[Geoserver-devel] Build failed in Jenkins: geoserver-2.6.x #175
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/175/&gt;
[...truncated 11992 lines...]
[INFO]
[INFO] Building Web Processing Service Module 2.6-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Web Processing Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.6
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/12-SNAPSHOT/maven-metadata.xml (981 B at 26.6 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/12-SNAPSHOT/maven-metadata.xml (976 B at 27.2 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/12-SNAPSHOT/maven-metadata.xml (981 B at 27.4 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml
972/972 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-geojson/12-SNAPSHOT/maven-metadata.xml (972 B at 52.7 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7075] JSON matched features count bug with spatial filter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 16.08.2015 @ 11:54:23 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 31-Aug-2015 20:54
[INFO] [GitCommitIdMojo] build.build.time = 31.08.2015 @ 21:13:59 UTC
[INFO] [GitCommitIdMojo] build.branch = 280a24fd2e062111b172effe1d217cbc745ab96a
[INFO] [GitCommitIdMojo] build.commit.user.email = Paul.Biskup@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Paul Biskup
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 280a24f
[INFO] [GitCommitIdMojo] build.commit.id = 280a24fd2e062111b172effe1d217cbc745ab96a
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7075] JSON matched features count bug with spatial filter
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 9 resources
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 130 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target/classes&gt;
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.217 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.564 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.718 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 13 resources
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 50 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target/test-classes&gt;
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.482 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.595 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-wps-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/extension/wps/wps-core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.DescribeProcessTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.732 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.1 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.267 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.009 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.893 sec
Results :
Failed tests: testExplicitMaxTimeCoverageSelector(org.geoserver.wms.dimension.RasterTimeDimensionDefaultValueTest): Default time should be the biggest one
Tests run: 661, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] Skipping Catalog Services for the Web - Simple CatalogStore implementation
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation extensions
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.930s]
[INFO] Core Platform Module .............................. SUCCESS [16.230s]
[INFO] Open Web Service Module ........................... SUCCESS [26.080s]
[INFO] Main Module ....................................... SUCCESS [3:24.043s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.137s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.953s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [47.636s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.142s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:03.212s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:22.303s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:07.772s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:49.037s]
[INFO] Web Map Service Module ............................ FAILURE [7:34.187s]
[INFO] REST Support Module ............................... SUCCESS [46.008s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.457s]
[INFO] Core UI Module .................................... SUCCESS [2:27.499s]
[INFO] WFS UI Module ..................................... SUCCESS [45.022s]
[INFO] Security UI Modules ............................... SUCCESS [0.450s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.340s]
[INFO] Printing Module ................................... SUCCESS [44.598s]
[INFO] Community Space ................................... SUCCESS [0.394s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.479s]
[INFO] Application Schema Support ........................ SUCCESS [0.223s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.458s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.360s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.555s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [4.924s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.221s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.409s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.468s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.354s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.656s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [39.398s]
[INFO] Excel Output Format ............................... SUCCESS [42.996s]
[INFO] Chart external graphics support ................... SUCCESS [3.771s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.551s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.467s]
[INFO] OWS request flow controller ....................... SUCCESS [31.788s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.438s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.683s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.192s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [51.531s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.381s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [26.763s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.413s]
[INFO] DXF WFS output format ............................. SUCCESS [41.806s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.414s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 20:02.414s (Wall Clock)
[INFO] Finished at: Mon Aug 31 21:14:45 UTC 2015
[INFO] Final Memory: 58M/226M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/176/changes&gt;
