See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/242/changes>
Changes:
[andrea.aime] [GEOS-7353] Make GetFeatureInfo HTML template loading thread-safe.
[andrea.aime] [GEOS-7352] Fix for WMS GetMap error against a raster layer with a rendering transformation when out of the layer's bounding box.
[...truncated 19969 lines...]
[INFO] DXF WFS output format
[INFO] DXF WPS PPIO
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO]
[INFO] Building GeoServer 2.7-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-api/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-api:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-api/13-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
[WARNING] Failure to transfer org.geotools:gt-api:13-SNAPSHOT/maven-metadata.xml from https://boundless.artifactoryonline.com/boundless/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-api:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/\): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt\-api/13\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/library/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:library:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/library/13-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/modules/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:modules:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/modules/13-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/geotools/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:geotools:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/geotools/13-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-referencing/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-referencing:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-referencing/13-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
[WARNING] Failure to transfer org.geotools:gt-referencing:13-SNAPSHOT/maven-metadata.xml from https://boundless.artifactoryonline.com/boundless/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-referencing:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/\): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt\-referencing/13\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-metadata/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-metadata:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-metadata/13-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
[WARNING] Failure to transfer org.geotools:gt-metadata:13-SNAPSHOT/maven-metadata.xml from https://boundless.artifactoryonline.com/boundless/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-metadata:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/\): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt\-metadata/13\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-opengis:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
[WARNING] Failure to transfer org.geotools:gt-opengis:13-SNAPSHOT/maven-metadata.xml from https://boundless.artifactoryonline.com/boundless/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-opengis:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/\): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt\-opengis/13\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-main/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-main:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-main/13-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
[WARNING] Failure to transfer org.geotools:gt-main:13-SNAPSHOT/maven-metadata.xml from https://boundless.artifactoryonline.com/boundless/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-main:13-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/main/\): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt\-main/13\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ geoserver ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7352] Fix for WMS GetMap error against a raster layer with a rendering transformation when out of the layer's bounding box.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.12.2015 @ 14:20:42 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Dec-2015 16:59
[INFO] [GitCommitIdMojo] build.build.time = 19.12.2015 @ 16:59:36 UTC
[INFO] [GitCommitIdMojo] build.branch = 7a123ad63e19b054bcb67f0763179bfbc612dd19
[INFO] [GitCommitIdMojo] build.commit.user.email = Steve.Ikeoka@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Steve Ikeoka
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7a123ad
[INFO] [GitCommitIdMojo] build.commit.id = 7a123ad63e19b054bcb67f0763179bfbc612dd19
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7352] Fix for WMS GetMap error against a raster layer with a rendering transformation when out of the layer's bounding box.
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 19.12.2015 @ 16:59:37 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 19.12.2015 @ 16:59:38 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geoserver ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.7-SNAPSHOT/geoserver-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/target/geoserver-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.7-SNAPSHOT/geoserver-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
Downloading: https://boundless.artifactoryonline.com/boundless/snapshot/org/geoserver/geoserver/2.7-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver:geoserver:2.7-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/snapshot/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/snapshot/org/geoserver/geoserver/2.7-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity.
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [5.661s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 9.113s
[INFO] Finished at: Sat Dec 19 16:59:38 UTC 2015
[INFO] Final Memory: 33M/263M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.7-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.7-SNAPSHOT/maven-metadata.xml from/to boundless (https://boundless.artifactoryonline.com/boundless/snapshot/): Failed to transfer file: https://boundless.artifactoryonline.com/boundless/snapshot/org/geoserver/geoserver/2.7-SNAPSHOT/maven-metadata.xml. Return code is: 503, ReasonPhrase:Service Unavailable: Back-end server is at capacity. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
