[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x #128
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/128/changes&gt;
Changes:
[andrea.aime] [GEOS-7297] Fix issue where Stored Queries fail under load.
[...truncated 3127 lines...]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-wfs ---
[INFO] Copying 11 resources
[INFO] Copying 10 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-wfs ---
[INFO] Compiling 249 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/ws/src/wfs/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-wfs ---
[INFO] Copying 32 resources
[INFO] skip non existing resourceDirectory <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/ws/src/wfs/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-wfs ---
[INFO] Compiling 90 source files to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/ws/src/wfs/target/test-classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[87,78] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[97,78] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[115,109] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[129,109] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[141,109] error: cannot find symbol
[ERROR] \.jenkins\jobs\GeoServer-2.8.x\workspace\src\wfs\src\test\java\org\geoserver\wfs\StoredQueryProviderTest.java:[177,66] error: cannot find symbol
[INFO] 6 errors
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [16.643s]
[INFO] Core Platform Module .............................. SUCCESS [21.185s]
[INFO] Open Web Service Module ........................... SUCCESS [35.382s]
[INFO] Main Module ....................................... SUCCESS [4:24.528s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.147s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [36.131s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.435s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.085s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.107s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:17.307s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:10.160s]
[INFO] Web Feature Service Module ........................ FAILURE [21.550s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11:52.169s
[INFO] Finished at: Sun Dec 20 11:50:05 CET 2015
[INFO] Final Memory: 59M/553M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wfs: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/129/changes&gt;
Changes:
[andrea.aime] Revert "[GEOS-7297] Fix issue where Stored Queries fail under load."
[...truncated 4376 lines...]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.36 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.416 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.242 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.59 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.76 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.905 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.841 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.671 sec
Results :
Failed tests: testTimeoutOption(org.geoserver.wms.map.RenderedImageMapOutputFormatTest): Timeout was not reached
Tests run: 697, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[INFO]
[INFO] GeoServer ......................................... SUCCESS [18.345s]
[INFO] Core Platform Module .............................. SUCCESS [20.301s]
[INFO] Open Web Service Module ........................... SUCCESS [26.400s]
[INFO] Main Module ....................................... SUCCESS [4:25.563s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.848s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [34.745s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [15.163s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.063s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:13.068s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2:16.891s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [3:21.370s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:29.357s]
[INFO] Web Map Service Module ............................ FAILURE [4:06.539s]
[INFO] Total time: 22:11.786s
[INFO] Finished at: Sun Dec 20 18:14:19 CET 2015
[INFO] Final Memory: 59M/574M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/130/&gt;
