See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/117/changes>
Changes:
[tbarsballe] Update imagemosiac tutorial
[ksmith] GEOS-7116, Add unit tests for ImportTaskTable
[ksmith] GEOS-7116, Force CRSPanel to update model on Find to match manual update behaviour
[tbarsballe] [GEOS-7270]
[...truncated 4827 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Results :
Failed tests: testIndexedTransparency(org.geoserver.wms.map.GetMapIntegrationTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
testFourBits(org.geoserver.wms.map.GetMapIntegrationTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
testCascadeGetMapOnto110(org.geoserver.wms.wms_1_1_1.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
testCascadeGetMapOnto130(org.geoserver.wms.wms_1_1_1.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
testCascadeGetMapOnto11(org.geoserver.wms.wms_1_3.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
testCascadeGetMapOnto13(org.geoserver.wms.wms_1_3.WMSCascadeTest): expected:<[image/png]> but was:<[text/xml]>
Tests run: 695, Failures: 6, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [44.102s]
[INFO] Core Platform Module .............................. SUCCESS [20.233s]
[INFO] Open Web Service Module ........................... SUCCESS [34.257s]
[INFO] Main Module ....................................... SUCCESS [4:16.980s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.687s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [33.935s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.134s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.772s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.452s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:15.379s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:06.407s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:23.690s]
[INFO] Web Map Service Module ............................ FAILURE [4:54.123s]
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 19:55.170s
[INFO] Finished at: Fri Dec 11 16:53:02 CET 2015
[INFO] Final Memory: 61M/572M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
