536s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:19.534s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:18.428s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:45.462s]
[INFO] Web Map Service Module ............................ FAILURE [7:13.715s]
[INFO] REST Support Module ............................... SUCCESS [46.980s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.569s]
[INFO] Core UI Module .................................... SUCCESS [2:39.157s]
[INFO] WFS UI Module ..................................... SUCCESS [42.644s]
[INFO] Security UI Modules ............................... SUCCESS [0.298s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.398s]
[INFO] Printing Module ................................... SUCCESS [30.427s]
[INFO] Community Space ................................... SUCCESS [0.480s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.372s]
[INFO] Application Schema Support ........................ SUCCESS [0.219s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.004s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.899s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.783s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.990s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.114s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.571s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.529s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.287s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.723s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.702s]
[INFO] Excel Output Format ............................... SUCCESS [39.102s]
[INFO] Chart external graphics support ................... SUCCESS [1.435s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.855s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.862s]
[INFO] OWS request flow controller ....................... SUCCESS [29.018s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.252s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [52.118s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.908s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [56.757s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.327s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [22.296s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.367s]
[INFO] DXF WFS output format ............................. SUCCESS [45.863s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.405s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 21:47.308s (Wall Clock)
[INFO] Finished at: Tue May 05 13:43:54 UTC 2015
[INFO] Final Memory: 58M/248M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Destroying 1 processes
Destroying process..
Destroyed 1 processes
