[Geoserver-devel] Build failed in Jenkins: geoserver-2.7.x #287
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/287/changes&gt;
Changes:
[ben] Upgrade git-commit-id-plugin to 2.2.0
[...truncated 17 lines...]
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:gs-web-wps:jar:2.7-SNAPSHOT
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-web-wps:${gs.version}, <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/web-wps/pom.xml,&gt; line 21, column 14
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Coverage Service 2.0 Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Security UI Modules
[INFO] Security UI Core Module
[INFO] Security UI JDBC Module
[INFO] Security UI LDAP Module
[INFO] REST UI Module
[INFO] GeoServer Extensions
[INFO] Printing Module
[INFO] Community Space
[INFO] HTTP Proxy Extension
[INFO] GeoServer Web Application
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web process status sharing with Hazelcast
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Data Importer
[INFO] Importer Core Module
[INFO] Importer REST Api Module
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO]
[INFO] Building GeoServer 2.7-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-api/13-SNAPSHOT/maven-metadata.xml
949/949 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-api/13-SNAPSHOT/maven-metadata.xml (949 B at 0.4 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/library/13-SNAPSHOT/maven-metadata.xml
569/569 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/library/13-SNAPSHOT/maven-metadata.xml (569 B at 1.3 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/modules/13-SNAPSHOT/maven-metadata.xml
569/569 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/modules/13-SNAPSHOT/maven-metadata.xml (569 B at 2.1 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/geotools/13-SNAPSHOT/maven-metadata.xml
570/570 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/geotools/13-SNAPSHOT/maven-metadata.xml (570 B at 1.2 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-referencing/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/13-SNAPSHOT/maven-metadata.xml
957/957 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-referencing/13-SNAPSHOT/maven-metadata.xml (957 B at 3.3 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-metadata/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/13-SNAPSHOT/maven-metadata.xml
954/954 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-metadata/13-SNAPSHOT/maven-metadata.xml (954 B at 1.9 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml
953/953 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-opengis/13-SNAPSHOT/maven-metadata.xml (953 B at 3.6 KB/sec)
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-main/13-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-main/13-SNAPSHOT/maven-metadata.xml (2 KB at 3.4 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ geoserver ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/ws/src/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ geoserver ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [7.386s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 9.595s
[INFO] Finished at: Sat Mar 19 23:14:26 UTC 2016
[INFO] Final Memory: 34M/319M
[ERROR] Failed to execute goal pl.project13.maven:git-commit-id-plugin:2.2.0:revision (default) on project geoserver: The plugin pl.project13.maven:git-commit-id-plugin:2.2.0 requires Maven version [3.1.1,) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginIncompatibleException
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x/288/changes&gt;
