See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/395/>
[...truncated 12301 lines...]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-imagemap ---
[INFO] Compiling 13 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-imagemap ---
[INFO] Copying 46 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-imagemap ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-imagemap ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-imagemap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/gs-imagemap-2.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-imagemap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/gs-imagemap-2.7-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemap >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-imagemap ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #1533 from ridethepenguin/secureddatastoreinfo-bug-2.7.x
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 15.03.2016 @ 19:34:15 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Mar-2016 10:39
[INFO] [GitCommitIdMojo] build.build.time = 17.03.2016 @ 10:49:33 UTC
[INFO] [GitCommitIdMojo] build.branch = 3532be9d464c2b336b19e50668d545b97ee23f30
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3532be9
[INFO] [GitCommitIdMojo] build.commit.id = 3532be9d464c2b336b19e50668d545b97ee23f30
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #1533 from ridethepenguin/secureddatastoreinfo-bug-2.7.x
[GEOS-7459] Securing an app-schema data store may result in ClassCastException being thrown
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemap <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-imagemap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/gs-imagemap-2.7-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemap >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 17.03.2016 @ 10:49:34 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemap <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-imagemap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/gs-imagemap-2.7-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-imagemap ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/dependency/gt-api-13-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/dependency/gwc-core-1.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-imagemap ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/gs-imagemap-2.7-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemap/2.7-SNAPSHOT/gs-imagemap-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemap/2.7-SNAPSHOT/gs-imagemap-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/gs-imagemap-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemap/2.7-SNAPSHOT/gs-imagemap-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/gs-imagemap-2.7-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemap/2.7-SNAPSHOT/gs-imagemap-2.7-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/imagemap/target/gs-imagemap-2.7-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-imagemap/2.7-SNAPSHOT/gs-imagemap-2.7-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building ImageI/O-Ext GDAL Coverage Extension 2.7-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-gdal ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-gdal ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-gdal ---
[INFO] [GitCommitIdMojo] build.build.time = 17.03.2016 @ 10:49:35 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-gdal ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-gdal ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-gdal ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-gdal ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-gdal ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-gdal ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target/gs-gdal-2.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-gdal ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target/gs-gdal-2.7-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-gdal >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-gdal <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-gdal ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target/gs-gdal-2.7-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-gdal >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 17.03.2016 @ 10:49:36 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-gdal <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-gdal ---
[INFO]
[INFO] --- maven-dependency-plugin:2.1:copy-dependencies (copy-dependencies) @ gs-gdal ---
[INFO] Copying gt-api-13-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target/dependency/gt-api-13-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.7-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target/dependency/gwc-core-1.7-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-gdal ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target/gs-gdal-2.7-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-gdal/2.7-SNAPSHOT/gs-gdal-2.7-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-gdal/2.7-SNAPSHOT/gs-gdal-2.7-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target/gs-gdal-2.7-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-gdal/2.7-SNAPSHOT/gs-gdal-2.7-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/gdal/target/gs-gdal-2.7-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-gdal/2.7-SNAPSHOT/gs-gdal-2.7-SNAPSHOT-sources.jar
[INFO]
[INFO] Building JP2K Coverage Extension 2.7-SNAPSHOT
Downloading: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-jp2k/13-SNAPSHOT/maven-metadata.xml
950/950 B
Downloaded: https://boundless.artifactoryonline.com/boundless/main/org/geotools/gt-jp2k/13-SNAPSHOT/maven-metadata.xml (950 B at 1.3 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-jp2k ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.7.x-nightly/ws/src/extension/jp2k/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-jp2k ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-jp2k ---
[ERROR] GC overhead limit exceeded -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/OutOfMemoryError
