See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/270/changes>
Changes:
[andrea.aime] Follow up on GEOS-7128, make sure cleanups are happening even in case of generic throwable
[...truncated 374 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 19-Feb-2016 09:14
[INFO] [GitCommitIdMojo] build.build.time = 19.02.2016 @ 09:15:13 UTC
[INFO] [GitCommitIdMojo] build.branch = 88c36378c4626c7116836c599aee6b3c6c33ced0
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 88c3637
[INFO] [GitCommitIdMojo] build.commit.id = 88c36378c4626c7116836c599aee6b3c6c33ced0
[INFO] [GitCommitIdMojo] build.commit.message.full = Follow up on GEOS-7128, make sure cleanups are happening even in case of generic throwable
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-platform <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-platform ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/platform/target/gs-platform-2.7-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-platform ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/platform/target/gs-platform-2.7-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/platform/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/platform/target/gs-platform-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/platform/target/gs-platform-2.7-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/platform/target/gs-platform-2.7-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Open Web Service Module 2.7-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/ogc/net.opengis.ows/13-SNAPSHOT/maven-metadata.xml
981/981 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/ogc/net.opengis.ows/13-SNAPSHOT/maven-metadata.xml (981 B at 1.6 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/ogc/13-SNAPSHOT/maven-metadata.xml
580/580 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/ogc/13-SNAPSHOT/maven-metadata.xml (580 B at 1.1 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/ogc/org.w3.xlink/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/ogc/org.w3.xlink/13-SNAPSHOT/maven-metadata.xml
978/978 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/ogc/org.w3.xlink/13-SNAPSHOT/maven-metadata.xml (978 B at 1.8 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-ows/13-SNAPSHOT/maven-metadata.xml
976/976 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-ows/13-SNAPSHOT/maven-metadata.xml (976 B at 1.7 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/xsd/13-SNAPSHOT/maven-metadata.xml
584/584 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/xsd/13-SNAPSHOT/maven-metadata.xml (584 B at 1.5 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/extension/13-SNAPSHOT/maven-metadata.xml
586/586 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/extension/13-SNAPSHOT/maven-metadata.xml (586 B at 0.8 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-filter/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-filter/13-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-filter/13-SNAPSHOT/maven-metadata.xml (2 KB at 2.1 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-coverage/13-SNAPSHOT/maven-metadata.xml
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-coverage/13-SNAPSHOT/maven-metadata.xml
973/973 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-coverage/13-SNAPSHOT/maven-metadata.xml (973 B at 6.1 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-core/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-core/13-SNAPSHOT/maven-metadata.xml
977/977 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-core/13-SNAPSHOT/maven-metadata.xml (977 B at 1.7 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-graph/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-graph/13-SNAPSHOT/maven-metadata.xml
970/970 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-graph/13-SNAPSHOT/maven-metadata.xml (970 B at 2.6 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-gml2/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-gml2/13-SNAPSHOT/maven-metadata.xml
977/977 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-gml2/13-SNAPSHOT/maven-metadata.xml (977 B at 1.6 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
977/977 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml (977 B at 2.0 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-ows ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/ows/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-ows ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-ows ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Follow up on GEOS-7128, make sure cleanups are happening even in case of generic throwable
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.02.2016 @ 09:12:11 UTC
[INFO] [GitCommitIdMojo] build.build.time = 19.02.2016 @ 09:15:21 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ows ---
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/ows/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-ows ---
[INFO] Compiling 90 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/ows/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-ows ---
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/ows/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-ows ---
[INFO] Compiling 24 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/ows/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/ows/src/test/java/org/geoserver/ows/DispatcherTest.java>:\[677,44\] error: try-with-resources not applicable to variable type
[INFO] 1 error
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.079s]
[INFO] Core Platform Module .............................. SUCCESS [13.459s]
[INFO] Open Web Service Module ........................... FAILURE [13.104s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 36.669s
[INFO] Finished at: Fri Feb 19 09:15:26 UTC 2016
[INFO] Final Memory: 36M/319M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-ows: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
