See <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/410/>
[...truncated 2958 lines...]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ web ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ web ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Fix missing close of resource input stream leading to close being called on the Finalizer thread.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.09.2015 @ 17:15:46 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Oct-2015 04:19
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 04:23:37 UTC
[INFO] [GitCommitIdMojo] build.branch = 2e715eec0db1059b4b5cc2063f926737e8e8bbd3
[INFO] [GitCommitIdMojo] build.commit.user.email = groldan@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Gabriel Roldan
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2e715ee
[INFO] [GitCommitIdMojo] build.commit.id = 2e715eec0db1059b4b5cc2063f926737e8e8bbd3
[INFO] [GitCommitIdMojo] build.commit.message.full = Fix missing close of resource input stream leading to close being called on the Finalizer thread.
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/web/target/web-2.6-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 04:23:38 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ web ---
[INFO] Copying gt-api-12-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/web/target/dependency/gt-api-12-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.6-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/web/target/dependency/gwc-core-1.6-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.6.x-nightly/ws/src/web/target/web-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Core UI Module 2.6-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://maven.restlet.org/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://repo.maven.apache.org/maven2/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.908s]
[INFO] Core Platform Module .............................. SUCCESS [8.552s]
[INFO] Open Web Service Module ........................... SUCCESS [19.022s]
[INFO] Main Module ....................................... SUCCESS [45.905s]
[INFO] GeoServer Security Modules ........................ SUCCESS [3.087s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.745s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.642s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.712s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [9.257s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [12.208s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [12.095s]
[INFO] Web Feature Service Module ........................ SUCCESS [18.557s]
[INFO] Web Map Service Module ............................ SUCCESS [21.075s]
[INFO] KML support for GeoServer ......................... SUCCESS [11.077s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [15.250s]
[INFO] REST Support Module ............................... SUCCESS [6.606s]
[INFO] REST Configuration Service Module ................. SUCCESS [12.030s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.264s]
[INFO] Core UI Module .................................... FAILURE [2.302s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 4:00.562s
[INFO] Finished at: Tue Oct 06 04:23:40 UTC 2015
[INFO] Final Memory: 56M/291M
[ERROR] Failed to execute goal on project gs-web-core: Could not resolve dependencies for project org.geoserver.web:gs-web-core:jar:2.6-SNAPSHOT: Failed to collect dependencies for [org.apache.wicket:wicket:jar:1.4.12 (compile), org.apache.wicket:wicket-extensions:jar:1.4.12 (compile), org.apache.wicket:wicket-spring:jar:1.4.12 (compile), org.wicketstuff:htmlvalidator:jar:1.2 (compile), org.slf4j:slf4j-log4j12:jar:1.4.2 (compile), log4j:log4j:jar:1.2.14 (compile), org.geoserver:gs-main:jar:2.6-SNAPSHOT (compile), org.geoserver:gs-platform:jar:2.6-SNAPSHOT (compile), org.geoserver:gs-main:jar:tests:2.6-SNAPSHOT (test), com.mockrunner:mockrunner:jar:0.3.6 (test), org.mortbay.jetty:jetty:jar:6.1.8 (test), org.geotools:gt-coverage:jar:12-SNAPSHOT (compile), org.geotools:gt-data:jar:12-SNAPSHOT (compile), org.geotools:gt-shapefile:jar:12-SNAPSHOT (compile), org.geotools.jdbc:gt-jdbc-postgis:jar:12-SNAPSHOT (compile), org.geotools:gt-wfs-ng:jar:12-SNAPSHOT (compile), org.geotools:gt-jdbc:jar:12-SNAPSHOT (compile), org.geotools:gt-metadata:jar:12-SNAPSHOT (compile), org.geotools:gt-arcgrid:jar:12-SNAPSHOT (compile), org.geotools:gt-geotiff:jar:12-SNAPSHOT (compile), org.geotools:gt-gtopo30:jar:12-SNAPSHOT (compile), org.geotools:gt-image:jar:12-SNAPSHOT (compile), org.springframework.security:spring-security-web:jar:3.1.0.RELEASE (compile), org.bouncycastle:bcprov-jdk14:jar:1.46 (compile), org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:12-SNAPSHOT (compile), org.geotools:gt-main:jar:12-SNAPSHOT (compile), junit:junit:jar:4.11 (test), org.geowebcache:gwc-core:jar:1.6-SNAPSHOT (compile)]: Failed to read artifact descriptor for org.wicketstuff:htmlvalidator:jar:1.2: Could not transfer artifact org.wicketstuff:htmlvalidator:pom:1.2 from/to boundlessgeo (https://boundless.artifactoryonline.com/boundless/main): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
