See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/139/changes>
Changes:
[groldan] Set slf4j dependencies version in root pom.
[...truncated 19557 lines...]
testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest) Time elapsed: 32 sec <<< ERROR!
org.apache.wicket.WicketRuntimeException: There is no application attached to current thread main
at org.apache.wicket.Application.get(Application.java:179)
at org.apache.wicket.Component.getApplication(Component.java:1386)
at org.apache.wicket.Component.<init>(Component.java:928)
at org.apache.wicket.MarkupContainer.<init>(MarkupContainer.java:113)
at org.apache.wicket.MarkupContainer.<init>(MarkupContainer.java:105)
at org.apache.wicket.Page.<init>(Page.java:237)
at org.apache.wicket.markup.html.WebPage.<init>(WebPage.java:185)
at org.geoserver.web.GeoServerBasePage.<init>(GeoServerBasePage.java:93)
at org.geoserver.web.GeoServerSecuredPage.<init>(GeoServerSecuredPage.java:33)
at org.geoserver.web.data.store.AbstractCoverageStorePage.<init>(AbstractCoverageStorePage.java:34)
at org.geoserver.web.data.store.CoverageStoreNewPage.<init>(CoverageStoreNewPage.java:34)
at org.geoserver.web.data.store.raster.GribRasterEditPanelTest.testGribCreate(GribRasterEditPanelTest.java:39)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest) Time elapsed: 33 sec <<< ERROR!
java.lang.IllegalStateException: you can only locate or create sessions in the context of a request cycle
at org.apache.wicket.Session.findOrCreate(Session.java:208)
at org.apache.wicket.Session.get(Session.java:252)
at org.geoserver.web.GeoServerWicketTestSupport.clearErrorMessages(GeoServerWicketTestSupport.java:54)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:33)
org.geoserver.web.data.store.raster.GribRasterEditPanelTest Time elapsed: 33 sec <<< ERROR!
java.lang.NullPointerException
at org.geoserver.web.GeoServerWicketTestSupport.onTearDown(GeoServerWicketTestSupport.java:60)
at org.geoserver.test.GeoServerSystemTestSupport.tearDown(GeoServerSystemTestSupport.java:246)
at org.geoserver.test.GeoServerSystemTestSupport.tearDown(GeoServerSystemTestSupport.java:154)
at org.geoserver.test.GeoServerBaseTestSupport.doTearDownClass(GeoServerBaseTestSupport.java:205)
Results :
Tests in error:
testCoverageView(org.geoserver.catalog.CoverageViewReaderTest): Could not initialize class javax.imageio.ImageIO
testImage(org.geoserver.grib.GribDataTest): Could not initialize class ucar.nc2.dataset.NetcdfDataset
testFormatSupported(org.geoserver.grib.GribDataTest): Could not initialize class org.geotools.imageio.netcdf.utilities.NetCDFUtilities
testGribEdit(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): Could not initialize class org.geotools.imageio.netcdf.utilities.NetCDFUtilities
testGribEdit(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): you can only locate or create sessions in the context of a request cycle
testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): There is no application attached to current thread main
testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): you can only locate or create sessions in the context of a request cycle
Tests run: 8, Failures: 0, Errors: 8, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.616s]
[INFO] Core Platform Module .............................. SUCCESS [13.314s]
[INFO] Open Web Service Module ........................... SUCCESS [14.638s]
[INFO] Main Module ....................................... SUCCESS [2:11.150s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.255s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [42.876s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1:15.906s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.053s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [28.699s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [34.405s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [51.649s]
[INFO] Web Feature Service Module ........................ SUCCESS [1:40.058s]
[INFO] Web Map Service Module ............................ SUCCESS [2:09.140s]
[INFO] KML support for GeoServer ......................... SUCCESS [37.535s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:14.854s]
[INFO] REST Support Module ............................... SUCCESS [17.939s]
[INFO] REST Configuration Service Module ................. SUCCESS [1:17.213s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.115s]
[INFO] Core UI Module .................................... SUCCESS [57.475s]
[INFO] WMS UI Module ..................................... SUCCESS [24.924s]
[INFO] GWC UI Module ..................................... SUCCESS [42.844s]
[INFO] WFS UI Module ..................................... SUCCESS [14.184s]
[INFO] Demoes Module ..................................... SUCCESS [24.372s]
[INFO] WCS UI Module ..................................... SUCCESS [18.187s]
[INFO] Security UI Modules ............................... SUCCESS [0.199s]
[INFO] Security UI Core Module ........................... SUCCESS [1:36.732s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:13.629s]
[INFO] Security UI LDAP Module ........................... SUCCESS [22.275s]
[INFO] REST UI Module .................................... SUCCESS [15.627s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.127s]
[INFO] Printing Module ................................... SUCCESS [16.715s]
[INFO] Community Space ................................... SUCCESS [0.111s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.375s]
[INFO] GeoServer Web Application ......................... SUCCESS [6.671s]
[INFO] Application Schema Support ........................ SUCCESS [0.452s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:07.848s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [15.773s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [15.421s]
[INFO] GeoSearch Index Module ............................ SUCCESS [15.415s]
[INFO] H2 DataStore Extension ............................ SUCCESS [11.779s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [0.469s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.135s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.549s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.575s]
[INFO] ImageMap Output Format ............................ SUCCESS [10.306s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.659s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.664s]
[INFO] OGR parent ........................................ SUCCESS [0.105s]
[INFO] OGR CORE .......................................... SUCCESS [2.323s]
[INFO] OGR WFS ........................................... SUCCESS [12.355s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.101s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:11.951s]
[INFO] OGR WPS ........................................... SUCCESS [15.030s]
[INFO] Excel Output Format ............................... SUCCESS [17.889s]
[INFO] Chart external graphics support ................... SUCCESS [0.654s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.555s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.442s]
[INFO] OWS request flow controller ....................... SUCCESS [15.534s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [29.160s]
[INFO] Web Processing Service GUI ........................ SUCCESS [34.850s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [22.398s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.800s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.192s]
[INFO] Core Monitor Extension ............................ SUCCESS [16.519s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [9.558s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.198s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [7.518s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [0.200s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [2.677s]
[INFO] XLST based WFS output format ...................... SUCCESS [24.912s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [28.546s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [19.022s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.151s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [13.514s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [13.774s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [44.564s]
[INFO] CSW UI Module ..................................... SUCCESS [12.938s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.110s]
[INFO] DXF WFS output format ............................. SUCCESS [17.512s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [14.349s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.103s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [24.017s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [16.519s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [12.425s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.201s]
[INFO] Importer Core Module .............................. SUCCESS [53.987s]
[INFO] Importer REST Api Module .......................... SUCCESS [49.528s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [27.554s]
[INFO] Importer Web UI Module ............................ SUCCESS [17.771s]
[INFO] GRIB Coverage Format .............................. FAILURE [15.256s]
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 36:37.671s
[INFO] Finished at: Mon Feb 01 18:42:49 UTC 2016
[INFO] Final Memory: 95M/168M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-grib: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/extension/grib/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-grib
