See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/159/changes>
Changes:
[tbarsballe] [GEOS-7102] Importer support for non-JDBC databases
[tbarsballe] Moved WCS 1.1 schema to GeoTools
[tbarsballe] [GEOS-7098] Improve getStoreByName null handling
[...truncated 5138 lines...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.007 sec
Running org.geoserver.wfs.v2_0.GetFeatureJoinTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.225 sec
Running org.geoserver.wfs.v2_0.GetFeaturePagingTest
sleep interrupted
Thread[Thread-20,5,main] calling requestComplete
Thread[Thread-20,5,main] done
Thread[Thread-21,5,main] calling requestIncoming
Thread[Thread-21,5,main] waiting
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
Thread[Thread-23,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
Thread[Thread-23,5,main] waiting
sleep interrupted
Thread[Thread-23,5,main] calling requestComplete
Thread[Thread-23,5,main] done
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-25,5,main] waiting
sleep interrupted
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
sleep interrupted
Thread[Thread-25,5,main] calling requestComplete
Thread[Thread-25,5,main] done
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 10.549 sec <<< FAILURE!
testConcurrentRequestsSingleIPAddress(org.geoserver.flow.controller.SingleIpFlowControllerTest) Time elapsed: 10104 sec <<< FAILURE!
java.lang.AssertionError: expected:<PROCESSING> but was:<STARTED>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:743)
at org.junit.Assert.assertEquals(Assert.java:118)
at org.junit.Assert.assertEquals(Assert.java:144)
at org.geoserver.flow.controller.SingleIpFlowControllerTest.testConcurrentRequestsSingleIPAddress(SingleIpFlowControllerTest.java:57)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Results :
Failed tests: testConcurrentRequestsSingleIPAddress(org.geoserver.flow.controller.SingleIpFlowControllerTest): expected:<PROCESSING> but was:<STARTED>
Tests run: 20, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Catalog Services for the Web parent
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
[INFO]
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping Security UI Modules
[INFO]
[INFO] Skipping Printing Module
[INFO]
[INFO] Skipping HTTP Proxy Extension
[INFO]
[INFO] Skipping ArcSDE DataStore Extension
[INFO]
[INFO] Skipping H2 DataStore Extension
[INFO]
[INFO] Skipping Teradata DataStore Extension
[INFO]
[INFO] Skipping GeoServer CSS Styling
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.576 sec
Running org.geoserver.wfs.v2_0.GetFeatureTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.870s]
[INFO] Core Platform Module .............................. SUCCESS [14.960s]
[INFO] Open Web Service Module ........................... SUCCESS [21.237s]
[INFO] Main Module ....................................... SUCCESS [3:20.309s]
[INFO] GeoServer Security Modules ........................ SUCCESS [3.891s]
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SUCCESS [3.376s]
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [45.829s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.827s]
[INFO] Core UI Module .................................... SUCCESS [2:34.235s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.274s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.426s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.206s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.777s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [2.001s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.434s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.436s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.124s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.543s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.206s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.818s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.312s]
[INFO] OWS request flow controller ....................... FAILURE [39.731s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.835s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.391s]
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.411s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8:24.014s (Wall Clock)
[INFO] Finished at: Wed Jul 08 21:38:10 UTC 2015
[INFO] Final Memory: 44M/291M
Tests run: 47, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.982 sec
Running org.geoserver.wfs.v2_0.GetFeatureWithLockTest
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-control-flow: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/control-flow/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-control-flow
