See <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/108/changes>
Changes:
[andrea.aime] [GEOS-7297] Fix issue where Stored Queries fail under load.
[...truncated 3776 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 20-Dec-2015 11:29
[INFO] [GitCommitIdMojo] build.build.time = 20.12.2015 @ 11:37:52 UTC
[INFO] [GitCommitIdMojo] build.branch = b00ca479330fa16d5836b64db1b273c209b9ff03
[INFO] [GitCommitIdMojo] build.commit.user.email = dean.povey@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Dean Povey
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = b00ca47
[INFO] [GitCommitIdMojo] build.commit.id = b00ca479330fa16d5836b64db1b273c209b9ff03
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-7297] Fix issue where Stored Queries fail under load.
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-wcs2_0 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wcs2_0/target/gs-wcs2_0-2.8-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0 >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wcs2_0 ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-7297] Fix issue where Stored Queries fail under load.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 20.12.2015 @ 10:35:58 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0 <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-wcs2_0 ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wcs2_0/target/gs-wcs2_0-2.8-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-wcs2_0 ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wcs2_0/target/gs-wcs2_0-2.8-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.8-SNAPSHOT/gs-wcs2_0-2.8-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wcs2_0/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.8-SNAPSHOT/gs-wcs2_0-2.8-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wcs2_0/target/gs-wcs2_0-2.8-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.8-SNAPSHOT/gs-wcs2_0-2.8-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wcs2_0/target/gs-wcs2_0-2.8-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.8-SNAPSHOT/gs-wcs2_0-2.8-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wcs2_0/target/gs-wcs2_0-2.8-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-wcs2_0/2.8-SNAPSHOT/gs-wcs2_0-2.8-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Feature Service Module 2.8-SNAPSHOT
Downloading: http://www.hibernatespatial.org/repository/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml
Downloading: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml
966/966 B
Downloaded: https://repo.boundlessgeo.com/main/org/geotools/jdbc/gt-jdbc-h2/14-SNAPSHOT/maven-metadata.xml (966 B at 2.0 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-wfs ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-wfs ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-wfs ---
[INFO] [GitCommitIdMojo] build.build.time = 20.12.2015 @ 11:37:55 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wfs ---
[INFO] Copying 11 resources
[INFO] Copying 10 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wfs ---
[INFO] Compiling 249 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wfs ---
[INFO] Copying 32 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wfs ---
[INFO] Compiling 90 source files to <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[87,78\] error: cannot find symbol
[ERROR] class File
<http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[97,78\] error: cannot find symbol
[ERROR] class File
<http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[115,109\] error: cannot find symbol
[ERROR] class File
<http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[129,109\] error: cannot find symbol
[ERROR] class File
<http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[141,109\] error: cannot find symbol
[ERROR] class File
<http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[177,66\] error: cannot find symbol
[INFO] 6 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.659s]
[INFO] Core Platform Module .............................. SUCCESS [15.639s]
[INFO] Open Web Service Module ........................... SUCCESS [19.989s]
[INFO] Main Module ....................................... SUCCESS [2:41.251s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.451s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [47.407s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:22.582s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.928s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [39.921s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [45.717s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:09.025s]
[INFO] Web Feature Service Module ........................ FAILURE [19.071s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8:40.439s
[INFO] Finished at: Sun Dec 20 11:38:11 UTC 2015
[INFO] Final Memory: 45M/287M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wfs: Compilation failure: Compilation failure:
[ERROR] class File
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[97,78\] error: cannot find symbol
[ERROR] class File
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[115,109\] error: cannot find symbol
[ERROR] class File
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[129,109\] error: cannot find symbol
[ERROR] class File
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[141,109\] error: cannot find symbol
[ERROR] class File
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-2.8.x/ws/src/wfs/src/test/java/org/geoserver/wfs/StoredQueryProviderTest.java>:\[177,66\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
