[Geoserver-devel] Build failed in Jenkins: geoserver-2.7.x #94
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/94/changes&gt;
Changes:
[andrea.aime] [GEOS-7047] WPS respose thread can get locked up if a CDATA-like output is requested in document form
[andrea.aime] Remove sysouts
[...truncated 20881 lines...]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wps ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps/2.7-SNAPSHOT/gs-wps-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/target/gs-wps-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps/2.7-SNAPSHOT/gs-wps-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Web Processing Service Module 2.7-SNAPSHOT
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.wps/13-SNAPSHOT/maven-metadata.xml (981 B at 73.7 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml
913/976 B
976/976 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-wps/13-SNAPSHOT/maven-metadata.xml (976 B at 95.3 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml
981/981 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/gt-process-geometry/13-SNAPSHOT/maven-metadata.xml (981 B at 87.1 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wps-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wps-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wps-core ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Remove sysouts
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.05.2015 @ 17:24:25 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-May-2015 17:47
[INFO] [GitCommitIdMojo] build.build.time = 24.05.2015 @ 18:28:57 UTC
[INFO] [GitCommitIdMojo] build.branch = 960da7db57cb966efa5a10312926579f0f4c990f
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 960da7d
[INFO] [GitCommitIdMojo] build.commit.id = 960da7db57cb966efa5a10312926579f0f4c990f
[INFO] [GitCommitIdMojo] build.commit.message.full = Remove sysouts
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wps-core ---
[INFO] Copying 10 resources
[INFO] Copying 15 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wps-core ---
[INFO] Compiling 186 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wps-core ---
[INFO] Copying 14 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wps-core ---
[INFO] Compiling 59 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1231,8\] error: cannot find symbol
[ERROR] class ExecuteTest
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1231,70\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1242,28\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1248,54\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1253,36\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1260,8\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1283,8\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1283,70\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1293,28\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1303,28\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1311,54\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1316,36\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1323,8\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1345,8\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1345,70\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1348,28\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1365,8\] error: cannot find symbol
[INFO] 17 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.100s]
[INFO] Core Platform Module .............................. SUCCESS [14.512s]
[INFO] Open Web Service Module ........................... SUCCESS [15.938s]
[INFO] Main Module ....................................... SUCCESS [3:22.751s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.687s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [57.896s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:17.275s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.313s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [47.317s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [51.766s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:27.898s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:13.138s]
[INFO] Web Map Service Module ............................ SUCCESS [5:22.182s]
[INFO] KML support for GeoServer ......................... SUCCESS [57.139s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:51.204s]
[INFO] REST Support Module ............................... SUCCESS [27.024s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:08.551s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.084s]
[INFO] Core UI Module .................................... SUCCESS [1:43.323s]
[INFO] WMS UI Module ..................................... SUCCESS [45.571s]
[INFO] GWC UI Module ..................................... SUCCESS [58.667s]
[INFO] WFS UI Module ..................................... SUCCESS [25.776s]
[INFO] Demoes Module ..................................... SUCCESS [42.629s]
[INFO] WCS UI Module ..................................... SUCCESS [32.940s]
[INFO] Security UI Modules ............................... SUCCESS [0.147s]
[INFO] Security UI Core Module ........................... SUCCESS [2:32.012s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:49.226s]
[INFO] Security UI LDAP Module ........................... SUCCESS [43.440s]
[INFO] REST UI Module .................................... SUCCESS [28.824s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.120s]
[INFO] Printing Module ................................... SUCCESS [26.171s]
[INFO] Community Space ................................... SUCCESS [0.116s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [9.136s]
[INFO] GeoServer Web Application ......................... SUCCESS [8.664s]
[INFO] Application Schema Support ........................ SUCCESS [0.221s]
[INFO] Application Schema Integration Test ............... SUCCESS [3:32.874s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [25.540s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [18.928s]
[INFO] GeoSearch Index Module ............................ SUCCESS [29.820s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.659s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.747s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.304s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.315s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.270s]
[INFO] ImageMap Output Format ............................ SUCCESS [11.916s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.291s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.374s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [24.007s]
[INFO] Excel Output Format ............................... SUCCESS [28.960s]
[INFO] Chart external graphics support ................... SUCCESS [0.282s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.826s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.217s]
[INFO] OWS request flow controller ....................... SUCCESS [21.183s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.090s]
[INFO] Web Processing Service Module ..................... FAILURE [15.098s]
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 41:54.831s
[INFO] Finished at: Sun May 24 18:29:12 UTC 2015
[INFO] Final Memory: 68M/194M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wps-core: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1231,70\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1242,28\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1248,54\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1253,36\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1260,8\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1283,8\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1283,70\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1293,28\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1303,28\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1311,54\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1316,36\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1323,8\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1345,8\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1345,70\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1348,28\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/ws/src/extension/wps/wps-core/src/test/java/org/geoserver/wps/ExecuteTest.java&gt;:\[1365,8\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x/95/changes&gt;
