[Geoserver-devel] Build failed in Jenkins: geoserver-2.7.x #1
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/1/&gt;
[...truncated 24846 lines...]
[INFO] [GitCommitIdMojo] build.commit.id = 3a8e03802363492e7a788b3f853ade7123dca72d
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #932 from boundlessgeo/importer_docs
Adding Importer docs
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-xslt ---
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/xslt/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-xslt ---
[INFO] Compiling 12 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/xslt/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-xslt ---
[INFO] Copying 0 resource
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-xslt ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/xslt/target/test-classes&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 38.868 sec
Running org.geoserver.test.BBoxFilterTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-xslt ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/xslt/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.xslt.GetFeatureXSLTTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.191 sec
Running org.geoserver.test.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.281 sec
Running org.geoserver.test.DefaultIdTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.78 sec
Running org.geoserver.test.DuplicatePropertiesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.99 sec
Running org.geoserver.test.DuplicateTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.503 sec
Running org.geoserver.test.EncodeIfEmptyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.017 sec
Running org.geoserver.test.FeatureChainingWfsTest
Formats are: {HTML=HTML, text/html; subtype=xslt=text/html; subtype=xslt}
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 37.454 sec <<< FAILURE!
testNoOutputFormats(org.geoserver.wfs.xslt.GetFeatureXSLTTest) Time elapsed: 18 sec <<< FAILURE!
java.lang.AssertionError
  at org.junit.Assert.fail(Assert.java:86)
  at org.junit.Assert.assertTrue(Assert.java:41)
  at org.junit.Assert.assertTrue(Assert.java:52)
  at org.geoserver.wfs.xslt.GetFeatureXSLTTest.setupXSLT(GetFeatureXSLTTest.java:47)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
Running org.geoserver.wfs.xslt.config.TransformRepositoryTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.509 sec
Running org.geoserver.wfs.xslt.rest.TransformRestTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.122 sec
Results :
Failed tests: testNoOutputFormats(org.geoserver.wfs.xslt.GetFeatureXSLTTest)
Tests run: 29, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping CSW UI Module
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.015 sec
Running org.geoserver.test.FeatureGML32Test
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.188s]
[INFO] Core Platform Module .............................. SUCCESS [15.080s]
[INFO] Open Web Service Module ........................... SUCCESS [16.584s]
[INFO] Main Module ....................................... SUCCESS [3:20.412s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.784s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:21.950s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.542s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.760s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:10.771s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.339s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:09.348s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:49.924s]
[INFO] Web Map Service Module ............................ SUCCESS [7:29.927s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:24.235s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:42.347s]
[INFO] REST Support Module ............................... SUCCESS [46.607s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:26.007s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.114s]
[INFO] Core UI Module .................................... SUCCESS [2:30.737s]
[INFO] WMS UI Module ..................................... SUCCESS [1:08.495s]
[INFO] GWC UI Module ..................................... SUCCESS [1:35.952s]
[INFO] WFS UI Module ..................................... SUCCESS [43.915s]
[INFO] Demoes Module ..................................... SUCCESS [1:11.549s]
[INFO] Security UI Modules ............................... SUCCESS [0.440s]
[INFO] Security UI Core Module ........................... SUCCESS [3:46.309s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SUCCESS [46.228s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.163s]
[INFO] Printing Module ................................... SUCCESS [35.549s]
[INFO] Community Space ................................... SUCCESS [0.175s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.756s]
[INFO] Application Schema Support ........................ SUCCESS [0.172s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [40.457s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [30.444s]
[INFO] GeoSearch Index Module ............................ SUCCESS [44.864s]
[INFO] H2 DataStore Extension ............................ SUCCESS [24.608s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.160s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.665s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.992s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.541s]
[INFO] ImageMap Output Format ............................ SUCCESS [18.332s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.992s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.241s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [39.474s]
[INFO] Excel Output Format ............................... SUCCESS [39.411s]
[INFO] Chart external graphics support ................... SUCCESS [1.728s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.669s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.698s]
[INFO] OWS request flow controller ....................... SUCCESS [32.157s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.194s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:28.694s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [33.549s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [50.294s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.868s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.410s]
[INFO] Core Monitor Extension ............................ SUCCESS [25.504s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... FAILURE [1:00.137s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [53.464s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [39.843s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.314s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [24.676s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [25.992s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:51.937s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.368s]
[INFO] DXF WFS output format ............................. SUCCESS [37.071s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [34.878s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.204s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [1:00.883s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [35.058s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [35.113s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.187s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 34:54.902s (Wall Clock)
[INFO] Finished at: Sat Feb 21 21:39:29 UTC 2015
[INFO] Final Memory: 264M/674M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-xslt: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/xslt/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-xslt
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/2/&gt;
