[Geoserver-devel] Build failed in Jenkins: geoserver-2.6.x-nightly #169
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/169/&gt;
[...truncated 2454 lines...]
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 2:55.423s
[INFO] Finished at: Thu Jan 29 04:22:14 UTC 2015
[INFO] Final Memory: 50M/216M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[83,32\] error: package org.geowebcache.diskquota does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[84,32\] error: package org.geowebcache.diskquota does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[85,32\] error: package org.geowebcache.diskquota does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[88,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[89,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[90,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[91,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[177,12\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/JDBCConfigurationStorage.java&gt;:\[18,32\] error: cannot find symbol
[ERROR] package org.geowebcache.diskquota
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/JDBCConfigurationStorage.java&gt;:\[19,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[197,49\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1026,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1034,12\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1045,36\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1062,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1072,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1088,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1122,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1143,11\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/JDBCConfigurationStorage.java&gt;:\[53,49\] error: cannot find symbol
[ERROR] class JDBCConfigurationStorage
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[8,39\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[8,0\] error: static import only from classes and interfaces
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[19,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[20,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[22,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[23,32\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[26,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[37,52\] error: cannot find symbol
[ERROR] class QuotaStoreProvider
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[42,4\] error: cannot find symbol
[ERROR] class ConfigurableQuotaStoreProvider
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[48,42\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[48,63\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[130,14\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[139,12\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[19,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[20,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[21,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[22,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[24,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[25,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[27,40\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[29,25\] error: cannot find symbol
[ERROR] class DummyQuotaStore
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[31,4\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[33,27\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[43,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[48,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[61,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[66,36\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[73,15\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[78,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[83,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[87,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[92,40\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[92,57\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[93,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[97,69\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[97,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[129,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[134,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[139,34\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/DummyQuotaStore.java&gt;:\[139,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[11,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[12,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[13,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[14,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[16,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[17,40\] error: package org.geowebcache.diskquota.storage does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[25,47\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[29,12\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[31,25\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[35,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[39,34\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[43,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[51,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[55,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[67,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[71,36\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[75,15\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[79,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[83,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[87,40\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[87,57\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[88,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[92,69\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[92,23\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[96,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[100,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[104,34\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStore.java&gt;:\[104,11\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[587,12\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1003,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1018,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1030,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1048,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1094,14\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1094,32\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1096,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1096,37\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1127,8\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1128,13\] error: cannot find symbol
[ERROR] class GWC
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/GWC.java&gt;:\[1132,13\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/170/&gt;
[...truncated 2858 lines...]
[INFO] Total time: 3:05.946s
[INFO] Finished at: Fri Jan 30 04:22:21 UTC 2015
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/171/&gt;
[...truncated 2797 lines...]
[INFO] Total time: 3:05.082s
[INFO] Finished at: Sat Jan 31 04:22:19 UTC 2015
[INFO] Final Memory: 51M/217M
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/172/&gt;
[...truncated 2850 lines...]
[INFO] Total time: 3:01.171s
[INFO] Finished at: Sun Feb 01 04:22:14 UTC 2015
[INFO] Final Memory: 50M/218M
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/173/&gt;
[...truncated 2848 lines...]
[INFO] Total time: 3:08.977s
[INFO] Finished at: Mon Feb 02 04:22:21 UTC 2015
[INFO] Final Memory: 50M/173M
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/174/changes&gt;
Changes:
[andrea.aime] [GEOS-6867] Filter validation fails in WFS when a join needs to be reordered, and has local, non joining filters
[...truncated 2754 lines...]
[INFO] Total time: 3:01.026s
[INFO] Finished at: Tue Feb 03 04:22:14 UTC 2015
[INFO] Final Memory: 51M/213M
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] class GWC
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/175/changes&gt;
