See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/161/changes>
Changes:
[ksmith] Add classes to XStream whitelist for JDBCConfig
[...truncated 12762 lines...]
<enabled>true</enabled>
<name>WPS</name>
<title>Prototype GeoServer WPS</title>
<versions>
<org.geotools.util.Version>
<version>1.0.0</version>
</org.geotools.util.Version>
</versions>
<citeCompliant>false</citeCompliant>
<schemaBaseURL>http://schemas.opengis.net</schemaBaseURL>
<verbose>false</verbose>
<connectionTimeout>30.0</connectionTimeout>
<resourceExpirationTimeout>300</resourceExpirationTimeout>
<maxSynchronousProcesses>4</maxSynchronousProcesses>
<maxAsynchronousProcesses>4</maxAsynchronousProcesses>
<processGroups>
<processGroup>
<factoryClass>org.geotools.process.geometry.GeometryProcessFactory</factoryClass>
<enabled>false</enabled>
<filteredProcesses>
<accessInfo>
<name>geo:Area</name>
<validators>
<entry key="geom">
<maxSizeValidator>
<maxSizeMB>10</maxSizeMB>
</maxSizeValidator>
</entry>
</validators>
</accessInfo>
</filteredProcesses>
</processGroup>
<processGroup>
<factoryClass>org.geotools.process.raster.RasterProcessFactory</factoryClass>
<filteredProcesses>
<accessInfo>
<name>ras:Contour</name>
<validators>
<entry key="levels">
<rangeValidator>
<range>
<minValue>-8000.0</minValue>
<maxValue>8000.0</maxValue>
</range>
</rangeValidator>
</entry>
<maxMultiplicityValidator>
<maxInstances>3</maxInstances>
</maxMultiplicityValidator>
</entry>
</validators>
</accessInfo>
</processGroup>
</processGroups>
<maxComplexInputSize>0</maxComplexInputSize>
<maxSynchronousExecutionTime>0</maxSynchronousExecutionTime>
<maxAsynchronousExecutionTime>0</maxAsynchronousExecutionTime>
</wps>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.769 sec
Running org.geoserver.wps.gs.AggregateProcessTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.665 sec
Running org.geoserver.wps.gs.BinaryProcessingsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.724 sec
Running org.geoserver.wps.gs.BufferFeatureCollectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.084 sec
Running org.geoserver.wps.gs.ClipProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.058 sec
Running org.geoserver.wps.gs.CollectGeometriesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.025 sec
Running org.geoserver.wps.gs.ContourProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.562 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.934 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.75 sec
Running org.geoserver.wps.gs.CropCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.169 sec
Running org.geoserver.wps.gs.GeorectifyCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.101 sec
Running org.geoserver.wps.gs.ImportProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.002 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.883 sec
Running org.geoserver.wps.gs.PagedUniqueProcessTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.574 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.255 sec
Running org.geoserver.wps.gs.QueryProcessTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.149 sec
Running org.geoserver.wps.gs.RangeLookupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.838 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.309 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.045 sec
Running org.geoserver.wps.gs.ReprojectProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.723 sec
Running org.geoserver.wps.gs.ScaleCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.583 sec
Running org.geoserver.wps.gs.SimplifyProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.708 sec
Running org.geoserver.wps.gs.StoreCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.4 sec
Running org.geoserver.wps.gs.StyleCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.179 sec
Running org.geoserver.wps.gs.UnionFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.244 sec
Running org.geoserver.wps.gs.UniqueProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.705 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.906 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.027 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.891 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.389 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.839 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.51 sec
Running org.geoserver.wps.security.WPSAccessChallangeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.939 sec
Running org.geoserver.wps.security.WPSAccessHideTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.537 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.543 sec
Results :
Failed tests: testAsyncExecutionLimits(org.geoserver.wps.InputLimitsTest): Expecting to find matches for Xpath //wps:Status/wps:ProcessFailed
Tests run: 222, Failures: 1, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.883s]
[INFO] Core Platform Module .............................. SUCCESS [15.421s]
[INFO] Open Web Service Module ........................... SUCCESS [25.135s]
[INFO] Main Module ....................................... SUCCESS [3:41.133s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.368s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [59.623s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [36.963s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.471s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [49.537s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [51.215s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:27.706s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:21.726s]
[INFO] Web Map Service Module ............................ SUCCESS [5:47.016s]
[INFO] KML support for GeoServer ......................... SUCCESS [58.639s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:54.066s]
[INFO] REST Support Module ............................... SUCCESS [26.745s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:15.049s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.184s]
[INFO] Core UI Module .................................... SUCCESS [1:46.019s]
[INFO] WMS UI Module ..................................... SUCCESS [46.891s]
[INFO] GWC UI Module ..................................... SUCCESS [1:00.189s]
[INFO] WFS UI Module ..................................... SUCCESS [26.610s]
[INFO] Demoes Module ..................................... SUCCESS [42.676s]
[INFO] WCS UI Module ..................................... SUCCESS [32.424s]
[INFO] Security UI Modules ............................... SUCCESS [0.166s]
[INFO] Security UI Core Module ........................... SUCCESS [2:33.218s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:51.546s]
[INFO] Security UI LDAP Module ........................... SUCCESS [47.335s]
[INFO] REST UI Module .................................... SUCCESS [28.460s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.153s]
[INFO] Printing Module ................................... SUCCESS [25.512s]
[INFO] Community Space ................................... SUCCESS [0.114s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [11.791s]
[INFO] GeoServer Web Application ......................... SUCCESS [9.902s]
[INFO] Application Schema Support ........................ SUCCESS [0.158s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:19.473s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [29.099s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.231s]
[INFO] GeoSearch Index Module ............................ SUCCESS [28.944s]
[INFO] H2 DataStore Extension ............................ SUCCESS [17.503s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.151s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.431s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.500s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.499s]
[INFO] ImageMap Output Format ............................ SUCCESS [16.578s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.123s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.372s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [26.641s]
[INFO] Excel Output Format ............................... SUCCESS [39.198s]
[INFO] Chart external graphics support ................... SUCCESS [0.621s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.803s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.418s]
[INFO] OWS request flow controller ....................... SUCCESS [21.586s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.122s]
[INFO] Web Processing Service Module ..................... FAILURE [3:28.138s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 46:14.013s
[INFO] Finished at: Fri Aug 14 02:02:17 UTC 2015
[INFO] Final Memory: 68M/171M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
