[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x #1
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/1/&gt;
[...truncated 114506 lines...]
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/maven-metadata.xml (2 KB at 32.9 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/maven-metadata.xml
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/maven-metadata.xml (2 KB at 107.4 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/maven-metadata.xml
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/maven-metadata.xml (2 KB at 17.2 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/gs-geosearch-2.8-20150926.092843-557-tests.jar
2/8 KB
4/8 KB
6/8 KB
8/8 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/gs-geosearch-2.8-20150926.092843-557-tests.jar (8 KB at 7.4 KB/sec)
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/maven-metadata.xml (2 KB at 116.4 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/gs-geosearch-2.8-20150926.092843-557-sources.jar
2/20 KB
4/20 KB
6/20 KB
8/20 KB
10/20 KB
12/20 KB
14/20 KB
16/20 KB
18/20 KB
20/20 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/gs-geosearch-2.8-20150926.092843-557-sources.jar (20 KB at 292.4 KB/sec)
2/2 KB
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/gs-geosearch-2.8-20150926.092843-557-test-sources.jar
2/5 KB
4/5 KB
5/5 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-geosearch/2.8-SNAPSHOT/gs-geosearch-2.8-20150926.092843-557-test-sources.jar (5 KB at 41.6 KB/sec)
2/2 KB
[INFO]
[INFO] Building H2 DataStore Extension 2.8-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-h2 ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Documented improved null handling in FormatDateTimezone function
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.09.2015 @ 19:39:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 26-Sep-2015 09:25
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 09:28:46 UTC
[INFO] [GitCommitIdMojo] build.branch = f0e2ba28bdaaa4a26583e43426b5faa6187bf932
[INFO] [GitCommitIdMojo] build.commit.user.email = ben@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f0e2ba2
[INFO] [GitCommitIdMojo] build.commit.id = f0e2ba28bdaaa4a26583e43426b5faa6187bf932
[INFO] [GitCommitIdMojo] build.commit.message.full = Documented improved null handling in FormatDateTimezone function
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-h2 ---
[INFO] Copying 1 resource
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-h2 ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-h2 ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/h2/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-h2 ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-h2 ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-h2 ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-h2 ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-h2 >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-h2 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-h2 ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-h2 >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 09:28:48 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-h2 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-h2 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/h2/target/gs-h2-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-h2 ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/h2/target/gs-h2-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/h2/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/h2/target/gs-h2-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/h2/target/gs-h2-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/extension/h2/target/gs-h2-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-h2 ---
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/maven-metadata.xml (2 KB at 32.9 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557.jar
2/7 KB
4/7 KB
6/7 KB
7/7 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557.jar (7 KB at 10.0 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557.pom
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557.pom (2 KB at 21.5 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/maven-metadata.xml
2/2 KB
[WARNING] Checksum validation failed, expected 40f273e211f6f1a95beb393e961310bbdd021715 but is 9796f3e74dd8a70e79648e6d215f0db7d7eb08fc for http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/maven-metadata.xml (2 KB at 12.4 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/maven-metadata.xml
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/maven-metadata.xml (2 KB at 106.9 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/maven-metadata.xml
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/maven-metadata.xml (2 KB at 30.9 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557-tests.jar
2/4 KB
4/4 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557-tests.jar (4 KB at 51.3 KB/sec)
2/2 KB
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557-sources.jar
2/6 KB
4/6 KB
6/6 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557-sources.jar (6 KB at 58.6 KB/sec)
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/maven-metadata.xml (2 KB at 86.9 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557-test-sources.jar
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/gs-h2-2.8-20150926.092850-557-test-sources.jar (2 KB at 16.1 KB/sec)
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/extension/gs-h2/2.8-SNAPSHOT/maven-metadata.xml (2 KB at 5.3 KB/sec)
[INFO]
[INFO] Building SQL Server DataStore Extension 2.8-SNAPSHOT
Downloading: http://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-sqlserver/14-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc-sqlserver/14-SNAPSHOT/maven-metadata.xml
984/984 B
Downloaded: http://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-sqlserver/14-SNAPSHOT/maven-metadata.xml (984 B at 0.9 KB/sec)
Downloading: http://www.hibernatespatial.org/repository/org/geotools/jdbc/gt-jdbc-sqlserver/14-SNAPSHOT/maven-metadata.xml
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-sqlserver ---
[ERROR] GC overhead limit exceeded -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/OutOfMemoryError
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/2/changes&gt;
Changes:
[andrea.aime] [GEOS-7213] Check geoserverlogfile appender against FileAppender
[andrea.aime] GEOS-7189: Fix deserialization of boolean metadata parameter.
[...truncated 4872 lines...]
Tests run: 44, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 80.579 sec <<< FAILURE!
testLayoutLegendStyleTitleDPI(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest) Time elapsed: 2020 sec <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[image/png]> but was:<[text/xml]>
  at junit.framework.Assert.assertEquals(Assert.java:100)
  at junit.framework.Assert.assertEquals(Assert.java:107)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsImage(GeoServerSystemTestSupport.java:1241)
  at org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest.testLayoutLegendStyleTitleDPI(GetMapIntegrationTest.java:836)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.wms.wms_1_1_1.GetStylesIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.506 sec
Running org.geoserver.wms.wms_1_1_1.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 21.031 sec
Running org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest
Tests run: 4, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 33.031 sec <<< FAILURE!
testGlobalCapabilities(org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest) Time elapsed: 26929 sec <<< ERROR!
java.lang.OutOfMemoryError: GC overhead limit exceeded
  at com.sun.org.apache.xerces.internal.dom.ElementImpl.getAttributes(ElementImpl.java:139)
  at com.sun.org.apache.xml.internal.dtm.ref.dom2dtm.DOM2DTM.nextNode(DOM2DTM.java:534)
  at com.sun.org.apache.xml.internal.dtm.ref.DTMDefaultBase._nextsib(DTMDefaultBase.java:567)
  at com.sun.org.apache.xml.internal.dtm.ref.DTMDefaultBase.getNextSibling(DTMDefaultBase.java:1142)
  at com.sun.org.apache.xml.internal.dtm.ref.DTMDefaultBaseTraversers$ChildTraverser.next(DTMDefaultBaseTraversers.java:465)
  at com.sun.org.apache.xpath.internal.axes.ChildTestIterator.getNextNode(ChildTestIterator.java:85)
  at com.sun.org.apache.xpath.internal.axes.BasicTestIterator.nextNode(BasicTestIterator.java:172)
  at com.sun.org.apache.xpath.internal.axes.NodeSequence.nextNode(NodeSequence.java:344)
  at com.sun.org.apache.xpath.internal.objects.XNodeSet.compare(XNodeSet.java:617)
  at com.sun.org.apache.xpath.internal.objects.XNodeSet.equals(XNodeSet.java:707)
  at com.sun.org.apache.xpath.internal.operations.Equals.operate(Equals.java:50)
  at com.sun.org.apache.xpath.internal.operations.Operation.execute(Operation.java:114)
  at com.sun.org.apache.xpath.internal.axes.PredicatedNodeTest.executePredicates(PredicatedNodeTest.java:344)
  at com.sun.org.apache.xpath.internal.axes.PredicatedNodeTest.acceptNode(PredicatedNodeTest.java:481)
  at com.sun.org.apache.xpath.internal.axes.DescendantIterator.nextNode(DescendantIterator.java:225)
  at com.sun.org.apache.xpath.internal.axes.NodeSequence.runTo(NodeSequence.java:503)
  at com.sun.org.apache.xml.internal.dtm.ref.DTMNodeList.<init>(DTMNodeList.java:83)
  at com.sun.org.apache.xpath.internal.objects.XNodeSet.nodelist(XNodeSet.java:348)
  at com.sun.org.apache.xpath.internal.jaxp.XPathImpl.getResultAsType(XPathImpl.java:318)
  at com.sun.org.apache.xpath.internal.jaxp.XPathImpl.evaluate(XPathImpl.java:271)
  at org.custommonkey.xmlunit.jaxp13.Jaxp13XpathEngine.getMatchingNodes(Jaxp13XpathEngine.java:87)
  at org.custommonkey.xmlunit.XMLAssert.assertXpathExists(XMLAssert.java:898)
  at org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest.testGlobalCapabilities(LayerWorkspaceTest.java:37)
testWorkspaceCapabilities(org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest) Time elapsed: 5499 sec <<< ERROR!
Running org.geoserver.wms.wms_1_1_1.SLDWithInlineFeatureTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.189 sec
Running org.geoserver.wms.wms_1_1_1.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.624 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAllowedMimeTypesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.682 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesAuthorityURLAndIdentifierTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.893 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesBBOXForEachCRSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.71 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesIntegrationTest
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.242 sec
Running org.geoserver.wms.wms_1_3.CapabilitiesSystemTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.963 sec
Running org.geoserver.wms.wms_1_3.CustomDimensionsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.887 sec
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.522 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.482 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.648 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.336 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.398 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.267 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.776 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.487 sec
Results :
Failed tests: testScaleTolerance(org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
  testLayoutLegendStyleTitleDPI(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest): expected:<[image/png]> but was:<[text/xml]>
Tests in error:
  testGlobalCapabilities(org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest): GC overhead limit exceeded
  testWorkspaceCapabilities(org.geoserver.wms.wms_1_1_1.LayerWorkspaceTest): GC overhead limit exceeded
Tests run: 692, Failures: 2, Errors: 2, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.313s]
[INFO] Core Platform Module .............................. SUCCESS [16.096s]
[INFO] Open Web Service Module ........................... SUCCESS [17.992s]
[INFO] Main Module ....................................... SUCCESS [2:36.375s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.382s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [48.227s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:22.595s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.048s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [36.372s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [48.446s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:16.889s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:08.301s]
[INFO] Web Map Service Module ............................ FAILURE [7:18.649s]
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17:46.041s
[INFO] Finished at: Sat Sep 26 11:23:07 UTC 2015
[INFO] Final Memory: 44M/276M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/3/&gt;
[...truncated 24687 lines...]
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-ldap ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-ldap ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-ldap ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-ldap ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sec-ldap >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-sec-ldap ---
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-7189: Fix deserialization of boolean metadata parameter.
[INFO] [GitCommitIdMojo] build.commit.time = 26.09.2015 @ 09:53:50 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 26-Sep-2015 13:51
[INFO] [GitCommitIdMojo] build.build.time = 26.09.2015 @ 13:55:54 UTC
[INFO] [GitCommitIdMojo] build.branch = e236bc312171f97a209b7244df67d2e73da40596
[INFO] [GitCommitIdMojo] build.commit.user.email = mase@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Marcus Sen
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e236bc3
[INFO] [GitCommitIdMojo] build.commit.id = e236bc312171f97a209b7244df67d2e73da40596
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-7189: Fix deserialization of boolean metadata parameter.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sec-ldap <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-sec-ldap ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sec-ldap >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sec-ldap <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-sec-ldap ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/security/ldap/target/gs-sec-ldap-2.8-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-sec-ldap ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/security/ldap/target/gs-sec-ldap-2.8-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/security/ldap/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/security/ldap/target/gs-sec-ldap-2.8-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/security/ldap/target/gs-sec-ldap-2.8-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/security/ldap/target/gs-sec-ldap-2.8-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-sec-ldap ---
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/maven-metadata.xml (2 KB at 55.4 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-20150926.135554-558.jar
2/46 KB
4/46 KB
6/46 KB
8/46 KB
10/46 KB
12/46 KB
14/46 KB
16/46 KB
18/46 KB
20/46 KB
22/46 KB
24/46 KB
26/46 KB
28/46 KB
30/46 KB
32/46 KB
34/46 KB
36/46 KB
38/46 KB
40/46 KB
42/46 KB
44/46 KB
46/46 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-20150926.135554-558.jar (46 KB at 144.4 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-20150926.135554-558.pom
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-20150926.135554-558.pom (2 KB at 10.9 KB/sec)
Downloading: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/maven-metadata.xml
2/2 KB
Downloaded: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/maven-metadata.xml (2 KB at 29.4 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/maven-metadata.xml
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/maven-metadata.xml (2 KB at 77.5 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/maven-metadata.xml
2/2 KB
Uploaded: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/maven-metadata.xml (2 KB at 5.2 KB/sec)
Uploading: http://repo.boundlessgeo.com/main/org/geoserver/security/gs-sec-ldap/2.8-SNAPSHOT/gs-sec-ldap-2.8-20150926.135554-558-tests.jar
2/17 KB
4/17 KB
6/17 KB
8/17 KB
10/17 KB
12/17 KB
14/17 KB
16/17 KB
17/17 KB
[INFO]
[INFO] GeoServer ......................................... SUCCESS [41.625s]
[INFO] Core Platform Module .............................. SUCCESS [15.973s]
[INFO] Open Web Service Module ........................... SUCCESS [1:49.487s]
[INFO] Main Module ....................................... SUCCESS [1:13.731s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.259s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [40.044s]
[INFO] GeoServer LDAP Security Module .................... FAILURE [30:01.527s]
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] Total time: 34:46.761s
[INFO] Finished at: Sat Sep 26 14:25:55 UTC 2015
[INFO] Final Memory: 39M/297M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-sec-ldap: Failed to deploy artifacts: Could not transfer artifact org.geoserver.security:gs-sec-ldap:jar:tests:2.8-20150926.135554-558 from/to boundless (http://repo.boundlessgeo.com/main): Read timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-sec-ldap
See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/4/changes&gt;
