Hudson
February 6, 2016, 10:48am
1
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/351/changes> ;
Changes:
[nuno.oliveira] Add extract-parameter community module
[...truncated 10446 lines...]
[GEOS-7399] Add extract-parameter community module (backport to 2.7.x)
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sldservice <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sldservice ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.7-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sldservice >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-sldservice ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/.git ’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1467 from nmco/community-params-extractor-2.7.x
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 05.02.2016 @ 16:34:31 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Feb-2016 10:39
[INFO] [GitCommitIdMojo] build.build.time = 06.02.2016 @ 10:48:14 UTC
[INFO] [GitCommitIdMojo] build.branch = 578daee6ba392ab5900ff38530d83d963db5d651
[INFO] [GitCommitIdMojo] build.commit.user.email = simone.giannecchini@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Simone Giannecchini
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 578daee
[INFO] [GitCommitIdMojo] build.commit.id = 578daee6ba392ab5900ff38530d83d963db5d651
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1467 from nmco/community-params-extractor-2.7.x
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sldservice <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sldservice ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.7-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-sldservice ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/target/dependency/gt-api-13-SNAPSHOT.jar> ;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/target/dependency/gwc-core-1.7-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-sldservice ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.7-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.7-SNAPSHOT/gs-sldservice-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.7-SNAPSHOT/gs-sldservice-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.7-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.7-SNAPSHOT/gs-sldservice-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.7-SNAPSHOT-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.7-SNAPSHOT/gs-sldservice-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/sldService/target/gs-sldservice-2.7-SNAPSHOT-test-sources.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-sldservice/2.7-SNAPSHOT/gs-sldservice-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Parameters Extractor 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-params-extractor ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/params-extractor/target> ;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-params-extractor ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-params-extractor ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-params-extractor ---
[INFO] Copying 5 resources
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-params-extractor ---
[INFO] Compiling 13 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/params-extractor/target/classes> ;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/params-extractor/src/main/java/org/geoserver/params/extractor/Rule.java>:\[10,16\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [11.524s]
[INFO] Core Platform Module .............................. SUCCESS [5.543s]
[INFO] Open Web Service Module ........................... SUCCESS [12.506s]
[INFO] Main Module ....................................... SUCCESS [33.973s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.748s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [5.258s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [4.565s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.864s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [8.136s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [7.275s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [8.591s]
[INFO] Web Feature Service Module ........................ SUCCESS [13.440s]
[INFO] Web Map Service Module ............................ SUCCESS [18.974s]
[INFO] KML support for GeoServer ......................... SUCCESS [8.295s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [15.848s]
[INFO] REST Support Module ............................... SUCCESS [5.100s]
[INFO] REST Configuration Service Module ................. SUCCESS [11.950s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.213s]
[INFO] Core UI Module .................................... SUCCESS [12.658s]
[INFO] WMS UI Module ..................................... SUCCESS [6.379s]
[INFO] GWC UI Module ..................................... SUCCESS [7.072s]
[INFO] WFS UI Module ..................................... SUCCESS [4.277s]
[INFO] Demoes Module ..................................... SUCCESS [6.507s]
[INFO] WCS UI Module ..................................... SUCCESS [5.246s]
[INFO] Security UI Modules ............................... SUCCESS [0.256s]
[INFO] Security UI Core Module ........................... SUCCESS [10.066s]
[INFO] Security UI JDBC Module ........................... SUCCESS [5.036s]
[INFO] Security UI LDAP Module ........................... SUCCESS [4.843s]
[INFO] REST UI Module .................................... SUCCESS [4.254s]
[INFO] GeoServer Web Application ......................... SUCCESS [13.239s]
[INFO] Community Space ................................... SUCCESS [0.271s]
[INFO] Authentication by unique url key .................. SUCCESS [10.417s]
[INFO] WorldWind Format Module ........................... SUCCESS [13.930s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.381s]
[INFO] SpatiaLite Extension .............................. SUCCESS [5.196s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [6.529s]
[INFO] Simple Feature Service ............................ SUCCESS [4.290s]
[INFO] Aggregating Data Store ............................ SUCCESS [3.272s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.209s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.214s]
[INFO] Web Processing Service Module ..................... SUCCESS [14.685s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.343s]
[INFO] Core Scripting Extension .......................... SUCCESS [6.247s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [5.090s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [4.145s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [31.443s]
[INFO] H2 DataStore Extension ............................ SUCCESS [4.531s]
[INFO] Python Scripting Extension ........................ SUCCESS [5.399s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [5.570s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [4.036s]
[INFO] WMS-EO ............................................ SUCCESS [5.860s]
[INFO] ColorMap .......................................... SUCCESS [4.391s]
[INFO] NetCDF Coverage format ............................ SUCCESS [5.441s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [12.061s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [6.195s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [5.149s]
[INFO] GRIB Coverage Format .............................. SUCCESS [5.014s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [3.170s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [5.238s]
[INFO] REST plugin community module ...................... SUCCESS [4.475s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [4.380s]
[INFO] KML PPIO for WPS .................................. SUCCESS [4.352s]
[INFO] DownloadProcess ................................... SUCCESS [5.371s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [2.371s]
[INFO] ActiveMQ .......................................... SUCCESS [9.498s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [5.089s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [13.653s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [5.497s]
[INFO] Solr Module ....................................... SUCCESS [5.049s]
[INFO] GeoFence security integration ..................... SUCCESS [9.806s]
[INFO] REST SLD service .................................. SUCCESS [5.516s]
[INFO] Parameters Extractor .............................. FAILURE [2.363s]
[INFO] GeoServer Community Release Module ................ SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8:36.369s
[INFO] Finished at: Sat Feb 06 10:48:17 UTC 2016
[INFO] Final Memory: 108M/187M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-params-extractor: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-params-extractor
Hudson
February 6, 2016, 11:36am
2
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/352/changes> ;
Changes:
[simone.giannecchini] Update pom.xml
[...truncated 9501 lines...]
Update pom.xml
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1473 from geoserver/fix-nightly-2.7.x
[INFO] [GitCommitIdMojo] build.commit.time = 06.02.2016 @ 11:20:10 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Feb-2016 11:29
[INFO] [GitCommitIdMojo] build.build.time = 06.02.2016 @ 11:36:10 UTC
[INFO] [GitCommitIdMojo] build.branch = 3748dab86526434e0c6a72b024662598606713b3
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3748dab
[INFO] [GitCommitIdMojo] build.commit.id = 3748dab86526434e0c6a72b024662598606713b3
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1473 from geoserver/fix-nightly-2.7.x
Update pom.xml
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Update pom.xml
[INFO]
[INFO]
[INFO] 1 error
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [2.463s]
[INFO] Core Platform Module .............................. SUCCESS [6.902s]
[INFO] Open Web Service Module ........................... SUCCESS [6.375s]
[INFO] Main Module ....................................... SUCCESS [20.981s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.285s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [5.454s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [4.586s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.811s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [5.940s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [6.783s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [8.194s]
[INFO] Web Feature Service Module ........................ SUCCESS [12.454s]
[INFO] Web Map Service Module ............................ SUCCESS [14.060s]
[INFO] KML support for GeoServer ......................... SUCCESS [7.726s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [9.282s]
[INFO] REST Support Module ............................... SUCCESS [5.070s]
[INFO] REST Configuration Service Module ................. SUCCESS [9.043s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.193s]
[INFO] Core UI Module .................................... SUCCESS [11.873s]
[INFO] WMS UI Module ..................................... SUCCESS [6.154s]
[INFO] GWC UI Module ..................................... SUCCESS [7.523s]
[INFO] WFS UI Module ..................................... SUCCESS [4.347s]
[INFO] Demoes Module ..................................... SUCCESS [5.982s]
[INFO] WCS UI Module ..................................... SUCCESS [5.099s]
[INFO] Security UI Modules ............................... SUCCESS [0.233s]
[INFO] Security UI Core Module ........................... SUCCESS [9.099s]
[INFO] Security UI JDBC Module ........................... SUCCESS [4.820s]
[INFO] Security UI LDAP Module ........................... SUCCESS [5.364s]
[INFO] REST UI Module .................................... SUCCESS [4.325s]
[INFO] GeoServer Web Application ......................... SUCCESS [5.730s]
[INFO] Community Space ................................... SUCCESS [0.201s]
[INFO] Authentication by unique url key .................. SUCCESS [5.536s]
[INFO] WorldWind Format Module ........................... SUCCESS [4.774s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.340s]
[INFO] SpatiaLite Extension .............................. SUCCESS [3.921s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [6.541s]
[INFO] Simple Feature Service ............................ SUCCESS [4.224s]
[INFO] Aggregating Data Store ............................ SUCCESS [2.568s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.195s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.215s]
[INFO] Web Processing Service Module ..................... SUCCESS [10.768s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.268s]
[INFO] Core Scripting Extension .......................... SUCCESS [5.919s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [5.035s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [4.151s]
[INFO] Groovy Scripting Extension ........................ SUCCESS [13.072s]
[INFO] H2 DataStore Extension ............................ SUCCESS [3.561s]
[INFO] Python Scripting Extension ........................ SUCCESS [5.344s]
[INFO] JavaScript Scripting Extension .................... SUCCESS [5.300s]
[INFO] Ruby Scripting Extension .......................... SUCCESS [4.058s]
[INFO] WMS-EO ............................................ SUCCESS [5.844s]
[INFO] ColorMap .......................................... SUCCESS [4.467s]
[INFO] NetCDF Coverage format ............................ SUCCESS [2.102s]
[INFO] WCS NetCDF output Module .......................... SUCCESS [5.056s]
[INFO] GeoServer mbtiles Extension ....................... SUCCESS [5.108s]
[INFO] GeoServer GeoPackage Extension .................... SUCCESS [4.987s]
[INFO] GRIB Coverage Format .............................. SUCCESS [4.357s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [2.219s]
[INFO] Dynamic WMS dimension value defaults .............. SUCCESS [5.086s]
[INFO] REST plugin community module ...................... SUCCESS [4.426s]
[INFO] GPX PPIO for WPS .................................. SUCCESS [4.971s]
[INFO] KML PPIO for WPS .................................. SUCCESS [4.520s]
[INFO] DownloadProcess ................................... SUCCESS [5.437s]
[INFO] GeoServer JMS based clustering modules ............ SUCCESS [0.214s]
[INFO] ActiveMQ .......................................... SUCCESS [4.624s]
[INFO] GeoServer JMS clustering Commons module ........... SUCCESS [1.809s]
[INFO] GeoServer JMS clustering module ................... SUCCESS [5.270s]
[INFO] GeoServer Hazelcast Clustering Module ............. SUCCESS [5.421s]
[INFO] Solr Module ....................................... SUCCESS [4.478s]
[INFO] GeoFence security integration ..................... SUCCESS [5.810s]
[INFO] REST SLD service .................................. SUCCESS [5.865s]
[INFO] Parameters Extractor .............................. FAILURE [2.379s]
[INFO] Total time: 6:25.308s
[INFO] Finished at: Sat Feb 06 11:36:12 UTC 2016
[INFO] Final Memory: 108M/269M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
February 6, 2016, 11:42am
3
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/353/> ;
Started by user Hudson
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/> ;
Checkout:geoserver-master / <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/> ; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 3748dab86526434e0c6a72b024662598606713b3 (origin/2.7.x)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
hudson.plugins.git.GitException: Command "git fetch -t origin +refs/heads/*:refs/remotes/origin/*" returned status code 1:
stdout:
stderr: error: Ref refs/remotes/origin/2.7.x is at 41e60e976dadf8bc74ae5818abd5c62229563f87 but expected 3748dab86526434e0c6a72b024662598606713b3
From git://github.com/geoserver/geoserver
! 3748dab..41e60e9 2.7.x -> origin/2.7.x (unable to update local ref)
* [new branch] removing-params-extractor-from-2.7-nightly -> origin/removing-params-extractor-from-2.7-nightly
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:790)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:756)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.fetch(CliGitAPIImpl.java:144)
at hudson.plugins.git.GitAPI.fetch(GitAPI.java:221)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:791)
at hudson.plugins.git.GitSCM.access$000(GitSCM.java:58)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:983)
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:948)
at hudson.FilePath.act(FilePath.java:914)
at hudson.FilePath.act(FilePath.java:887)
at hudson.plugins.git.GitSCM.determineRevisionToBuild(GitSCM.java:948)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1114)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1320)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:609)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:88)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:518)
at hudson.model.Run.execute(Run.java:1689)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:231)
ERROR: Could not fetch from any repository
java.io.IOException: Could not fetch from any repository
at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:992)
Hudson
February 6, 2016, 11:55am
4
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/354/changes> ;
Changes:
[...truncated 10674 lines...]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sqlserver ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/src/main/java> ;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/src/main/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-sqlserver ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sqlserver ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/src/test/java> ;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/src/test/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sqlserver ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sqlserver ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sqlserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/target/gs-sqlserver-2.7-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sqlserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/target/gs-sqlserver-2.7-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sqlserver >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-sqlserver ---
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1475 from geoserver/removing-params-extractor-from-2.7-nightly
[INFO] [GitCommitIdMojo] build.commit.time = 06.02.2016 @ 11:42:09 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-Feb-2016 11:47
[INFO] [GitCommitIdMojo] build.build.time = 06.02.2016 @ 11:55:04 UTC
[INFO] [GitCommitIdMojo] build.branch = 41e60e976dadf8bc74ae5818abd5c62229563f87
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 41e60e9
[INFO] [GitCommitIdMojo] build.commit.id = 41e60e976dadf8bc74ae5818abd5c62229563f87
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1475 from geoserver/removing-params-extractor-from-2.7-nightly
Update pom.xml
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sqlserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sqlserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sqlserver >>>
[INFO]
Update pom.xml
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sqlserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sqlserver ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-sqlserver ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/target/dependency/gt-api-13-SNAPSHOT.jar> ;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/target/dependency/gwc-core-1.7-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-sqlserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/target/gs-sqlserver-2.7-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sqlserver/2.7-SNAPSHOT/gs-sqlserver-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sqlserver/2.7-SNAPSHOT/gs-sqlserver-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/sqlserver/target/gs-sqlserver-2.7-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-sqlserver/2.7-SNAPSHOT/gs-sqlserver-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Oracle DataStore Extension 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-oracle ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-oracle ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-oracle ---
Update pom.xml
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oracle ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/src/main/java> ;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/src/main/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oracle ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oracle ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/src/test/java> ;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/src/test/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oracle ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oracle ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oracle ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/target/gs-oracle-2.7-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oracle ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/target/gs-oracle-2.7-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-oracle >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 06.02.2016 @ 11:55:05 UTC
Update pom.xml
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-oracle <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-oracle ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-oracle >>>
[INFO]
Update pom.xml
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-oracle <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-oracle ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-oracle ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/target/dependency/gt-api-13-SNAPSHOT.jar> ;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/target/dependency/gwc-core-1.7-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-oracle ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/target/gs-oracle-2.7-SNAPSHOT.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-oracle/2.7-SNAPSHOT/gs-oracle-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/pom.xml> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-oracle/2.7-SNAPSHOT/gs-oracle-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/oracle/target/gs-oracle-2.7-SNAPSHOT-tests.jar> ; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-oracle/2.7-SNAPSHOT/gs-oracle-2.7-SNAPSHOT-tests.jar
[INFO]
[INFO] Building MySQL DataStore Extension 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-mysql ---
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-mysql ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-mysql ---
[ERROR] GC overhead limit exceeded -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/OutOfMemoryError
Hudson
February 6, 2016, 12:15pm
5
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/355/> ;
[...truncated 6015 lines...]
[INFO] Copying 6 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.1:testCompile (default-testCompile) @ gs-script-groovy ---
[INFO] Changes detected - recompiling the module!
[INFO] Using Groovy-Eclipse compiler to compile both Java and Groovy files
[INFO] Found location </var/lib/jenkins/.m2/repository/org/codehaus/groovy/groovy-eclipse-batch/2.3.7-01/groovy-eclipse-batch-2.3.7-01.jar> for className <org.eclipse.jdt.internal.compiler.batch.Main>
[INFO] no javaAgentClass seems to be set
[INFO] Compiling in a forked process using /var/lib/jenkins/.m2/repository/org/codehaus/groovy/groovy-eclipse-batch/2.3.7-01/groovy-eclipse-batch-2.3.7-01.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-script-groovy ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-script-groovy ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/script/groovy/target/gs-script-groovy-2.7-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-script-groovy ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/script/groovy/target/gs-script-groovy-2.7-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-script-groovy >>>
[INFO]
[INFO] --- groovy-eclipse-compiler:2.9.2-01:add-groovy-build-paths (default-add-groovy-build-paths) @ gs-script-groovy ---
[INFO] Adding /src/main/groovy to the list of source folders
[INFO] Adding /src/test/groovy to the list of test source folders
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-script-groovy ---
[INFO] [GitCommitIdMojo] build.timestamp = 06-Feb-2016 11:57
[INFO] [GitCommitIdMojo] build.build.time = 06.02.2016 @ 12:01:36 UTC
Update pom.xml
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-script-groovy <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-script-groovy ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/script/groovy/target/gs-script-groovy-2.7-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-script-groovy >>>
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 06.02.2016 @ 12:01:37 UTC
Update pom.xml
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-script-groovy <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-script-groovy ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/script/groovy/target/gs-script-groovy-2.7-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-script-groovy ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/script/groovy/target/dependency/gt-api-13-SNAPSHOT.jar> ;
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/script/groovy/target/dependency/gwc-core-1.7-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (default) @ gs-script-groovy ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [2.747s]
[INFO] Core Platform Module .............................. SUCCESS [4.692s]
[INFO] Open Web Service Module ........................... SUCCESS [6.595s]
[INFO] Main Module ....................................... SUCCESS [20.933s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.173s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [5.268s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [4.399s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.748s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [5.770s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [7.144s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [8.669s]
[INFO] Web Feature Service Module ........................ SUCCESS [12.066s]
[INFO] Web Map Service Module ............................ SUCCESS [13.440s]
[INFO] KML support for GeoServer ......................... SUCCESS [7.518s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [9.147s]
[INFO] REST Support Module ............................... SUCCESS [4.873s]
[INFO] REST Configuration Service Module ................. SUCCESS [9.738s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.088s]
[INFO] Core UI Module .................................... SUCCESS [11.958s]
[INFO] WMS UI Module ..................................... SUCCESS [5.764s]
[INFO] GWC UI Module ..................................... SUCCESS [6.898s]
[INFO] WFS UI Module ..................................... SUCCESS [4.152s]
[INFO] Demoes Module ..................................... SUCCESS [5.565s]
[INFO] WCS UI Module ..................................... SUCCESS [5.146s]
[INFO] Security UI Modules ............................... SUCCESS [0.146s]
[INFO] Security UI Core Module ........................... SUCCESS [9.718s]
[INFO] Security UI JDBC Module ........................... SUCCESS [4.745s]
[INFO] Security UI LDAP Module ........................... SUCCESS [4.615s]
[INFO] REST UI Module .................................... SUCCESS [4.189s]
[INFO] GeoServer Web Application ......................... SUCCESS [5.679s]
[INFO] Community Space ................................... SUCCESS [0.587s]
[INFO] Authentication by unique url key .................. SUCCESS [5.121s]
[INFO] WorldWind Format Module ........................... SUCCESS [4.839s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.594s]
[INFO] SpatiaLite Extension .............................. SUCCESS [4.455s]
[INFO] GeoServer JDBC KV Catalog ......................... SUCCESS [6.915s]
[INFO] Simple Feature Service ............................ SUCCESS [4.512s]
[INFO] Aggregating Data Store ............................ SUCCESS [2.861s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.608s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.242s]
[INFO] Web Processing Service Module ..................... SUCCESS [10.924s]
[INFO] GeoServer Scripting Extensions .................... SUCCESS [0.788s]
[INFO] Core Scripting Extension .......................... SUCCESS [6.212s]
[INFO] Web UI Scripting Extension ........................ SUCCESS [5.553s]
[INFO] BeanShell Scripting Extension ..................... SUCCESS [4.594s]
[INFO] Groovy Scripting Extension ........................ FAILURE [14:07.389s]
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] Python Scripting Extension ........................ SKIPPED
[INFO] JavaScript Scripting Extension .................... SKIPPED
[INFO] Ruby Scripting Extension .......................... SKIPPED
[INFO] WMS-EO ............................................ SKIPPED
[INFO] ColorMap .......................................... SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer mbtiles Extension ....................... SKIPPED
[INFO] GeoServer GeoPackage Extension .................... SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults .............. SKIPPED
[INFO] REST plugin community module ...................... SKIPPED
[INFO] GPX PPIO for WPS .................................. SKIPPED
[INFO] KML PPIO for WPS .................................. SKIPPED
[INFO] DownloadProcess ................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............ SKIPPED
[INFO] ActiveMQ .......................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ........... SKIPPED
[INFO] GeoServer JMS clustering module ................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module ............. SKIPPED
[INFO] Solr Module ....................................... SKIPPED
[INFO] GeoFence security integration ..................... SKIPPED
[INFO] REST SLD service .................................. SKIPPED
[INFO] Total time: 18:27.597s
[INFO] Finished at: Sat Feb 06 12:15:34 UTC 2016
[INFO] Final Memory: 596M/623M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (default) on project gs-script-groovy: An Ant BuildException has occured: java.lang.OutOfMemoryError: Java heap space
[ERROR] around Ant part ...<Groovydoc windowtitle="GeoServer Scripting Groovy API" destdir="target/groovydoc" sourcepath="src/main/groovy" use="true" packagenames="**.*" private="false"/>... @ 9:163 in <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/community/script/groovy/target/antrun/build-main.xml> ;
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-script-groovy
Hudson
February 7, 2016, 12:27pm
6
