See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-2.8.x/160/changes>
Changes:
[groldan] Set slf4j dependencies version in root pom.
[...truncated 19607 lines...]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
Results :
Tests in error:
testCoverageView(org.geoserver.catalog.CoverageViewReaderTest): javax.imageio.spi.ImageReaderSpi: Provider org.geotools.imageio.netcdf.NetCDFImageReaderSpi could not be instantiated
testImage(org.geoserver.grib.GribDataTest): Could not initialize class ucar.nc2.dataset.NetcdfDataset
testFormatSupported(org.geoserver.grib.GribDataTest): Could not initialize class org.geotools.imageio.netcdf.utilities.NetCDFUtilities
testGribEdit(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): Could not initialize class javax.imageio.ImageIO
testGribEdit(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): you can only locate or create sessions in the context of a request cycle
testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): There is no application attached to current thread main
testGribCreate(org.geoserver.web.data.store.raster.GribRasterEditPanelTest): you can only locate or create sessions in the context of a request cycle
Tests run: 8, Failures: 0, Errors: 8, Skipped: 0
[JENKINS] Recording test results
[JENKINS] Archiving disabled
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 0 seconds
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [13.120s]
[INFO] Core Platform Module .............................. SUCCESS [19.516s]
[INFO] Open Web Service Module ........................... SUCCESS [22.511s]
[INFO] Main Module ....................................... SUCCESS [4:08.400s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.749s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [34.192s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [21.872s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.259s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:08.125s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:12.306s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [2:02.382s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:10.803s]
[INFO] Web Map Service Module ............................ SUCCESS [4:35.793s]
[INFO] KML support for GeoServer ......................... SUCCESS [54.615s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:01.392s]
[INFO] REST Support Module ............................... SUCCESS [26.130s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:23.403s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.374s]
[INFO] Core UI Module .................................... SUCCESS [2:00.479s]
[INFO] WMS UI Module ..................................... SUCCESS [37.706s]
[INFO] GWC UI Module ..................................... SUCCESS [1:14.276s]
[INFO] WFS UI Module ..................................... SUCCESS [18.580s]
[INFO] Demoes Module ..................................... SUCCESS [35.053s]
[INFO] WCS UI Module ..................................... SUCCESS [25.381s]
[INFO] Security UI Modules ............................... SUCCESS [0.686s]
[INFO] Security UI Core Module ........................... SUCCESS [2:15.939s]
[INFO] Security UI JDBC Module ........................... SUCCESS [1:29.597s]
[INFO] Security UI LDAP Module ........................... SUCCESS [23.275s]
[INFO] REST UI Module .................................... SUCCESS [19.079s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.727s]
[INFO] Community Space ................................... SUCCESS [0.390s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.718s]
[INFO] Application Schema Support ........................ SUCCESS [0.406s]
[INFO] Application Schema Integration Test ............... SUCCESS [2:37.997s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [17.534s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [20.062s]
[INFO] GeoSearch Index Module ............................ SUCCESS [19.781s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.649s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.264s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.468s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.201s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.248s]
[INFO] ImageMap Output Format ............................ SUCCESS [13.026s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.466s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.341s]
[INFO] OGR parent ........................................ SUCCESS [0.359s]
[INFO] OGR CORE .......................................... SUCCESS [3.167s]
[INFO] OGR WFS ........................................... SUCCESS [15.788s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.390s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:35.452s]
[INFO] OGR WPS ........................................... SUCCESS [19.110s]
[INFO] Excel Output Format ............................... SUCCESS [22.682s]
[INFO] Chart external graphics support ................... SUCCESS [1.918s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.883s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.264s]
[INFO] OWS request flow controller ....................... SUCCESS [18.910s]
[INFO] Web process status sharing with Hazelcast ......... SUCCESS [26.864s]
[INFO] Web Processing Service GUI ........................ SUCCESS [44.554s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [29.609s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.117s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.670s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.573s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [13.307s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.811s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [10.218s]
[INFO] GeoServer Security Extension Web Modules .......... SUCCESS [1.482s]
[INFO] GeoServer CAS Security Web Module ................. SUCCESS [4.415s]
[INFO] XLST based WFS output format ...................... SUCCESS [30.778s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [38.095s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [27.487s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.639s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [16.614s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [16.599s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:07.214s]
[INFO] CSW UI Module ..................................... SUCCESS [18.002s]
[INFO] DXF WFS output format and WPS PPIO ................ SUCCESS [0.374s]
[INFO] DXF WFS output format ............................. SUCCESS [21.996s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [18.955s]
[INFO] Printing Module ................................... SUCCESS [22.355s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.390s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [38.033s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [22.323s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [19.064s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.796s]
[INFO] Importer Core Module .............................. SUCCESS [1:16.865s]
[INFO] Importer REST Api Module .......................... SUCCESS [1:07.942s]
[INFO] Importer Berkley DB Persistence Module ............ SUCCESS [33.446s]
[INFO] Importer Web UI Module ............................ SUCCESS [23.931s]
[INFO] GRIB Coverage Format .............................. FAILURE [20.779s]
[INFO] NetCDF Coverage format ............................ SKIPPED
[INFO] WCS NetCDF output Module .......................... SKIPPED
[INFO] GeoServer Release Module .......................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 57:14.610s
[INFO] Finished at: Mon Feb 01 20:02:23 CET 2016
[INFO] Final Memory: 111M/293M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-grib: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-2.8.x\workspace\src\extension\grib\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-grib
Sending e-mails to: geoserver-devel@lists.sourceforge.net
channel stopped
Finished Calculation of disk usage of workspace in 1 second
