[Geoserver-devel] Build failed in Jenkins: geoserver-2.7.x #183
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/183/changes&gt;
Changes:
[andrea.aime] [GEOS-7213] Check geoserverlogfile appender against FileAppender
[...truncated 13614 lines...]
  <enabled>true</enabled>
  <name>WPS</name>
  <title>Prototype GeoServer WPS</title>
  <versions>
    <org.geotools.util.Version>
      <version>1.0.0</version>
    </org.geotools.util.Version>
  </versions>
  <citeCompliant>false</citeCompliant>
  <schemaBaseURL>http://schemas.opengis.net</schemaBaseURL>
  <verbose>false</verbose>
  <connectionTimeout>30.0</connectionTimeout>
  <resourceExpirationTimeout>300</resourceExpirationTimeout>
  <maxSynchronousProcesses>4</maxSynchronousProcesses>
  <maxAsynchronousProcesses>4</maxAsynchronousProcesses>
  <processGroups>
    <processGroup>
      <factoryClass>org.geotools.process.geometry.GeometryProcessFactory</factoryClass>
      <enabled>false</enabled>
      <filteredProcesses>
        <accessInfo>
          <name>geo:Area</name>
          <validators>
            <entry key="geom">
              <maxSizeValidator>
                <maxSizeMB>10</maxSizeMB>
              </maxSizeValidator>
            </entry>
          </validators>
        </accessInfo>
      </filteredProcesses>
    </processGroup>
    <processGroup>
      <factoryClass>org.geotools.process.raster.RasterProcessFactory</factoryClass>
      <filteredProcesses>
        <accessInfo>
          <name>ras:Contour</name>
          <validators>
            <entry key="levels">
              <rangeValidator>
                <range>
                  <minValue>-8000.0</minValue>
                  <maxValue>8000.0</maxValue>
                </range>
              </rangeValidator>
            </entry>
              <maxMultiplicityValidator>
                <maxInstances>3</maxInstances>
              </maxMultiplicityValidator>
            </entry>
          </validators>
        </accessInfo>
    </processGroup>
  </processGroups>
  <maxComplexInputSize>0</maxComplexInputSize>
  <maxSynchronousExecutionTime>0</maxSynchronousExecutionTime>
  <maxAsynchronousExecutionTime>0</maxAsynchronousExecutionTime>
</wps>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.826 sec
Running org.geoserver.wps.gs.AggregateProcessTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.523 sec
Running org.geoserver.wps.gs.BinaryProcessingsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.612 sec
Running org.geoserver.wps.gs.BufferFeatureCollectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.849 sec
Running org.geoserver.wps.gs.ClipProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.795 sec
Running org.geoserver.wps.gs.CollectGeometriesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.653 sec
Running org.geoserver.wps.gs.ContourProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.669 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.155 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.545 sec
Running org.geoserver.wps.gs.CropCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.042 sec
Running org.geoserver.wps.gs.GeorectifyCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.945 sec
Running org.geoserver.wps.gs.ImportProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.757 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.947 sec
Running org.geoserver.wps.gs.PagedUniqueProcessTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.727 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.323 sec
Running org.geoserver.wps.gs.QueryProcessTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.972 sec
Running org.geoserver.wps.gs.RangeLookupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.533 sec
Running org.geoserver.wps.gs.RasterAsPointCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.866 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.824 sec
Running org.geoserver.wps.gs.ReprojectProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.663 sec
Running org.geoserver.wps.gs.ScaleCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.417 sec
Running org.geoserver.wps.gs.SimplifyProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.641 sec
Running org.geoserver.wps.gs.StoreCoverageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.675 sec
Running org.geoserver.wps.gs.StyleCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.031 sec
Running org.geoserver.wps.gs.UnionFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.628 sec
Running org.geoserver.wps.gs.UniqueProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.682 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.549 sec
Running org.geoserver.wps.jts.BeanProcessFactoryTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.853 sec
Running org.geoserver.wps.jts.GeometryProcessWPSTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.624 sec
Running org.geoserver.wps.process.ProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.09 sec
Running org.geoserver.wps.process.WPSConfigProcessFilterTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.416 sec
Running org.geoserver.wps.resource.WPSResourceManagerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.323 sec
Running org.geoserver.wps.security.WPSAccessChallangeTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.656 sec
Running org.geoserver.wps.security.WPSAccessHideTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.668 sec
Running org.geoserver.wps.security.WPSAccessMixedTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.665 sec
Results :
Failed tests: testAsyncExecutionLimits(org.geoserver.wps.InputLimitsTest): Expecting to find matches for Xpath //wps:Status/wps:ProcessFailed
Tests run: 222, Failures: 1, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.539s]
[INFO] Core Platform Module .............................. SUCCESS [14.727s]
[INFO] Open Web Service Module ........................... SUCCESS [26.250s]
[INFO] Main Module ....................................... SUCCESS [3:28.174s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.888s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [56.000s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [37.699s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.252s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [48.061s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [53.605s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:29.290s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:09.959s]
[INFO] Web Map Service Module ............................ SUCCESS [5:40.679s]
[INFO] KML support for GeoServer ......................... SUCCESS [57.569s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:50.582s]
[INFO] REST Support Module ............................... SUCCESS [25.595s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:16.104s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.137s]
[INFO] Core UI Module .................................... SUCCESS [1:42.164s]
[INFO] WMS UI Module ..................................... SUCCESS [44.324s]
[INFO] GWC UI Module ..................................... SUCCESS [58.735s]
[INFO] WFS UI Module ..................................... SUCCESS [25.823s]
[INFO] Demoes Module ..................................... SUCCESS [43.616s]
[INFO] WCS UI Module ..................................... SUCCESS [34.208s]
[INFO] Security UI Modules ............................... SUCCESS [0.176s]
[INFO] Security UI Core Module ........................... SUCCESS [2:34.928s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:50.441s]
[INFO] Security UI LDAP Module ........................... SUCCESS [44.234s]
[INFO] REST UI Module .................................... SUCCESS [29.236s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.122s]
[INFO] Printing Module ................................... SUCCESS [27.437s]
[INFO] Community Space ................................... SUCCESS [0.131s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.009s]
[INFO] GeoServer Web Application ......................... SUCCESS [8.773s]
[INFO] Application Schema Support ........................ SUCCESS [2.713s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:23.987s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [25.253s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [19.930s]
[INFO] GeoSearch Index Module ............................ SUCCESS [28.891s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.954s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [3.186s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.114s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.304s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.414s]
[INFO] ImageMap Output Format ............................ SUCCESS [11.402s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.986s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.304s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [25.688s]
[INFO] Excel Output Format ............................... SUCCESS [26.426s]
[INFO] Chart external graphics support ................... SUCCESS [0.292s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.239s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.306s]
[INFO] OWS request flow controller ....................... SUCCESS [21.239s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.146s]
[INFO] Web Processing Service Module ..................... FAILURE [3:13.144s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 44:56.523s
[INFO] Finished at: Fri Sep 25 15:49:20 UTC 2015
[INFO] Final Memory: 68M/174M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/184/&gt;
