[Geoserver-devel] Build failed in Jenkins: GeoServer-2.8.x #134
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/134/changes&gt;
Changes:
[dean.povey] [GEOS-7297] Fix issue where Stored Queries fail under load.
[...truncated 4228 lines...]
Running org.geoserver.wms.wms_1_3.DimensionsRasterCapabilitiesTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.999 sec
Running org.geoserver.wms.wms_1_3.DimensionsVectorCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.633 sec
Running org.geoserver.wms.wms_1_3.GetCapabilitiesLegendUR_1_3_0LTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.375 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Results for FeatureType 'http://www.opengis.net/cite/geometry:Polygons’:
id = t0002
polygonProperty = [GEOMETRY (Polygon) with 5 points]
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.734 sec
Running org.geoserver.wms.wms_1_3.GetMapIntegrationTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.984 sec
Running org.geoserver.wms.wms_1_3.LayerGroupWorkspaceTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.416 sec
Running org.geoserver.wms.wms_1_3.LayerWorkspaceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.6 sec
Running org.geoserver.wms.wms_1_3.WMSCascadeTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.819 sec
Results :
Failed tests: testTimeoutOption(org.geoserver.wms.map.RenderedImageMapOutputFormatTest): Timeout was not reached
Tests run: 697, Failures: 1, Errors: 0, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [11.527s]
[INFO] Core Platform Module .............................. SUCCESS [21.169s]
[INFO] Open Web Service Module ........................... SUCCESS [21.925s]
[INFO] Main Module ....................................... SUCCESS [4:06.771s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.909s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [36.281s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [14.653s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.665s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:11.983s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:18.665s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:11.188s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:29.566s]
[INFO] Web Map Service Module ............................ FAILURE [4:17.811s]
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 18:49.005s
[INFO] Finished at: Thu Dec 24 18:56:18 CET 2015
[INFO] Final Memory: 59M/572M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\wms\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/135/changes&gt;
