[Geoserver-devel] Build failed in Jenkins: geoserver-2.6.x #94
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/94/changes&gt;
Changes:
[andrea.aime] [GEOS-6867] Filter validation fails in WFS when a join needs to be reordered, and has local, non joining filters
[...truncated 21096 lines...]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [39.777s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.484s]
[INFO] H2 DataStore Extension ............................ SUCCESS [20.765s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.091s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [2.809s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.408s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.411s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.981s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.503s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [35.902s]
[INFO] Excel Output Format ............................... SUCCESS [36.331s]
[INFO] Chart external graphics support ................... SUCCESS [1.039s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.895s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.156s]
[INFO] OWS request flow controller ....................... SUCCESS [28.828s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.295s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [51.772s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.151s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.205s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SUCCESS [53.413s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.342s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [27.555s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [27.360s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.281s]
[INFO] DXF WFS output format ............................. SUCCESS [38.731s]
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.276s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [1:05.145s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 22:45.708s (Wall Clock)
[INFO] Finished at: Mon Feb 02 19:14:01 UTC 2015
[INFO] Final Memory: 61M/196M
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.128 sec
Running org.geoserver.wps.gs.UniqueProcessTest
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[83,32\] error: package org.geowebcache.diskquota does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[84,32\] error: package org.geowebcache.diskquota does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[85,32\] error: package org.geowebcache.diskquota does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[88,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[89,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[90,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[91,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[177,12\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/JDBCConfigurationStorage.java&gt;:\[18,32\] error: cannot find symbol
[ERROR] package org.geowebcache.diskquota
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/JDBCConfigurationStorage.java&gt;:\[19,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[197,49\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1026,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1034,12\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1045,36\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1062,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1072,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1088,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1122,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1143,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/JDBCConfigurationStorage.java&gt;:\[53,49\] error: cannot find symbol
[ERROR] class JDBCConfigurationStorage
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[8,39\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[8,0\] error: static import only from classes and interfaces
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[19,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[20,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[22,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[23,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[26,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[37,52\] error: cannot find symbol
[ERROR] class QuotaStoreProvider
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[42,4\] error: cannot find symbol
[ERROR] class ConfigurableQuotaStoreProvider
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[48,42\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[48,63\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[130,14\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[139,12\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[19,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[20,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[21,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[22,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[24,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[25,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[27,40\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[29,25\] error: cannot find symbol
[ERROR] class DummyQuotaStore
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[31,4\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[33,27\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[43,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[48,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[61,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[66,36\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[73,15\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[78,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[83,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[87,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[92,40\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[92,57\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[93,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[97,69\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[97,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[129,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[134,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[139,34\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[139,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[11,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[12,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[13,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[14,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[16,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[17,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[25,47\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[29,12\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[31,25\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[35,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[39,34\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[43,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[51,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[55,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[67,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[71,36\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[75,15\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[79,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[83,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[87,40\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[87,57\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[88,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[92,69\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[92,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[96,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[100,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[104,34\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[104,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[587,12\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1003,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1018,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1030,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1048,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1094,14\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1094,32\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1096,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1096,37\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1127,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1128,13\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1132,13\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/95/changes&gt;
Changes:
[andrea.aime] [GEOS-6869] Join filter validator applies the joining capabilities checks also to non joining filters
[...truncated 21013 lines...]
[INFO] Application Schema Support ........................ SUCCESS [0.156s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.666s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.106s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.520s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.048s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.587s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.667s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.540s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.029s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.624s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [37.627s]
[INFO] Excel Output Format ............................... SUCCESS [40.724s]
[INFO] Chart external graphics support ................... SUCCESS [2.899s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.566s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.743s]
[INFO] OWS request flow controller ....................... SUCCESS [29.244s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.234s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.649s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [4.263s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.222s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [57.662s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.369s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [23.156s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [28.281s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.525s]
[INFO] DXF WFS output format ............................. SUCCESS [43.552s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.222s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [59.020s]
[INFO] Total time: 22:12.221s (Wall Clock)
[INFO] Finished at: Tue Feb 03 12:07:48 UTC 2015
[INFO] Final Memory: 61M/175M
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x/96/&gt;
