[Geoserver-devel] Build failed in Jenkins: geoserver-2.8.x #158
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/158/&gt;
[...truncated 1668 lines...]
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.375 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.784 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.631 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.363 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.916 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.211 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.213 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.038 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.132 sec
Running org.geoserver.util.DefaultCacheProviderTest
12 Feb 02:38:59 WARN [geoserver.util] - Multiple Cache Providers in context: testCacheProvider1, testCacheProvider2
  Using testCacheProvider1. Override by setting system property GEOSERVER_DEFAULT_CACHE_PROVIDER
Tests run: 5, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.009 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.246 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.355 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.178 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.652 sec <<< FAILURE!
testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest) Time elapsed: 380 sec <<< ERROR!
org.opengis.referencing.FactoryException: Database failure while creating a 'CoordinateReferenceSystem' object for code "EPSG:4326".
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.databaseFailure(DirectEpsgFactory.java:3061)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateReferenceSystem(DirectEpsgFactory.java:2099)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
  at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:644)
  at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
  at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
  at org.geotools.referencing.CRS.decode(CRS.java:520)
  at org.geotools.referencing.CRS.decode(CRS.java:448)
  at org.vfny.geoserver.crs.OvverideTransformationsTest.testFallbackOnEPSGDatabaseStd(OvverideTransformationsTest.java:98)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Caused by: java.sql.SQLException: Database lock acquisition failure: attempt to connect while db opening /closing
  at org.hsqldb.jdbc.JDBCUtil.sqlException(Unknown Source)
  at org.hsqldb.jdbc.JDBCConnection.<init>(Unknown Source)
  at org.hsqldb.jdbc.JDBCDriver.getConnection(Unknown Source)
  at org.hsqldb.jdbc.JDBCDataSource.getConnection(Unknown Source)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.getConnection(DirectEpsgFactory.java:3262)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.prepareStatement(DirectEpsgFactory.java:779)
  at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateReferenceSystem(DirectEpsgFactory.java:1940)
  ... 46 more
Caused by: org.hsqldb.HsqlException: Database lock acquisition failure: attempt to connect while db opening /closing
  at org.hsqldb.error.Error.error(Unknown Source)
  at org.hsqldb.DatabaseManager.getDatabase(Unknown Source)
  at org.hsqldb.DatabaseManager.newSession(Unknown Source)
  ... 53 more
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.344 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.072 sec
Results :
Tests in error:
  testFallbackOnEPSGDatabaseStd(org.vfny.geoserver.crs.OvverideTransformationsTest): Database failure while creating a 'CoordinateReferenceSystem' object for code "EPSG:4326".
Tests run: 687, Failures: 0, Errors: 1, Skipped: 2
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.735s]
[INFO] Core Platform Module .............................. SUCCESS [15.667s]
[INFO] Open Web Service Module ........................... SUCCESS [23.450s]
[INFO] Main Module ....................................... FAILURE [2:32.301s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] REST UI Module .................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] OGR parent ........................................ SKIPPED
[INFO] OGR CORE .......................................... SKIPPED
[INFO] OGR WFS ........................................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] OGR WPS ........................................... SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web process status sharing with Hazelcast ......... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................ SKIPPED
[INFO] DXF WFS output format ............................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] GRIB Coverage Format .............................. SKIPPED
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:25.172s
[INFO] Finished at: Fri Feb 12 02:39:01 UTC 2016
[INFO] Final Memory: 39M/318M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.8.x/159/&gt;
