[Geoserver-devel] Build failed in Jenkins: geoserver-2.7.x #193
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/193/changes&gt;
Changes:
[andrea.aime] "Resource reset" REST API documentation fix
[...truncated 6956 lines...]
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 06:39:43 UTC
[INFO] [GitCommitIdMojo] build.branch = 87e86ac7d109c00f2cdd3a40fdba1252e2ef447a
[INFO] [GitCommitIdMojo] build.commit.user.email = m.filocha@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mfilocha
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 87e86ac
[INFO] [GitCommitIdMojo] build.commit.id = 87e86ac7d109c00f2cdd3a40fdba1252e2ef447a
[INFO] [GitCommitIdMojo] build.commit.message.full = "Resource reset" REST API documentation fix
Fix for: https://osgeo-org.atlassian.net/browse/GEOS-7187
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-restconfig <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-restconfig ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/restconfig/target/gs-restconfig-2.7-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-restconfig ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/restconfig/target/gs-restconfig-2.7-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.7-SNAPSHOT/gs-restconfig-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/restconfig/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.7-SNAPSHOT/gs-restconfig-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/restconfig/target/gs-restconfig-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.7-SNAPSHOT/gs-restconfig-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/restconfig/target/gs-restconfig-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.7-SNAPSHOT/gs-restconfig-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/restconfig/target/gs-restconfig-2.7-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-restconfig/2.7-SNAPSHOT/gs-restconfig-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Web Modules 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ web ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ web ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = "Resource reset" REST API documentation fix
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 06.10.2015 @ 06:10:07 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Oct-2015 06:15
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/web/target/web-2.7-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 06:39:44 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.7-SNAPSHOT/web-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/web/target/web-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.7-SNAPSHOT/web-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Core UI Module 2.7-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://maven.restlet.org/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
Downloading: http://repo.maven.apache.org/maven2/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.935s]
[INFO] Core Platform Module .............................. SUCCESS [15.444s]
[INFO] Open Web Service Module ........................... SUCCESS [19.379s]
[INFO] Main Module ....................................... SUCCESS [3:40.462s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.137s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [58.926s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [41.209s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.076s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [51.888s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [53.680s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:30.773s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:11.858s]
[INFO] Web Map Service Module ............................ SUCCESS [5:31.834s]
[INFO] KML support for GeoServer ......................... SUCCESS [56.808s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:57.576s]
[INFO] REST Support Module ............................... SUCCESS [29.153s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:18.220s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.177s]
[INFO] Core UI Module .................................... FAILURE [1.605s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 24:05.012s
[INFO] Finished at: Tue Oct 06 06:39:45 UTC 2015
[INFO] Final Memory: 46M/257M
[ERROR] Failed to execute goal on project gs-web-core: Could not resolve dependencies for project org.geoserver.web:gs-web-core:jar:2.7-SNAPSHOT: Failed to collect dependencies for [org.apache.wicket:wicket:jar:1.4.12 (compile), org.apache.wicket:wicket-extensions:jar:1.4.12 (compile), org.apache.wicket:wicket-spring:jar:1.4.12 (compile), org.wicketstuff:htmlvalidator:jar:1.2 (compile), org.slf4j:slf4j-log4j12:jar:1.4.2 (compile), log4j:log4j:jar:1.2.14 (compile), org.geoserver:gs-main:jar:2.7-SNAPSHOT (compile), org.geoserver:gs-platform:jar:2.7-SNAPSHOT (compile), org.geoserver:gs-main:jar:tests:2.7-SNAPSHOT (test), com.mockrunner:mockrunner:jar:0.3.6 (test), org.mortbay.jetty:jetty:jar:6.1.8 (test), org.geotools:gt-coverage:jar:13-SNAPSHOT (compile), org.geotools:gt-data:jar:13-SNAPSHOT (compile), org.geotools:gt-shapefile:jar:13-SNAPSHOT (compile), org.geotools.jdbc:gt-jdbc-postgis:jar:13-SNAPSHOT (compile), org.geotools:gt-wfs-ng:jar:13-SNAPSHOT (compile), org.geotools:gt-jdbc:jar:13-SNAPSHOT (compile), org.geotools:gt-metadata:jar:13-SNAPSHOT (compile), org.geotools:gt-arcgrid:jar:13-SNAPSHOT (compile), org.geotools:gt-geotiff:jar:13-SNAPSHOT (compile), org.geotools:gt-gtopo30:jar:13-SNAPSHOT (compile), org.geotools:gt-image:jar:13-SNAPSHOT (compile), org.springframework.security:spring-security-web:jar:3.1.0.RELEASE (compile), org.bouncycastle:bcprov-jdk14:jar:1.46 (compile), org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:13-SNAPSHOT (compile), org.geotools:gt-main:jar:13-SNAPSHOT (compile), junit:junit:jar:4.11 (test)]: Failed to read artifact descriptor for org.wicketstuff:htmlvalidator:jar:1.2: Could not transfer artifact org.wicketstuff:htmlvalidator:pom:1.2 from/to boundlessgeo (https://boundless.artifactoryonline.com/boundless/main): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/194/changes&gt;
Changes:
[daniele.romagnoli] Fixing pom related to GEOT-5148 (NetCDF 4.6.2 upgrade) since UCAR changed scope of a dependency from compile to runtime
[...truncated 6927 lines...]
[INFO] [GitCommitIdMojo] build.commit.time = 06.10.2015 @ 08:23:03 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Oct-2015 08:36
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 09:00:45 UTC
[INFO] [GitCommitIdMojo] build.branch = 841997c124ca9b5172f1211f63c988c374f714ba
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com268...
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 841997c
[INFO] [GitCommitIdMojo] build.commit.id = 841997c124ca9b5172f1211f63c988c374f714ba
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1253 from dromagnoli/GEOT-5148-fix
Fixing pom related to GEOT-5148 (NetCDF 4.6.2 upgrade) since UCAR cha…
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1253 from dromagnoli/GEOT-5148-fix
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 09:00:46 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.275s]
[INFO] Core Platform Module .............................. SUCCESS [18.976s]
[INFO] Open Web Service Module ........................... SUCCESS [18.460s]
[INFO] Main Module ....................................... SUCCESS [3:25.676s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.470s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [56.868s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [35.869s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.024s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [51.041s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [55.010s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:29.309s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:09.415s]
[INFO] Web Map Service Module ............................ SUCCESS [6:22.204s]
[INFO] KML support for GeoServer ......................... SUCCESS [57.275s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:51.710s]
[INFO] REST Support Module ............................... SUCCESS [27.436s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:16.896s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.134s]
[INFO] Core UI Module .................................... FAILURE [2.617s]
[INFO] Total time: 24:21.271s
[INFO] Finished at: Tue Oct 06 09:00:48 UTC 2015
[INFO] Final Memory: 46M/225M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/195/&gt;
[...truncated 6929 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 06-Oct-2015 12:11
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 12:35:47 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.174s]
[INFO] Core Platform Module .............................. SUCCESS [16.305s]
[INFO] Open Web Service Module ........................... SUCCESS [20.823s]
[INFO] Main Module ....................................... SUCCESS [3:31.521s]
[INFO] GeoServer Security Modules ........................ SUCCESS [2.450s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:00.105s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [36.039s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.103s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [48.317s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [52.331s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:28.943s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:13.276s]
[INFO] Web Map Service Module ............................ SUCCESS [5:53.404s]
[INFO] KML support for GeoServer ......................... SUCCESS [56.661s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:51.516s]
[INFO] REST Support Module ............................... SUCCESS [28.569s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:12.808s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.133s]
[INFO] Core UI Module .................................... FAILURE [2.147s]
[INFO] Total time: 23:52.990s
[INFO] Finished at: Tue Oct 06 12:35:49 UTC 2015
[INFO] Final Memory: 47M/258M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/196/&gt;
[...truncated 20743 lines...]
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/13-SNAPSHOT/maven-metadata.xml
971/971 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-metadata/13-SNAPSHOT/maven-metadata.xml (971 B at 3.1 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml
970/970 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml (970 B at 3.2 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-main/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/13-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-main/13-SNAPSHOT/maven-metadata.xml (2 KB at 3.8 KB/sec)
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ geoserver ---
[INFO] [GitCommitIdMojo] build.timestamp = 09-Oct-2015 03:48
[INFO] [GitCommitIdMojo] build.build.time = 09.10.2015 @ 03:48:48 UTC
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 09.10.2015 @ 03:48:49 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geoserver ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.7-SNAPSHOT/geoserver-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/target/geoserver-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.7-SNAPSHOT/geoserver-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.7-SNAPSHOT/maven-metadata.xml
801/801 B
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.7-SNAPSHOT/maven-metadata.xml (801 B at 0.6 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.7-SNAPSHOT/geoserver-2.7-20151009.034851-507.pom
2/53 KB
4/53 KB
6/53 KB
8/53 KB
10/53 KB
12/53 KB
14/53 KB
16/53 KB
18/53 KB
20/53 KB
22/53 KB
24/53 KB
26/53 KB
28/53 KB
30/53 KB
32/53 KB
34/53 KB
36/53 KB
38/53 KB
40/53 KB
42/53 KB
44/53 KB
46/53 KB
48/53 KB
50/53 KB
52/53 KB
53/53 KB
[INFO]
[INFO] GeoServer ......................................... FAILURE [8.972s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] Total time: 13.622s
[INFO] Finished at: Fri Oct 09 03:48:51 UTC 2015
[INFO] Final Memory: 30M/211M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to deploy artifacts: Could not transfer artifact org.geoserver:geoserver:pom:2.7-20151009.034851-507 from/to boundless (http://repo.boundlessgeo.com/main): Failed to transfer file: http://repo.boundlessgeo.com/main/org/geoserver/geoserver/2.7-SNAPSHOT/geoserver-2.7-20151009.034851-507.pom. Return code is: 302, ReasonPhrase:Moved Temporarily. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/197/changes&gt;
