[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8-OpenJDK7 #181
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/181/changes&gt;
Changes:
[ben] [GEOT-5469] Support multivalued xlink:href ClientProperty
[...truncated 699 lines...]
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
testGetFeatureFilterFirstXlinkHref(org.geoserver.test.MultivaluedXlinkHrefClientPropertyTest) Time elapsed: 39 sec <<< FAILURE!
java.lang.AssertionError: expected:<2> but was:<1>
  at org.junit.Assert.fail(Assert.java:88)
  at org.junit.Assert.failNotEquals(Assert.java:743)
  at org.junit.Assert.assertEquals(Assert.java:118)
  at org.junit.Assert.assertEquals(Assert.java:555)
  at org.junit.Assert.assertEquals(Assert.java:542)
  at org.geoserver.test.AbstractAppSchemaTestSupport.assertXpathCount(AbstractAppSchemaTestSupport.java:358)
  at org.geoserver.test.MultivaluedXlinkHrefClientPropertyTest.testGetFeatureFilterFirstXlinkHref(MultivaluedXlinkHrefClientPropertyTest.java:68)
testGetFeatureFilterSecondXlinkHref(org.geoserver.test.MultivaluedXlinkHrefClientPropertyTest) Time elapsed: 42 sec <<< FAILURE!
  at org.geoserver.test.MultivaluedXlinkHrefClientPropertyTest.testGetFeatureFilterSecondXlinkHref(MultivaluedXlinkHrefClientPropertyTest.java:103)
Running org.geoserver.test.NestedIdSupportTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.654 sec
Running org.geoserver.test.Observation_2_0_WfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.724 sec
Running org.geoserver.test.PolymorphismInlineWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.311 sec
Running org.geoserver.test.PolymorphismWfsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.288 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.026 sec
Running org.geoserver.test.PropertySelectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.492 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.76 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.851 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.741 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.935 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.505 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.988 sec
Running org.geoserver.test.SecuredFeatureChainingTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.948 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.915 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.914 sec
Running org.geoserver.test.StringConstantIdWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.157 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.907 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.23 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.105 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.554 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.347 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Query:
   feature type: MappedFeatureType
   filter: [ shape intersects POLYGON ((-1.3650000000000033 52.475133749539246, -1.235000000000003 52.475133749539246, -1.235000000000003 52.52485219413131, -1.3650000000000033 52.52485219413131, -1.3650000000000033 52.475133749539246)) ]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   filter: [ shape intersects POLYGON ((-1.365 52.475, -1.235 52.475, -1.235 52.525, -1.365 52.525, -1.365 52.475)) ]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   filter: [[ shape intersects POLYGON ((-1.365 53.475, -1.235 53.475, -1.235 53.525, -1.365 53.525, -1.365 53.475)) ] AND [[ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = http://urn.opengis.net ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = a ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = b ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = c ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = d ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = e ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = f ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = g ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = h ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = i ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = j ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = k ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = l ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = m ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = n ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = o ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = p ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = q ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = r ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = S ] OR [ gsml:observationMethod/gsml:CGI_TermValue/gsml:value/@codeSpace = t ]]]
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Query:
   [properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.626 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.436 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.658 sec
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.787 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.634 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.771 sec
Running org.geoserver.test.web.Gml311LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.344 sec
Running org.geoserver.test.web.Gml32LinksTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.812 sec
Results :
Failed tests: testGetFeature(org.geoserver.test.MultivaluedXlinkHrefClientPropertyTest): expected:<2> but was:<1>
  testGetFeatureFilterFirstXlinkHref(org.geoserver.test.MultivaluedXlinkHrefClientPropertyTest): expected:<2> but was:<1>
  testGetFeatureFilterSecondXlinkHref(org.geoserver.test.MultivaluedXlinkHrefClientPropertyTest): expected:<2> but was:<1>
Tests run: 160, Failures: 3, Errors: 0, Skipped: 0
[JENKINS] Recording test results
log4j:WARN No appenders could be found for logger (org.apache.commons.beanutils.converters.BooleanConverter).
log4j:WARN Please initialize the log4j system properly.
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] BUILD FAILURE
[INFO] Total time: 3:12.247s
[INFO] Finished at: Sat Jul 30 11:51:16 CEST 2016
[INFO] Final Memory: 77M/622M
[WARNING] The requested profile "proxy" could not be activated because it does not exist.
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[JENKINS] Archiving <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/ws/src/extension/app-schema/app-schema-test/pom.xml&gt; to org.geoserver.extension/gs-app-schema-test/2.8-SNAPSHOT/gs-app-schema-test-2.8-SNAPSHOT.pom
channel stopped
See <http://build.geo-solutions.it/jenkins/job/GeoServer-2.8-OpenJDK7/182/&gt;
