See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/139/changes>
Changes:
[Andrea Aime] [GEOS-7599] WMS Request Causes Geoserver Lat/Lon Bounding Box to Change
[...truncated 298 lines...]
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-property/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-property/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-property/14-SNAPSHOT/maven-metadata.xml (958 B at 4.3 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/plugin/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/plugin/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/plugin/14-SNAPSHOT/maven-metadata.xml (570 B at 2.5 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-epsg-hsql/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-epsg-hsql/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-epsg-hsql/14-SNAPSHOT/maven-metadata.xml (959 B at 4.3 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-wms/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-wms/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-wms/14-SNAPSHOT/maven-metadata.xml (953 B at 4.1 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-render/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-render/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-render/14-SNAPSHOT/maven-metadata.xml (2 KB at 5.1 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-sld/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-sld/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/xsd/gt-xsd-sld/14-SNAPSHOT/maven-metadata.xml (961 B at 4.2 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-arcgrid/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-arcgrid/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-arcgrid/14-SNAPSHOT/maven-metadata.xml (957 B at 4.2 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-geotiff/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-geotiff/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-geotiff/14-SNAPSHOT/maven-metadata.xml (957 B at 4.3 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-gtopo30/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-gtopo30/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-gtopo30/14-SNAPSHOT/maven-metadata.xml (957 B at 4.2 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-image/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-image/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-image/14-SNAPSHOT/maven-metadata.xml (955 B at 4.2 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-imagemosaic/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-imagemosaic/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-imagemosaic/14-SNAPSHOT/maven-metadata.xml (961 B at 4.2 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-shapefile/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-shapefile/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-shapefile/14-SNAPSHOT/maven-metadata.xml (959 B at 4.2 KB/sec)
Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-transform/14-SNAPSHOT/maven-metadata.xml (959 B at 2.7 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/jdbc/gt-jdbc-postgis/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-postgis/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-postgis/14-SNAPSHOT/maven-metadata.xml (967 B at 4.3 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/jdbc/gt-jdbc/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc/14-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc/14-SNAPSHOT/maven-metadata.xml (576 B at 2.5 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-main ---
[INFO] Deleting <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/main/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-main ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.13:revision (default) @ gs-main ---
[WARNING] The POM for com.google.guava:guava:jar:15.0 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-main ---
[INFO] Copying 34 resources
[INFO] Copying 168 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-main ---
[INFO] Compiling 611 source files to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/main/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-main ---
[INFO] Copying 117 resources
[INFO] Copying 41 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-main ---
[INFO] Compiling 211 source files to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/main/target/test-classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/main/src/test/java/org/geoserver/catalog/impl/CatalogBuilderTest.java>:\[191,12\] error: cannot find symbol
[ERROR] class CatalogBuilderTest
<http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/main/src/test/java/org/geoserver/catalog/impl/CatalogBuilderTest.java>:\[191,34\] error: cannot find symbol
[INFO] 2 errors
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] Main Module ....................................... FAILURE [38.057s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 45.524s
[INFO] Finished at: Sat Jun 25 16:36:02 CEST 2016
[INFO] Final Memory: 44M/410M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-main: Compilation failure: Compilation failure:
[ERROR] <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/main/src/test/java/org/geoserver/catalog/impl/CatalogBuilderTest.java>:\[191,34\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/csw/web-csw/pom.xml> to org.geoserver.csw/gs-web-csw/2.8-SNAPSHOT/gs-web-csw-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/netcdf-out/pom.xml> to org.geoserver.extension/gs-netcdf-out/2.8-SNAPSHOT/gs-netcdf-out-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/arcsde/pom.xml> to org.geoserver.extension/gs-arcsde/2.8-SNAPSHOT/gs-arcsde-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/app-schema/app-schema-test/pom.xml> to org.geoserver.extension/gs-app-schema-test/2.8-SNAPSHOT/gs-app-schema-test-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/teradata/pom.xml> to org.geoserver.extension/gs-teradata/2.8-SNAPSHOT/gs-teradata-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/ogr/ogr-wps/pom.xml> to org.geoserver.extension/gs-ogr-wps/2.8-SNAPSHOT/gs-ogr-wps-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/wfs/pom.xml> to org.geoserver.web/gs-web-wfs/2.8-SNAPSHOT/gs-web-wfs-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/geosearch/pom.xml> to org.geoserver.extension/gs-geosearch/2.8-SNAPSHOT/gs-geosearch-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/dxf/core/pom.xml> to org.geoserver.extension/gs-dxf-core/2.8-SNAPSHOT/gs-dxf-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/security/pom.xml> to org.geoserver.extension/gs-security/2.8-SNAPSHOT/gs-security-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/security/web/pom.xml> to org.geoserver.extension/gs-web-sec/2.8-SNAPSHOT/gs-web-sec-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/wcs/pom.xml> to org.geoserver/gs-wcs/2.8-SNAPSHOT/gs-wcs-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/wcs1_1/pom.xml> to org.geoserver/gs-wcs1_1/2.8-SNAPSHOT/gs-wcs1_1-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/wcs1_0/pom.xml> to org.geoserver/gs-wcs1_0/2.8-SNAPSHOT/gs-wcs1_0-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/core/pom.xml> to org.geoserver.web/gs-web-core/2.8-SNAPSHOT/gs-web-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/wcs2_0/pom.xml> to org.geoserver/gs-wcs2_0/2.8-SNAPSHOT/gs-wcs2_0-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/monitor/hibernate/pom.xml> to org.geoserver.extension/gs-monitor-hibernate/2.8-SNAPSHOT/gs-monitor-hibernate-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/security/jdbc/pom.xml> to org.geoserver.security/gs-sec-jdbc/2.8-SNAPSHOT/gs-sec-jdbc-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/wcs2_0-eo/core/pom.xml> to org.geoserver.extension/gs-wcs2_0-eo-core/2.8-SNAPSHOT/gs-wcs2_0-eo-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/libjpeg-turbo/pom.xml> to org.geoserver.extension/gs-libjpeg-turbo/2.8-SNAPSHOT/gs-libjpeg-turbo-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/security/ldap/pom.xml> to org.geoserver.web/gs-web-sec-ldap/2.8-SNAPSHOT/gs-web-sec-ldap-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/csw/simple-store/pom.xml> to org.geoserver.csw/gs-csw-simple-store/2.8-SNAPSHOT/gs-csw-simple-store-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/app-schema/sample-data-access-test/pom.xml> to org.geoserver.extension/gs-sample-data-access-test/2.8-SNAPSHOT/gs-sample-data-access-test-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/feature-pregeneralized/pom.xml> to org.geoserver.extension/gs-feature-pregeneralized/2.8-SNAPSHOT/gs-feature-pregeneralized-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/csw/core/pom.xml> to org.geoserver.csw/gs-csw-core/2.8-SNAPSHOT/gs-csw-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/wfs/pom.xml> to org.geoserver/gs-wfs/2.8-SNAPSHOT/gs-wfs-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/security/ldap/pom.xml> to org.geoserver.security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml> to org.geoserver.extension/gs-wps-cluster-hazelcast/2.8-SNAPSHOT/gs-wps-cluster-hazelcast-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/excel/pom.xml> to org.geoserver.extension/gs-excel/2.8-SNAPSHOT/gs-excel-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/wms/pom.xml> to org.geoserver.web/gs-web-wms/2.8-SNAPSHOT/gs-web-wms-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/inspire/pom.xml> to org.geoserver.extension/gs-inspire/2.8-SNAPSHOT/gs-inspire-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/wps/wps-core/pom.xml> to org.geoserver.extension/gs-wps-core/2.8-SNAPSHOT/gs-wps-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/css/pom.xml> to org.geoserver.extension/gs-css/2.8-SNAPSHOT/gs-css-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/main/pom.xml> to org.geoserver/gs-main/2.8-SNAPSHOT/gs-main-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/netcdf/pom.xml> to org.geoserver.extension/gs-netcdf/2.8-SNAPSHOT/gs-netcdf-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/rest/pom.xml> to org.geoserver/gs-rest/2.8-SNAPSHOT/gs-rest-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/security/cas/pom.xml> to org.geoserver.security/gs-sec-cas/2.8-SNAPSHOT/gs-sec-cas-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/rest/pom.xml> to org.geoserver.web/gs-web-rest/2.8-SNAPSHOT/gs-web-rest-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/monitor/pom.xml> to org.geoserver.extension/gs-monitor/2.8-SNAPSHOT/gs-monitor-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/restconfig/pom.xml> to org.geoserver/gs-restconfig/2.8-SNAPSHOT/gs-restconfig-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/security/pom.xml> to org.geoserver.web/gs-web-sec/2.8-SNAPSHOT/gs-web-sec-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/wms/pom.xml> to org.geoserver/gs-wms/2.8-SNAPSHOT/gs-wms-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/community/proxy/pom.xml> to org.geoserver.community/gs-proxy/2.8-SNAPSHOT/gs-proxy-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/imagemap/pom.xml> to org.geoserver.extension/gs-imagemap/2.8-SNAPSHOT/gs-imagemap-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/xslt/pom.xml> to org.geoserver/gs-xslt/2.8-SNAPSHOT/gs-xslt-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/grib/pom.xml> to org.geoserver.extension/gs-grib/2.8-SNAPSHOT/gs-grib-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/csw/pom.xml> to org.geoserver/gs-csw/2.8-SNAPSHOT/gs-csw-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/importer/bdb/pom.xml> to org.geoserver.importer/gs-importer-bdb/2.8-SNAPSHOT/gs-importer-bdb-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/demo/pom.xml> to org.geoserver.web/gs-web-demo/2.8-SNAPSHOT/gs-web-demo-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/monitor/core/pom.xml> to org.geoserver.extension/gs-monitor-core/2.8-SNAPSHOT/gs-monitor-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/ogr/ogr-core/pom.xml> to org.geoserver.extension/gs-ogr-core/2.8-SNAPSHOT/gs-ogr-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/importer/core/pom.xml> to org.geoserver.importer/gs-importer-core/2.8-SNAPSHOT/gs-importer-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/gwc/pom.xml> to org.geoserver/gs-gwc/2.8-SNAPSHOT/gs-gwc-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/ogr/ogr-wfs/pom.xml> to org.geoserver.extension/gs-ogr-wfs/2.8-SNAPSHOT/gs-ogr-wfs-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/security/pom.xml> to org.geoserver/gs-security/2.8-SNAPSHOT/gs-security-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/h2/pom.xml> to org.geoserver.extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/wcs/pom.xml> to org.geoserver.web/gs-web-wcs/2.8-SNAPSHOT/gs-web-wcs-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/importer/pom.xml> to org.geoserver/gs-importer/2.8-SNAPSHOT/gs-importer-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/app/pom.xml> to org.geoserver.web/gs-web-app/2.8-SNAPSHOT/gs-web-app-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/control-flow/pom.xml> to org.geoserver.extension/gs-control-flow/2.8-SNAPSHOT/gs-control-flow-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/kml/pom.xml> to org.geoserver/gs-kml/2.8-SNAPSHOT/gs-kml-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/wcs2_0-eo/web/pom.xml> to org.geoserver.extension/gs-web-wcs2_0-eo/2.8-SNAPSHOT/gs-web-wcs2_0-eo-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/gwc/pom.xml> to org.geoserver.web/gs-web-gwc/2.8-SNAPSHOT/gs-web-gwc-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/security/core/pom.xml> to org.geoserver.web/gs-web-sec-core/2.8-SNAPSHOT/gs-web-sec-core-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/security/web/web-cas/pom.xml> to org.geoserver.security/gs-web-sec-cas/2.8-SNAPSHOT/gs-web-sec-cas-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/web/security/jdbc/pom.xml> to org.geoserver.web/gs-web-sec-jdbc/2.8-SNAPSHOT/gs-web-sec-jdbc-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/printing/pom.xml> to org.geoserver.extension/gs-printing/2.8-SNAPSHOT/gs-printing-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/importer/web/pom.xml> to org.geoserver.importer/gs-importer-web/2.8-SNAPSHOT/gs-importer-web-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/importer/rest/pom.xml> to org.geoserver.importer/gs-importer-rest/2.8-SNAPSHOT/gs-importer-rest-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/dxf/wps/pom.xml> to org.geoserver.extension/gs-dxf-wps/2.8-SNAPSHOT/gs-dxf-wps-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/querylayer/pom.xml> to org.geoserver.extension/gs-querylayer/2.8-SNAPSHOT/gs-querylayer-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/csw/api/pom.xml> to org.geoserver.csw/gs-csw-api/2.8-SNAPSHOT/gs-csw-api-2.8-SNAPSHOT.pom
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/wps/web-wps/pom.xml> to org.geoserver.extension/gs-web-wps/2.8-SNAPSHOT/gs-web-wps-2.8-SNAPSHOT.pom
channel stopped
