[Geoserver-devel] Build failed in Jenkins: geoserver-2.6.x #132
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/132/changes&gt;
Changes:
[maurobartolomeoli] GEOS-7020: fixed VectorRenderingLayerIdentifier bounds / size calculation to have a more precise scale factor calculation
[...truncated 20143 lines...]
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Web Processing Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml (981 B at 25.9 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml (976 B at 59.6 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml
980/980 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml (980 B at 79.8 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml (972 B at 29.7 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1061 from mbarto/26x_geos7020
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 15.05.2015 @ 08:17:59 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 15-May-2015 08:26
[INFO] [GitCommitIdMojo] build.build.time = 15.05.2015 @ 08:45:13 UTC
[INFO] [GitCommitIdMojo] build.branch = 68c78253b98fb16a6bc7b59329d735e3ffcafd0a
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com03...
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 68c7825
[INFO] [GitCommitIdMojo] build.commit.id = 68c78253b98fb16a6bc7b59329d735e3ffcafd0a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1061 from mbarto/26x_geos7020
GEOS-7020: fixed VectorRenderingLayerIdentifier bounds / size calcula…
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 130 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target/classes&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.574 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.284 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.332 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 13 resources
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 50 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target/test-classes&gt;
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.524 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.093 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wps-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.DescribeProcessTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.424 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.113 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.769 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.445 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.94 sec
Results :
Tests in error:
  testPureLabelGenericGeometry(org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest): Invalid JSON String
  testPureLabelPolygon(org.geoserver.wms.featureinfo.RenderingBasedFeatureInfoTest): Invalid JSON String
Tests run: 661, Failures: 0, Errors: 2, Skipped: 0
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.915s]
[INFO] Core Platform Module .............................. SUCCESS [15.206s]
[INFO] Open Web Service Module ........................... SUCCESS [16.859s]
[INFO] Main Module ....................................... SUCCESS [3:19.741s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.687s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:20.906s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [46.297s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.984s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [58.114s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:20.034s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.708s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:59.919s]
[INFO] Web Map Service Module ............................ FAILURE [7:28.222s]
[INFO] REST Support Module ............................... SUCCESS [45.088s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.553s]
[INFO] Core UI Module .................................... SUCCESS [2:25.776s]
[INFO] WFS UI Module ..................................... SUCCESS [43.340s]
[INFO] Security UI Modules ............................... SUCCESS [0.316s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.225s]
[INFO] Printing Module ................................... SUCCESS [44.699s]
[INFO] Community Space ................................... SUCCESS [0.370s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.597s]
[INFO] Application Schema Support ........................ SUCCESS [0.168s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [35.291s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.386s]
[INFO] H2 DataStore Extension ............................ SUCCESS [25.977s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.016s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.606s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.358s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.383s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.962s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.410s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [34.432s]
[INFO] Excel Output Format ............................... SUCCESS [40.871s]
[INFO] Chart external graphics support ................... SUCCESS [1.249s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.914s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.780s]
[INFO] OWS request flow controller ....................... SUCCESS [29.651s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.257s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.016s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.209s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [52.524s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.225s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.074s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.269s]
[INFO] DXF WFS output format ............................. SUCCESS [40.970s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.276s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 19:35.172s (Wall Clock)
[INFO] Finished at: Fri May 15 08:45:59 UTC 2015
[INFO] Final Memory: 59M/277M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/133/changes&gt;
