[Geoserver-devel] Build failed in Jenkins: geoserver-2.7.x #278
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/278/changes&gt;
Changes:
[ben] Fix spatialite plugin dependencies
[...truncated 4175 lines...]
        </swe:field>
        <swe:field name="GREEN_BAND">
          <swe:Quantity>
            <swe:description>GREEN_BAND</swe:description>
            <swe:nilValues>
              <swe:NilValues>
                <swe:nilValue reason="http://www.opengis.net/def/nil/OGC/0/unknown&quot;&gt;0\.0&lt;/swe:nilValue&gt;
              </swe:NilValues>
            </swe:nilValues>
            <swe:uom code="W.m-2.Sr-1"/>
            <swe:constraint>
              <swe:AllowedValues>
                <swe:interval>0.0 0.0</swe:interval>
              </swe:AllowedValues>
            </swe:constraint>
          </swe:Quantity>
        </swe:field>
        <swe:field name="BLUE_BAND">
          <swe:Quantity>
            <swe:description>BLUE_BAND</swe:description>
            <swe:nilValues>
              <swe:NilValues>
              </swe:NilValues>
            </swe:nilValues>
            <swe:constraint>
              <swe:AllowedValues>
            </swe:constraint>
          </swe:Quantity>
        </swe:field>
      </swe:DataRecord>
    </gmlcov:rangeType>
    <wcs:ServiceParameters>
      <wcs:CoverageSubtype>RectifiedGridCoverage</wcs:CoverageSubtype>
      <wcs:nativeFormat>image/tiff</wcs:nativeFormat>
    </wcs:ServiceParameters>
  </wcs:CoverageDescription>
</wcs:CoverageDescriptions>
Tests run: 24, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.372 sec
Running org.geoserver.wcs2_0.kvp.GMLGetCoverageKVPTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.904 sec
Running org.geoserver.wcs2_0.kvp.GeoTiffKvpTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.137 sec
Running org.geoserver.wcs2_0.kvp.GetCapabilitiesTest
ERROR: 'Unknown section Bogus'
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.494 sec
Running org.geoserver.wcs2_0.kvp.GetCoverageKvpTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.682 sec
Running org.geoserver.wcs2_0.kvp.InterpolationKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.091 sec
Running org.geoserver.wcs2_0.kvp.RangeSubsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.wcs2_0.kvp.RangeSubsetKvpTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.974 sec
Running org.geoserver.wcs2_0.kvp.ScaleExtentKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.wcs2_0.kvp.ScaleKvpTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.794 sec
Running org.geoserver.wcs2_0.kvp.SubsetKvpParserTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.wcs2_0.kvp.SubsetKvpTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.446 sec
Running org.geoserver.wcs2_0.xml.CRSExtentionTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.822 sec
Running org.geoserver.wcs2_0.xml.DescribeCoverageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.566 sec
Running org.geoserver.wcs2_0.xml.GMLGetCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.387 sec
Running org.geoserver.wcs2_0.xml.GeoTiffGetCoverageTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 2, Time elapsed: 2.222 sec
Running org.geoserver.wcs2_0.xml.GetCapabilitiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.117 sec
Running org.geoserver.wcs2_0.xml.GetCoverageTest
./target/default6049907227637203548data
<ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema&quot; xmlns:ows="http://www.opengis.net/ows/2.0&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema\-instance&quot; version="2.0.0" xsi:schemaLocation="http://www.opengis.net/ows/2.0 http://schemas.opengis.net/ows/2.0/owsExceptionReport.xsd&quot;&gt;
  <ows:Exception exceptionCode="NoApplicableCode">
    <ows:ExceptionText>This request is trying to read too much data, the limit is 1KB but the actual amount of bytes to be read is 2.97MB
</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Tests run: 29, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.41 sec
Running org.geoserver.wcs2_0.xml.InterpolationExtentionsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.11 sec
Running org.geoserver.wcs2_0.xml.RangeSubsetExtentionTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.392 sec
Running org.geoserver.wcs2_0.xml.ScalingExtentionTest
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 10.202 sec <<< FAILURE!
testScaleToSizeXML(org.geoserver.wcs2_0.xml.ScalingExtentionTest) Time elapsed: 2523 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[image/tiff]> but was:<[application/xml]>
  at junit.framework.Assert.assertEquals(Assert.java:100)
  at junit.framework.Assert.assertEquals(Assert.java:107)
  at junit.framework.TestCase.assertEquals(TestCase.java:269)
  at org.geoserver.wcs2_0.xml.ScalingExtentionTest.testScaleToSizeXML(ScalingExtentionTest.java:78)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Results :
Failed tests: testScaleToSizeXML(org.geoserver.wcs2_0.xml.ScalingExtentionTest): expected:<[image/tiff]> but was:<[application/xml]>
Tests run: 178, Failures: 1, Errors: 0, Skipped: 2
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.895s]
[INFO] Core Platform Module .............................. SUCCESS [13.568s]
[INFO] Open Web Service Module ........................... SUCCESS [15.626s]
[INFO] Main Module ....................................... SUCCESS [3:07.524s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.732s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [51.016s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [34.590s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.981s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [38.797s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [40.258s]
[INFO] Web Coverage Service 2.0 Module ................... FAILURE [1:18.339s]
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 7:52.789s
[INFO] Finished at: Fri Mar 04 01:14:58 UTC 2016
[INFO] Final Memory: 42M/295M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/279/changes&gt;
