[Geoserver-devel] Build failed in Jenkins: geoserver-2.6.x #77
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/77/changes&gt;
Changes:
[lago.88] [GEOS-6627]GWC causes a wrong handling of the ImageIO and ImageIO-Ext plugins
[...truncated 20615 lines...]
Downloaded: http://repo.boundlessgeo.com/main/org/geowebcache/gwc-diskquota-core/1.6-SNAPSHOT/maven-metadata.xml (2 KB at 44.6 KB/sec)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.116 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-gwc ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-gwc ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #854 from n-lagomarsini/GEOS-6627_2_6
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 07.01.2015 @ 09:03:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 07-Jan-2015 09:04
[INFO] [GitCommitIdMojo] build.build.time = 07.01.2015 @ 09:27:10 UTC
[INFO] [GitCommitIdMojo] build.branch = 2f11e3d9b1a908c9c6f27a348a397f327920d453
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2f11e3d
[INFO] [GitCommitIdMojo] build.commit.id = 2f11e3d9b1a908c9c6f27a348a397f327920d453
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #854 from n-lagomarsini/GEOS-6627_2_6
[GEOS-6627]GWC causes a wrong handling of the ImageIO and ImageIO-Ext plugins (Backport on 2.6.x branch)
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gwc ---
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gwc ---
[INFO] Compiling 40 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/target/classes&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.193 sec
Running org.geoserver.wps.gs.PagedUniqueProcessTest
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.018 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-gwc ---
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-gwc ---
[INFO] Compiling 21 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/target/test-classes&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.422 sec
Running org.geoserver.wps.gs.QueryProcessTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.111 sec
Running org.geoserver.wps.gs.RangeLookupTest
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/test/java/org/geoserver/gwc/wms/TestFullWMSBeans.java&gt;:\[12,25\] error: cannot find symbol
[ERROR] package org.geowebcache.io
<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/test/java/org/geoserver/gwc/wms/TestFullWMSBeans.java&gt;:\[32,41\] error: cannot find symbol
[ERROR] class TestFullWMSBeans
<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/test/java/org/geoserver/gwc/wms/TestFullWMSBeans.java&gt;:\[35,8\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/test/java/org/geoserver/gwc/wms/TestFullWMSBeans.java&gt;:\[35,35\] error: cannot find symbol
[INFO] 4 errors
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping Security UI Core Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping GeoServer libjpeg-turbo Module
[INFO]
[INFO] Skipping GeoServer Data Importer
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping GeoSearch Index Module
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.958 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.377 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.384s]
[INFO] Core Platform Module .............................. SUCCESS [14.389s]
[INFO] Open Web Service Module ........................... SUCCESS [17.823s]
[INFO] Main Module ....................................... SUCCESS [3:28.060s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.681s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:19.540s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [45.502s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.385s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:05.858s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.317s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:05.544s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:51.262s]
[INFO] Web Map Service Module ............................ SUCCESS [7:08.665s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:26.009s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [19.797s]
[INFO] REST Support Module ............................... SUCCESS [45.299s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.553s]
[INFO] Core UI Module .................................... SUCCESS [2:33.977s]
[INFO] WFS UI Module ..................................... SUCCESS [45.983s]
[INFO] Security UI Modules ............................... SUCCESS [0.625s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.186s]
[INFO] Printing Module ................................... SUCCESS [41.390s]
[INFO] Community Space ................................... SUCCESS [0.242s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.373s]
[INFO] Application Schema Support ........................ SUCCESS [0.156s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [38.066s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [29.613s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.868s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.400s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.557s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.795s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.450s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.718s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.536s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [38.160s]
[INFO] Excel Output Format ............................... SUCCESS [43.213s]
[INFO] Chart external graphics support ................... SUCCESS [2.049s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.396s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.701s]
[INFO] OWS request flow controller ....................... SUCCESS [30.492s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.233s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [47.676s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.712s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.454s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [55.160s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.449s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.973s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.043s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.417s]
[INFO] DXF WFS output format ............................. SUCCESS [41.226s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.136s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [57.134s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 22:36.332s (Wall Clock)
[INFO] Finished at: Wed Jan 07 09:27:31 UTC 2015
[INFO] Final Memory: 61M/191M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/test/java/org/geoserver/gwc/wms/TestFullWMSBeans.java&gt;:\[32,41\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/test/java/org/geoserver/gwc/wms/TestFullWMSBeans.java&gt;:\[35,8\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/test/java/org/geoserver/gwc/wms/TestFullWMSBeans.java&gt;:\[35,35\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/78/&gt;
