[Geoserver-devel] Build failed in Jenkins: geoserver-2.7.x-nightly #228
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/228/changes&gt;
Changes:
[andrea.aime] "Resource reset" REST API documentation fix
[daniele.romagnoli] Fixing pom related to GEOT-5148 (NetCDF 4.6.2 upgrade) since UCAR changed scope of a dependency from compile to runtime
[...truncated 2484 lines...]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1253 from dromagnoli/GEOT-5148-fix
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 06.10.2015 @ 08:23:03 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Oct-2015 10:53
[INFO] [GitCommitIdMojo] build.build.time = 06.10.2015 @ 10:56:59 UTC
[INFO] [GitCommitIdMojo] build.branch = 841997c124ca9b5172f1211f63c988c374f714ba
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com268...
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 841997c
[INFO] [GitCommitIdMojo] build.commit.id = 841997c124ca9b5172f1211f63c988c374f714ba
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1253 from dromagnoli/GEOT-5148-fix
Fixing pom related to GEOT-5148 (NetCDF 4.6.2 upgrade) since UCAR cha…
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/web/target/web-2.7-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ web ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/web/target/dependency/gt-api-13-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/web/target/dependency/gwc-core-1.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.7-SNAPSHOT/web-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/web/target/web-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.7-SNAPSHOT/web-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Core UI Module 2.7-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.863s]
[INFO] Core Platform Module .............................. SUCCESS [6.747s]
[INFO] Open Web Service Module ........................... SUCCESS [8.369s]
[INFO] Main Module ....................................... SUCCESS [30.694s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.262s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [7.852s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [5.497s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.479s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [10.058s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [11.023s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [11.922s]
[INFO] Web Feature Service Module ........................ SUCCESS [19.673s]
[INFO] Web Map Service Module ............................ SUCCESS [20.112s]
[INFO] KML support for GeoServer ......................... SUCCESS [10.307s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [13.674s]
[INFO] REST Support Module ............................... SUCCESS [5.964s]
[INFO] REST Configuration Service Module ................. SUCCESS [13.311s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.185s]
[INFO] Core UI Module .................................... FAILURE [0.355s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Authentication by unique url key .................. SKIPPED
[INFO] WorldWind Format Module ........................... SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] SpatiaLite Extension .............................. SKIPPED
[INFO] GeoServer JDBC KV Catalog ......................... SKIPPED
[INFO] Simple Feature Service ............................ SKIPPED
[INFO] Aggregating Data Store ............................ SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Scripting Extensions .................... SKIPPED
[INFO] Core Scripting Extension .......................... SKIPPED
[INFO] Web UI Scripting Extension ........................ SKIPPED
[INFO] BeanShell Scripting Extension ..................... SKIPPED
[INFO] Groovy Scripting Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:15.099s
[INFO] Finished at: Tue Oct 06 10:56:59 UTC 2015
[INFO] Final Memory: 59M/286M
[ERROR] Failed to execute goal on project gs-web-core: Could not resolve dependencies for project org.geoserver.web:gs-web-core:jar:2.7-SNAPSHOT: Failed to collect dependencies for [org.apache.wicket:wicket:jar:1.4.12 (compile), org.apache.wicket:wicket-extensions:jar:1.4.12 (compile), org.apache.wicket:wicket-spring:jar:1.4.12 (compile), org.wicketstuff:htmlvalidator:jar:1.2 (compile), org.slf4j:slf4j-log4j12:jar:1.4.2 (compile), log4j:log4j:jar:1.2.14 (compile), org.geoserver:gs-main:jar:2.7-SNAPSHOT (compile), org.geoserver:gs-platform:jar:2.7-SNAPSHOT (compile), org.geoserver:gs-main:jar:tests:2.7-SNAPSHOT (test), com.mockrunner:mockrunner:jar:0.3.6 (test), org.mortbay.jetty:jetty:jar:6.1.8 (test), org.geotools:gt-coverage:jar:13-SNAPSHOT (compile), org.geotools:gt-data:jar:13-SNAPSHOT (compile), org.geotools:gt-shapefile:jar:13-SNAPSHOT (compile), org.geotools.jdbc:gt-jdbc-postgis:jar:13-SNAPSHOT (compile), org.geotools:gt-wfs-ng:jar:13-SNAPSHOT (compile), org.geotools:gt-jdbc:jar:13-SNAPSHOT (compile), org.geotools:gt-metadata:jar:13-SNAPSHOT (compile), org.geotools:gt-arcgrid:jar:13-SNAPSHOT (compile), org.geotools:gt-geotiff:jar:13-SNAPSHOT (compile), org.geotools:gt-gtopo30:jar:13-SNAPSHOT (compile), org.geotools:gt-image:jar:13-SNAPSHOT (compile), org.springframework.security:spring-security-web:jar:3.1.0.RELEASE (compile), org.bouncycastle:bcprov-jdk14:jar:1.46 (compile), org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:13-SNAPSHOT (compile), org.geotools:gt-main:jar:13-SNAPSHOT (compile), junit:junit:jar:4.11 (test), org.geowebcache:gwc-core:jar:1.7-SNAPSHOT (compile)]: Failed to read artifact descriptor for org.wicketstuff:htmlvalidator:jar:1.2: Could not transfer artifact org.wicketstuff:htmlvalidator:pom:1.2 from/to boundlessgeo (https://boundless.artifactoryonline.com/boundless/main): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/229/&gt;
[...truncated 429 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-platform <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-platform ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/platform/target/gs-platform-2.7-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-platform ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/platform/target/dependency/gt-api-13-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/platform/target/dependency/gwc-core-1.7-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-platform ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/platform/target/gs-platform-2.7-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/platform/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/platform/target/gs-platform-2.7-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/platform/target/gs-platform-2.7-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/ws/src/platform/target/gs-platform-2.7-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/gs-platform/2.7-SNAPSHOT/gs-platform-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Open Web Service Module 2.7-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geotools/ogc/net.opengis.ows/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.ows/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools.ogc:net.opengis.ows:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools.ogc:net.opengis.ows:13-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.ogc:net.opengis.ows:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-ows/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-ows/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools.xsd:gt-xsd-ows:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-ows:13-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-ows:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-filter/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-filter/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-filter/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-filter/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools.xsd:gt-xsd-filter:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-filter:13-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-filter:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-coverage/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-coverage/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-coverage/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-coverage/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-coverage:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools:gt-coverage:13-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-coverage:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-core/13-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-core/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-core/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-core/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools.xsd:gt-xsd-core:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-core:13-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-core:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/gt-graph/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-graph/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-graph/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-graph/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-graph:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools:gt-graph:13-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-graph:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml2/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml2/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-gml2/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-gml2/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools.xsd:gt-xsd-gml2:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-gml2:13-SNAPSHOT/maven-metadata.xml from http://repo.boundlessgeo.com/main was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-gml2:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main\): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools.xsd:gt-xsd-gml3:13-SNAPSHOT/maven-metadata.xml from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized.
Downloading: http://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/gt-xsd-gml3-13-20151006.112425-273.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/gt-xsd-gml3-13-20151006.112425-273.pom
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/gt-xsd-gml3-13-20151006.112425-273.pom
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-gml3/13-SNAPSHOT/gt-xsd-gml3-13-20151006.112425-273.pom
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.627s]
[INFO] Core Platform Module .............................. SUCCESS [6.561s]
[INFO] Open Web Service Module ........................... FAILURE [6.990s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Total time: 28.708s
[INFO] Finished at: Wed Oct 07 10:39:54 UTC 2015
[INFO] Final Memory: 44M/254M
[ERROR] Failed to execute goal on project gs-ows: Could not resolve dependencies for project org.geoserver:gs-ows:jar:2.7-SNAPSHOT: Failed to collect dependencies for [org.springframework.security:spring-security-core:jar:3.1.0.RELEASE (compile), commons-lang:commons-lang:jar:2.6 (compile), commons-io:commons-io:jar:2.1 (compile), commons-fileupload:commons-fileupload:jar:1.2.1 (compile), org.geoserver:gs-platform:jar:2.7-SNAPSHOT (compile), org.geotools.ogc:net.opengis.ows:jar:13-SNAPSHOT (compile), org.geotools.xsd:gt-xsd-ows:jar:13-SNAPSHOT (compile), org.geotools.xsd:gt-xsd-core:jar:13-SNAPSHOT (compile), javax.servlet:servlet-api:jar:2.5 (compile), xpp3:xpp3:jar:1.1.3.4.O (compile), com.mockrunner:mockrunner:jar:0.3.6 (test), junit:junit:jar:4.11 (test), xalan:xalan:jar:2.7.0 (test), javax.mail:mail:jar:1.4 (test), org.springframework:spring-beans:jar:3.1.4.RELEASE (compile), org.springframework:spring-core:jar:3.1.4.RELEASE (compile), org.springframework:spring-context:jar:3.1.4.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.4.RELEASE (compile), org.geotools:gt-api:jar:13-SNAPSHOT (compile), org.geotools:gt-main:jar:13-SNAPSHOT (compile), org.geowebcache:gwc-core:jar:1.7-SNAPSHOT (compile)]: Failed to read artifact descriptor for org.geotools.xsd:gt-xsd-gml3:jar:13-SNAPSHOT: Could not transfer artifact org.geotools.xsd:gt-xsd-gml3:pom:13-20151006.112425-273 from/to boundless (http://repo.boundlessgeo.com/main): Not authorized, ReasonPhrase:Unauthorized. -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
See <http://ares.opengeo.org/jenkins/job/geoserver-2.7.x-nightly/230/&gt;
